Results 1 to 3 of 3
Thread: Help with wiring a switched 1/4'' TRS jack
    Mar 2017
    2
    I am doing a project and I need help with wiring. I'm new to the electronics so don't judge and help me understand...
    I need to connect a TRS input socket to an XLR output jack. The signal fed will be mono, but balanced (TRS). I bought neutrik XLR male, however I can't find a TRS 1/4'' unswitched female jack, so I bought a switched jack (6 terminals). Now I want to connect the switched jack normally as you would connect an unswitched jack. Since I'm a newbie, I thought it would be best to consult with someone, but I have read about switched and non switched jacks, and I kind of grasp the difference. As i've said I would use the switched one as unswitched (I don't need any features of normalled tip and ring connection), so how would I wire that...?
    Would I just connect the main terminals (t to t, r to r, s to s) of the TRS jack to the XLR pins and just ignore the switched terminals, or would I need to connect them in some way in order to signal to go through to the XLR?
    And is there a downside to using a switched jack without the switches, like the noise or something?
    Thanks.
    Example of the switch I bought: http://img1.banggood.com/thumb/view/...7ad86ee35f.jpg
    Supporting Member
    Dec 2009
    UK
    2,974
    Hi and welcome to the forum.
    There's no disadvantage at all in using a switched connector. If you were to install the socket in a PCB you'd want the extra pins for mechanical stability, even if they were unused. The one in your link is dual-purpose in having pins for PCB use, as well as holes for wires if you mount the socket on a panel. Just connect to the main terminals (in the picture the top row) and ignore the other three.
    Mar 2017
    2
    Wow, that was fast. Thanks a lot friend! Much appreciated
  1. hardwiring a pcb mount mono switched jack
    By bournemouthmusician in forum Music Electronics
    Last Post: 08-29-2015, 12:20 PM
  2. Mono switched jack to speakon jack help
    By homedoc in forum Music Electronics
    Last Post: 11-15-2010, 08:41 PM
  3. 1/4" trs To Female xlr Input Jack
    By tube power in forum Music Electronics
    Last Post: 11-14-2010, 02:06 PM
  4. Input Jack Wiring
    By ajeffcote in forum Guitar Amps
    Last Post: 05-07-2008, 12:06 PM
  5. signal loss? 1/4" TS plug into 1/4" TRS jack
    By mike_mccue in forum Music Electronics
    Last Post: 12-20-2007, 02:17 PM
