Results 1 to 15 of 15
Thread: Measuring resonant peak
    Feb 2017
    4
    Hey there fellas, anyone here attempt to measure resonant peak of pickups. Either with dual trace or one of them fancy syscomp design boxes? And if so, what was your method/chain?
    Jul 2012
    Tees, Alberta
    124
    There are many threads already regarding measurement of resonance peak and using the Syscomp goodies.
    Supporting Member mozz's Avatar
    Oct 2015
    NEPA
    428
    A signal generator and a scope to show the Lissajous pattern works great. You need a good LCR meter also to measure the inductance. I have that and a Syscomp setup. The scope probes included with the Syscomp load down the circuit and give false readings due to the high capacitance, especially on 1x. You need decent probes with the lowest picofarads you can afford. I should draw my circuit out but it was pieced together from the web.
    Feb 2017
    4
    With a search I found a couple things to answer the questions I had. I was more curious of the different methods people use. I personally just started running the Syscomp Mini since its the easiest. But part of me really wants to grab a scope and generator.
    Also, thanks to the guys that sent me PMs on how they do it. Good reading!
    Supporting Member StarryNight's Avatar
    Oct 2008
    Victoria, BC Canada
    400
    Quote Originally Posted by mozz View Post
    that's too bad. I have the CGR-101 and they even have a whitepaper on how to measure RP on a pickup using that unit. Why would they include probes that give a false reading for a device that they sell to many pickup makers with the intention of measuring RP? How false of a reading are we talking about?
    rjb
    rjb is offline
    Feb 2010
    Somewhere near Bawlmer, Merlin
    2,198
    Quote Originally Posted by StarryNight View Post
    Because super-low capacitance scope probes are way expensive?
  7. #7
    Oct 2015
    NEPA
    428
    They don't give a false reading, they give a wrong reading. Add 30pf in your formula and you will see about 1000hz drop in the resonant frequency. That was with a single coil 120 pf and 2.2h. If you are just using it to compare pickups, it really doesn't matter. If you have a capacitance meter, measure the probe and you will see how much capacitance it has. A better probe and more expensive will have about 8pf.
  8. #8
    Senior Member salvarsan's Avatar
    Jan 2008
    The pines country.
    1,089
    Yeah, a drawing would help because without it, you come off as confrontational. Unless you're comfy with some schematic capture software, scrawl one on a legal pad with a Sharpie and upload the photo.
    The lofted fewmet doth soon hew close to the whirling blades.
  9. #9
    Jun 2015
    67
    On the subject of resonant peaks and capacitance, there's not really a benefit to finding the true resonant peak of a pickup, for it's own sake, unless your goal is to calculate the capacitance of the coil from the resonance and the inductance. The capacitance of a given single coil will vary by about +/- 50pF, but that will combine with the guitar cable to tack on another few hundred more pF. For data gathering purposes, I measure a "raw" resonant peak as well as a resonant peak with a 470pF load in order to get a value that is more "real world". For a Strat pickup of around 2 henries, it's common to see a raw resonant peak of 10kHz, but with a 500pF guitar cable, it falls down to around 4kHz.
    The scope probe will add about 10 to 20pF, and the CGR-101 will add another 20pF according to the spec sheet CGR-101, so you can get pretty close to calculating the true resonant peak by taking the inductance and the calculated capacitance, then subtract, say 25pF from that calculation, and then recalculate for resonance with that lowered capacitance estimate.
  10. #10
    Oct 2015
    NEPA
    428
    Yes that's all true. I like to experiment with different winding techniques and see the variations of capacitance. They will affect the sound. When I often wind a set of 3 single coils, the first wound usually has higher capacitance due to me paying more attention how i am laying down the wire, after that i get sloppy and impatient and they get more scatter wound.
  11. #11
    Jun 2015
    67
    How do you regulate the winding tension?
  12. #12
    Senior Member LtKojak's Avatar
    Feb 2008
    Milano, Italy
    935
    Quote Originally Posted by Antigua View Post
    Mojotone Hand Guided Tensioner | stewmac.com
    A little overpriced, but definitely a helpful tool, specially for the beginner.
    HTH,
    Pepe aka Lt. Kojak
    Milano, Italy
  13. #13
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    9,834
    I still tension with my fingers!
    T
    Technicians Run the World, but Bankers, Lawyers, and Accountants, Take All The Credit!
    Keep Rockin! B_T
    Terry
  14. #14
    Oct 2015
    NEPA
    428
    I have the spool about 1 ft off the floor, goes through 2 pieces of felt sandwiched between 2 pieces of metal, then i use my fingers to hold the wire and guide it.
  15. #15
    Member Alberto's Avatar
    May 2015
    Italy
    70
    Same here!
  1. Single vs 4-conductor resonant peak
    By zparts in forum Pickup Makers
    Last Post: 07-30-2015, 07:29 PM
  2. measuring resonant peak
    By Elektrometeor in forum Pickup Makers
    Last Post: 04-19-2011, 05:42 AM
  3. another resonant peak question
    By StarryNight in forum Pickup Makers
    Last Post: 08-14-2010, 12:24 AM
  4. Measuring resonant/resonance peak - Questions/advice
    By belwar in forum Pickup Makers
    Last Post: 03-10-2009, 10:22 AM
  5. Resonant peak
    By Magnetosaure in forum Pickup Makers
    Last Post: 08-25-2006, 09:03 PM
