Results 1 to 6 of 6
Thread: Help! 2 HB with p/p pots for coil cut each, + DPDT each choose which coil is cut
    Apr 2017
    3
    Talking Help! 2 HB with p/p pots for coil cut each, + DPDT each choose which coil is cut
    Hi guys, appreciate any help in advance. I can't get my head around this yet, but a customer wants 2 HB with p/p pots for coil cut each, then additional DPDT for each pup to choose/switch which coil is cut. SO he can have either north or south of each pup on or off.
    Thanks in advance :-)
    Julyan.
    Supporting Member
    Dec 2009
    UK
    3,191
    Welcome to the forum.
    You can do it with just the mini-toggle switches (on/off/on), one for each pickup. Centre gives you humbucking, either side kills one coil or the other. For an explanation see the section 'SPDT centre off switch' here;
    Guitar Wiring Site - Coil Cut Switching
    Apr 2017
    3
    Thanks Mick, but we have made a guitar and its been sprayed up and the holes are drilled. Basically, 2 hb's to 3 way switch with a push/push volume each. Adding mini switches to choose which coil to cut. Cheers :-)
    Quote Originally Posted by Mick Bailey View Post
    Supporting Member
    Dec 2009
    UK
    3,191
    No more holes to drill if you're already intending to install mini switches anyhow. Just that you don't need the pot switching unless you assigned this to (say) phase switching. If you did it this way you have a few more tonal variations - wire the DPDT pot switches as phase switches, then use the mini toggle as a regular coil tap switch to ground the coil junction (one for each HB).
    So, in non-coil tap mode the pot switch operates as a regular phase switch, but in coil tap mode the phase switch selects which coil is active.
    Apr 2017
    3
    Cheers Mick. I am going to pursued him to either do that or just regular 500k pots and use the 3 way mini switches option in your first reply. Thanks again really appreciate it. Jules.
    Supporting Member
    Dec 2009
    UK
    3,191
    The bridge humbucker in my HSS Kramer splits this way - it works perfectly.
  1. Replies: 8
    Last Post: 09-04-2015, 11:03 AM
  2. which winder coil choose? Help!!!
    By gavilan128 in forum Tools and Coil Winding Gear
    Last Post: 12-10-2014, 08:06 PM
  3. which winder coil choose? Help!!!
    By gavilan128 in forum Beginner/ Hobbyist
    Last Post: 11-27-2014, 08:30 AM
  4. Replies: 2
    Last Post: 03-27-2013, 11:45 AM
  5. single coil magnets in a HB?
    By franklin01 in forum Pickup Makers
    Last Post: 09-24-2006, 01:41 AM
