Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By Leo_Gnardo
Thread: 6l6 to el34 tube swap?
    Jul 2009
    33
    I'm sure many will think this is a question that we all should know the answer to so I may be the only one. I have a MMRD50 with 6l6's and wondered if el34's could be substituted for them with out significant changes? Thanks in advance for your patience!
    Dec 2008
    Wernersville, PA
    12,105
    #1 on the list is the power transformer.
    -Can it supply the additional heater current that the EL34's require.
    It goes without saying that the bias voltage will have to be lowered to accommodate the EL34's.
    Jul 2011
    Adelaide, South Oz
    676
    Plus
    Check that there is a link between pins 1 and 8 on ALL of the output tube sockets. This to connect the EL34 suppressor grid to the cathode. 6L6 doesn't have a suppressor grid so doesn't need that connection. A lot of amps will have that link in them just so that EL34 or 6L6 can be used. If your amp does not have that link then you will need to add it.
    Cheers,
    Ian
    Supporting Member
    Dec 2009
    UK
    3,138
    Check if pin 1 is used as a tie point for another component such as the grid stopper or screen resistor. If so you will need to move that component end off pin 1 and connect pins 1 to 8 as Ian suggests.
    I also like to increase the screen resistors from 470R to 1K for EL34.
    Jul 2011
    Adelaide, South Oz
    676
    What Mick says too - important. Even if you leave 6L6 in, changing the screen resistor to 1K 5 Watt Rat Coffin types will extend the life or your tubes.
    Cheers,
    Ian
    Jul 2009
    33
    Ok! Thanks all of you for the great information. Since the MM is stock as I bought it in 82 I think a good work around would be just find a nice 40 or 50 watt el34 that was designed that way.
    BTW Gingertube, what is "Rat Coffin" type and do they reduce current/voltage?
  7. #7
    Jul 2011
    Adelaide, South Oz
    676
    "Rats Coffin" type is slang for the white ceramic block style power resistor.
    Like this one:
    https://www.digikey.com.au/product-d...0KW-5-ND/18703
    They introduce some screen compression and limit screen power dissipation.
    Cheers,
    Ian
  8. #8
    Jan 2014
    Chiraq
    840
    oh like, that's what you get for squeelin. Mousetrap for a rat
    not like an animal rat that nibbles your cookies while you're out.
    just some old fashioned mob justice i see
  9. #9
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    5,295
    I've seen those called "ant coffin."
  10. #10
    Supporting Member
    Dec 2009
    UK
    3,138
    And 'Sugar cubes'
  11. #11
    g1
    g1 is offline
    Feb 2010
    9,774
    and 'sand box'
    Certified Dotard
  12. #12
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,368
    Wow, you know, all these names are colorful and fun. In all my years, I never adopted a name for them, I still call them rectangular ceramic resistors. Kinda trips off the tongue, donit?
  13. #13
    Sep 2012
    Dogpatch-on-Hudson
    5,295
    Better than the brand names I see on 'em: Xicon, Yageo. "Workman" on the old ones. I picture a sweaty guy with pick n shovel, what's he need a square cement resistor for? Hm, maybe he's the one mixing the mortar for a new batch.
    PeanutNore likes this.
  1. EL34 vs 6L6 tube comparison in Laney IRT120
    By Claudio Passamani in forum Other Amps
    Last Post: 04-15-2014, 02:32 AM
  2. EL34 to 6L6 change
    By mikeboone in forum Theory & Design
    Last Post: 08-17-2012, 03:10 PM
  3. Use a 6L6 or EL34 in place of the 6V6
    By brodude in forum Theory & Design
    Last Post: 01-30-2010, 06:09 AM
  4. 6l6 to el34 convertion
    By bennieusmaximus in forum Guitar Amps
    Last Post: 01-21-2009, 11:54 PM
  5. El34, 6l6, 6v6
    By russ_guitarboy in forum Tubes (Valves)
    Last Post: 05-23-2007, 08:12 PM
