Results 1 to 14 of 14
Thread: what resistors to make a 500K pot into a 100k? please
    Aug 2011
    20
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hiza, I picked up a Armstrong Rock Treble pickup and it needs to see a 100K volume & 200K tone. Would anyone be so kind as to tell me what resistors i need for each so i can use a couple of my handful of 500k sitting in my parts box? Oh and to what lugs would they go?
    Cheers, J
    0 Not allowed! Not allowed!
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,175
    Thumbs Up/Down
    Received: 269/1
    Given: 0/0
    If I had a 500k pot and wanted to make it 100k, and I was not up to doing the math, I would do it empirically. I would take another of my 500k, and with a couple clip wires to one end and the wiper, connect it in parallel the original 500k. I'd connect my ohm meter probes across the original pot too. Now I dial the new pot down until my ohm meter says 100k. Now don't move anything, but unclip the wires, and measure the resistance set on the new pot. That would be the resistance you;d need. Chose a resistor of the nearest standard value to that.
    Dec 2008
    Wernersville, PA
    12,243
    Thumbs Up/Down
    Received: 35/0
    Given: 15/0
    Just a thought, but paralleling a resistor, usually messes with the taper.
    Aug 2011
    20
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I don't own an ohm meter...
    I'm ok with it messing up the taper as long as it basically works...
    anyone?
    Supporting Member The Dude's Avatar
    May 2010
    Sioux Falls, SD
    5,165
    Thumbs Up/Down
    Received: 131/0
    Given: 111/0
    125K for the volume and 333K for the tone. Whatever standard values you have close should be fine. This is simply an answer to your specific question. I'm not making any judgement as to whether it's necessary or a good idea.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
    30,175
    Thumbs Up/Down
    Received: 269/1
    Given: 0/0
    Specifically then 120k and 330k are common standard values close to those. That assumes also that your 500k pots actually measure 500k resistance. Pots notoriously have poor tolerance - in my experience.
  7. #7
    May 2010
    Sioux Falls, SD
    5,165
    Thumbs Up/Down
    Received: 131/0
    Given: 111/0
    I'll add: If you're trying to copy the old Dan Armstrong electronics, I believe you have it backwards. The Volume should be 200K and the Tone should be 100K, but then I'm not 100% sure what you're up to. As an example, see the first diagram here:
    Dan Armstrong Registry FAQ - DA Registry
  8. #8
    Aug 2011
    20
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Whoa... thanks. I knew it was something like that! So does that mean i add 125K resister for the volume and 333K resister for the tone to get them each close to 100 and 200k? Or, are you saying there are readily available pots of 120k and 330k... ?
    sorry, i just play the damn things!
  9. #9
    May 2010
    Sioux Falls, SD
    5,165
    Thumbs Up/Down
    Received: 131/0
    Given: 111/0
    125K (or standard value of 120K) with the 500K will get you close to 100K.
    333K (or 330K standard value) with the 500K will get you close to 200K.
    There are 100K and 200K pots readily available if you wish to forget about paralleling resistors.
  10. #10
    Dec 2008
    Wernersville, PA
    12,243
    Thumbs Up/Down
    Received: 35/0
    Given: 15/0
    I agree.
    The chances of having oddball resistors to get the final results are probably slim. (unless we are dealing with a well equipped shop)
    Just buy the correct pots.
  11. #11
    Supporting Member
    Dec 2009
    UK
    3,253
    Thumbs Up/Down
    Received: 18/0
    Given: 2/0
    As Enzo points out, pots have a slack tolerance and I doubt that the difference between a 333k and 330k resistor would be audible. I have some 250k guitar pots that read 218k, and some 500k that read 570k.
    A Suhr guitar I recently worked on use a Superswitch to reduce the 500k pots to 250k when switching from humbucker to single coil. They just parallel a resistor across the outer lugs of the pot to reduce the value and it works just fine.
  12. #12
    30,175
    Thumbs Up/Down
    Received: 269/1
    Given: 0/0
    And for that matter, 333 is less than 1% off 330, so a common 5% 330k might well measure 333k anyway.
  13. #13
    Feb 2010
    Just south of Bawlmer, Merlin
    2,360
    Thumbs Up/Down
    Received: 74/1
    Given: 53/1
    Quote Originally Posted by Jazz P Bass View Post
    That.
  14. #14
    Aug 2011
    20
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thanks much!!
  1. 470K vs 100K wah pot
    By rymac in forum Guitar Effects
    Last Post: 08-14-2014, 06:53 PM
  2. How Bad Is It To Have A 100k Volume Pot?
    By gellfex in forum Guitar Tech
    Last Post: 06-15-2011, 03:08 AM
  3. 500k pot + 500k resistor = 250 k pot
    By getonemaker in forum Music Electronics
    Last Post: 03-02-2011, 04:33 PM
  4. Changing a 100K linear volume pot to 1M
    By do clear in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-14-2009, 01:29 AM
  5. 1 500K vol pot, but B pup w/250K for ex.
    By socalscott in forum Guitar Tech
    Last Post: 09-12-2007, 06:47 PM
