Results 1 to 3 of 3
Thread: Line6 Tonecore Dock Clipping Problem
    New Member
    Jun 2017
    2
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I just picked up a used Echo Park as a spare/backup, but there is some very fuzz clipping happening, plus an unusual amount of hiss and windy noise. Something is very wrong.
    It works fine in bypass mode, so I swapped the Tonecore Echo Park module from my other pedal. No change, but this tells me the issue is with the dock -- not the module.
    I also flipped the internal dip switches that affect gain, and reduced the input using my amp effect loop's Send control but the fuzzy clipping was still there.
    I can't do repairs to SMDs myself, but have a friend who may be able to help. Any clues from someone where would be helpful before poking around in there, though.
    I only found one other instance of this issue on Line 6's tech support page, and they strongly recommended the guy just replace it.
    0 Not allowed! Not allowed!
    Dec 2008
    Wernersville, PA
    12,243
    Thumbs Up/Down
    Received: 35/0
    Given: 15/0
    Good luck 'fixing ' that.
    Narrowing it down to the power supply, the A/D Codec or the DSP is going to be a chore.
    TCDDK%20Hardware%20Guide).pdf
    New Member
    Jun 2017
    2
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thanks for that clue. Actually, I downloaded the full document a long time ago to research the DIP switch functions, but didn't notice there was a schematic at the back! One more clue I found was that the distortion goes away when the MIX control is turned up all the way. That suggests to me the problem is one of the final op-amps or maybe one of the input resistors.
  1. samson xm610 odd clipping problem
    By mattball826 in forum Music Electronics
    Last Post: 07-14-2016, 06:05 AM
  2. dead line6 tonecore base
    By nosaj in forum Guitar Effects
    Last Post: 11-13-2015, 02:05 AM
  3. Bogner (Line6) Alchemist problem
    By puterg33k in forum Music Electronics
    Last Post: 01-07-2014, 01:51 PM
  4. Line6 Spider III 15 channel switch problem
    By baev_al in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-08-2012, 06:07 AM
  5. Replies: 10
    Last Post: 06-25-2010, 07:48 AM
