Results 1 to 22 of 22
Thread: Wider coils than Jazzmaster pickups?
    May 2017
    33
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    Hi everybody,
    Has anyone in here experimented with *really* wide coils? The widest I have encountered so far are JM pickups, which I love (wound one yesterday that sounds pretty mean), but it makes me want to see how much further the concept behind those can be expanded. Most of the pickups I make go on home made guitars, so non-standard bobbin shape & size aren't really an issue.
    The one problem I can see for now is that a larger portion of the coil, ie. on the sides, would be useless as there would be no string vibrating above it. I assume the result would be an even darker overall sound.
    Any thoughts on this?
    0 Not allowed! Not allowed!
    Member Rodent's Avatar
    Mar 2013
    Pacific NW
    100
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    if by wider you mean perpendicular across the strings, then these 7-string bass pickups should certainly qualify. they're 145mm long x 32mm wide, and require a custom made cover since none are available in the free market for this 'standard' Bart size
    and these are for a bass with 'only' seven strings. there are basses on the market with up to 13 strings - now that a wide (err ... long) pickup!
    May 2017
    33
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    Ah, sorry, I meant wider as in flat and wide all around, but most importantly spreading further parallel to the strings rather than just being a longer coil. Nice looking wood covers though!
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    10,137
    Thumbs Up/Down
    Received: 80/21
    Given: 88/9
    If you mean a short height between the flats?
    A wide flange across the wound coil, like a P90, or a Jazz Master coil?
    If you get wider than that, don't you end up with a darker or muddier pickup sound?
    T
    “When you find yourself in a hole, quit digging.” WILL ROGERS
    Keep Rockin! B_T
    Terry
    Feb 2010
    Just south of Bawlmer, Merlin
    2,359
    Thumbs Up/Down
    Received: 68/1
    Given: 53/1
    If by wider you mean perpendicular across the strings, you can't get much wider than this configuration by Bruce Johnson. I know it's not what you were considering- but there's always more than one way to skin a cat.
    Here's Bruce's original post: http://music-electronics-forum.com/t32943/#post301401
    -rb
    Senior Member Chris Turner's Avatar
    Nov 2009
    Tucson, AZ
    240
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    This is the widest I've seen... never heard one, though, so no idea how this kind of thing sounds.
  7. #7
    Feb 2010
    2,359
    Thumbs Up/Down
    Received: 68/1
    Given: 53/1
    Quote Originally Posted by Chris Turner View Post
    Yup, same idea but with lipsticks instead of "Strat-type" pickups.
    I've never seen anyone use that configuration other than on bass.
    IIRC, wide sensing window emphasizes the fundamental(?)
    -rb
  8. #8
    Member parentheticalfact's Avatar
    Mar 2007
    United States, Portland Oregon
    82
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I've done this quite a few times.
    Tonally, RJB is on the right track, more fundamental emphasis. Basically a fat tone with lower emphasis on high harmonics.
    Side effect is it becomes a huge antenna for hum.
  9. #9
    May 2017
    33
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    Quote Originally Posted by big_teee View Post
    T
    Yup, exactly. I have a feeling the flange can be taken a bit further, as Jazzmaster pickups aren't even close to being dark or muddy...I'm curious as to what a few extra millimeters on each side would do, flattening the bobbin accordingly to keep things in the 7-8k area.
  10. #10
    Jun 2010
    Mid-South USA
    10,137
    Thumbs Up/Down
    Received: 80/21
    Given: 88/9
    Quote Originally Posted by epizootics View Post
    If you wish to stay with standard parts and covers?
    You could try 43PE, and, or, 250-300k Pots.
    You can increase the turns count a bunch!
    That would be my remedy, rather than all the fabrication of custom parts.
    Unless you like making custom parts?
    T
    Keep Rockin! B_T
    Terry
  11. #11
    May 2017
    33
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    I do like to make custom parts! I make my own guitars (no money to buy the gear I like & unlimited access to my dad's cabinet making workshop) and non-standard dimensions aren't an issue. As stated above, I don't want to go over a fairly standard DCR/output, I've never been one for hot pickups.
    I guess I'll just give it a try - increase that flare size until it gets too dark. I'll try and post the results on the board as I go if anyone's interested...
  12. #12
    Jun 2010
    Mid-South USA
    10,137
    Thumbs Up/Down
    Received: 80/21
    Given: 88/9
    Sounds good. If you like to make parts, make parts.
    I prefer to make Pickups, not pickup parts!
    Actually going to smaller wire makes the size of the coil smaller for same turn count.
    Smaller coil size usally means brighter.
    So with 43 same turn count will be more DCR, but not hotter.
    You would have to increase turn count to make it hotter.
    Anyone else?
    GL,
    T
    Keep Rockin! B_T
    Terry
  13. #13
    Mar 2007
    82
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    T
    Turns count and DCR are only part of the picture and while a higher resistance will generally darken the pickup so will a wider coil. Don't forget how important coil shape is to a pickup, which accounts for why most P-90 for tele type pickups don't truly sound like a P-90. Lots of factors to experiment with here to get your desired result.
  14. #14
    May 2017
    33
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    Anyone else?
    GL,
    T
    There's a thought here - I could try awg 43 to brighten up the design, reducing the bobbin's height further to compensate for the thinner gauge but reaching an overall theoretical balance with the darkening of the tone from the flatter shape of the pickup...
  15. #15
    Supporting Member
    Sep 2007
    3,004
    Thumbs Up/Down
    Received: 3/0
    Given: 0/0
    It makes sense to review how a pickup works in order to understand when a wider coil would have the kind of effects you are interested in.
    1. The permanent magnetic field from the pole pieces magnetizes the strings. Right over the pole pieces, the field from this string magnetization points towards the pole pieces. The string magnetization becomes weaker further from the pole pieces along the strings, and it increasingly points along the string rather than towards the pole piece.
    2. A turn of wire in the coil produces a voltage that depends on the time varying field from the magnetized vibrating string, but it is only field lines that pass through the loop that count. Furthermore, it is only the component of the field that is perpendicular to the plane of the loop that counts. So the field from the part of the string over the pole piece is very effective since it is strong and points through the coil. But the field from a part of the string that is farther away is both weaker and it points less directly through the coil because the magnetization points more along the string.
    3. When you wind more wire on a coil, whether it is by making the coil wider or deeper, you increase the inductance, making the resonant frequency lower, and the resistance, making the resonant peak broader and less high.
    4. When you make a coil wider, the turns near the outside enclose the magnetic field from the part of the string over the pole piece just as the turns near the pole pieces do. However, the additional field that the outer turns enclose (from the parts of the string further away from the pole piece) do not add much.
    5. If you made the coil very wide, you would get almost nothing. This is because magnetic field lines have no beginning or end. So a field line from the vibrating string that passes directly through the coil loops back to the string. A wide enough coil would enclose this line twice, once in each direction, and so its effect would cancel out.
    6. A narrow strat pickup gets nearly all of the field from the most effective part of the string. A wider pickup sees this field more times (because it has more turns), but gets very little voltage from the additional parts of the string that are sampled because these parts are weakly magnetized, and the field mostly points in the wrong direction.
    7. You can use information such as this to guide experimentation, but the exact sound you get is only learned by winding it and listening.
  16. #16
    Feb 2010
    2,359
    Thumbs Up/Down
    Received: 68/1
    Given: 53/1
    Quote Originally Posted by rjb View Post
    Too late to edit...
    Meant to say "If by wider you mean along the strings", or something like that.
    But you-all can tell what I meant by the pic.
    -rb
  17. #17
    Jun 2010
    Mid-South USA
    10,137
    Thumbs Up/Down
    Received: 80/21
    Given: 88/9
    Too late to edit...
    -rb
    The Bruce Johnson coils don't appear to be one wide coil.
    I think they are 4 skinny coils turned sideways!
    T
    Keep Rockin! B_T
    Terry
  18. #18
    Feb 2010
    2,359
    Thumbs Up/Down
    Received: 68/1
    Given: 53/1
    Of course they are. That's why I referred to a "configuration".
    I'm not sure why epizootics wants to experiment with *really* wide coils - but if the goal is to sample a long section of the string, this is an alternate way of achieving that goal.
    -rb
  19. #19
    Jul 2014
    Oregon
    303
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by Mike Sulzer View Post
    Question on your #6- Let's say we made one of those hybrid, P-90-ish pickups that's basically a Strat pickup with A2 or A5 rods and 1/4" between the flats. So now you have a pickup with a wider, shorter coil, but same wind count at 9000-10,000 and same DCR. Does it sound warmer because a lower voltage is being created and that lower voltage truncates the frequency spectrum?
  20. #20
    Supporting Member
    Sep 2007
    3,004
    Thumbs Up/Down
    Received: 3/0
    Given: 0/0
    Quote Originally Posted by Jason Rodgers View Post
    The short approximate an answer is that the wider shorter coil has a higher inductance, and thus a lower resonant frequency. The slightly longer answer is that if you use the same number of turns and keep the wire size the same, then the dc resistance increases (longer average turn length), making the peak broader and lower. Predicting the exact inductance of coils in pickup shapes is hard. Even with an air core, it is not so easy, but with some magnetic material in the core it gets even harder.
    One simple thing to remember is that if you have a single turn coil, the bigger you make it, the higher the inductance. Another thing is that in a multi turn coil, the turns interact, making the inductance higher than you might expect if you just counted the number of turns. Also, in a wide flat multi turn coil, the turns interact more than in a tall coil of the same number of turns. But these are just approximations. And it is hard in experimenting with pickups to change just one factor.
  21. #21
    Member Alberto's Avatar
    May 2015
    Italy
    82
    Thumbs Up/Down
    Received: 2/0
    Given: 2/0
    Theory aside, experimenting with 0,3'' between the flats, strat alnico rods and same turns of awg42 wire, I get warmer sounding pickups.
  22. #22
    Jul 2014
    Oregon
    303
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by Alberto View Post
    Yeah, I did this with A2 rods and 3/8" between the flats. Just wondering what the theory behind it was.
  1. BF Princeton Reverb - wider range for treble pot
    By Bluefinger in forum Mods & Tweaks
    Last Post: 05-25-2017, 07:31 PM
  2. Self-demagnetizing & Jazzmaster pickups
    By fieldwrangler in forum Pickup Makers
    Last Post: 02-16-2017, 02:18 PM
  3. Replies: 50
    Last Post: 03-17-2016, 08:52 PM
  4. Pickups with Air Coils
    By big_teee in forum Pickup Makers
    Last Post: 10-18-2011, 12:49 AM
  5. Constructing Pickups (coils, etc) without bobbins.
    By peskywinnets in forum Pickup Makers
    Last Post: 10-19-2009, 12:11 AM
