Results 1 to 8 of 8
Thread: How to warm up a bridge humbucker in split single coil mode ...cap/resistor
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,067
    Thumbs Up/Down
    Received: 8/0
    Given: 5/0
    i have one of my humbuckers going in the bridge of a custom esquire & in split single coil mode on a push pull but he wants a warm tone .Now i will wiring that the slug coil will be the coil the works in single coil mode & i will overwinding that coil ..My question is about adding a cap & or resistor to tame some of the treble . & if so what value ..... thanks
    0 Not allowed! Not allowed!
    "UP here in the Canada we shoot things we don't understand"
    Cheshire, UK
    1,791
    Thumbs Up/Down
    Received: 18/0
    Given: 14/0
    Quote Originally Posted by copperheadroads View Post
    I'd try the same values you'd use for the normal tone control turned down a little. eg. 22n or 47n in series with a 25k to 100k resistor. Small capacitor values will just move the frequency of the resonant peak.
    Feb 2010
    Just south of Bawlmer, Merlin
    2,360
    Thumbs Up/Down
    Received: 74/1
    Given: 53/1
    I think that sounds about right.
    The "Eldred Mod" (~4.7nF switched straight across the pickup) produces what some describe as a "half-cocked wah" or "vocal vowel tone". I like it, but it doesn't seem to be what your customer is after....
    -rb
    Jun 2009
    2,067
    Thumbs Up/Down
    Received: 8/0
    Given: 5/0
    Thanks guys did some test 22k,51k,100k resistors with .022uf & .047uf & settled on the 22k+ the .047k
    Feb 2010
    2,360
    Thumbs Up/Down
    Received: 74/1
    Given: 53/1
    I assume that "Esquire" means "one pickup".
    Just wondering:
    Is the 22K + .047uF in all the time, or just in split mode?
    In addition to the push-pull, is there a 3-way selector?
    What are the planned selections?
    -rb
    Jun 2009
    2,067
    Thumbs Up/Down
    Received: 8/0
    Given: 5/0
    I was told on a push pull . I tested it in my test guitar which has a 3 way blade & tested the split coil wires red & white (same as Seymour's) with the cap & resistor wired to neck position .& i do believed it worked as it should .
  7. #7
    Feb 2010
    2,360
    Thumbs Up/Down
    Received: 74/1
    Given: 53/1
    My question wasn't very clear, and I am still confused about the answer.
    I know that the original Esquire had a bridge pickup, and a 3-way selector which changed wiring configurations to get 3 different tones out of that one pickup. I also know that some Esquires have been modded to add a neck pickup.
    So the first part of my question should have been "How many pickups in this custom esquire?"
    Second part is about your bridge humbucker with the push-pull to split coils. "Will you have the 22k/.047uF across the pickup always, or only when in single coil mode?"
    Third part is about the 3-way selector. If the guitar has two pickups, I assume the switch will be wired like a Tele. But if the guitar has one pickup, then what are the three different configuration/tones?
    If anything is a trade secret, forget I asked.
    -rb
  8. #8
    Jun 2009
    2,067
    Thumbs Up/Down
    Received: 8/0
    Given: 5/0
    When someone says Esquire ,,it's a one pickup tele .
  1. Blues: BK Abraxas bridge split mode _ 63 Veneer Neck
    By fdesalvo in forum Plug Your Music/Band
    Last Post: 11-18-2014, 08:09 PM
  2. 1 humbucker 1 single-coil coil-tapping blade-switch options?
    By luthierwnc in forum Music Electronics
    Last Post: 11-12-2013, 07:07 AM
  3. Replies: 18
    Last Post: 05-28-2012, 11:13 PM
  4. Looking for a tapped strat bridge single coil
    By imaradiostar in forum Pickup Makers
    Last Post: 11-02-2011, 01:52 PM
  5. Strat Bridge Single Coil with baseplate
    By big_teee in forum Pickup Makers
    Last Post: 12-26-2010, 02:04 AM
