Results 1 to 2 of 2
Thread: Mackie Thump th15a issues
    Jun 2014
    scotland
    69
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Good evening,
    I have subject active on the bench at moment. Flashing power led but power supply is fine 28vdc+- on the rails. Leave it switched on in 'flashing' mode for about a minute then the led stays on. barely audible sound through speaker. Could it be the caps in the power supply failing - although the voltage is steady - or is the amp board failed? Amp boards are no too expensive - I swapped out the TDA chip for a new 1 without any luck. I have a feeling the failure, if it's the board, is the small chip on the underside (which handily enough has no markings or identification).
    I would normally swap out the board at this stage but if that's not the issue (the LED thing is bugging me) where do you stop in replacing boards???
    Cheers guys.
    J
    0 Not allowed! Not allowed!
    In life there are no problems, only challenges but in my present situation I may have a problem
    Jun 2014
    scotland
    69
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Aha, after some further browsing the unidentified chip is the tda89xx class d
  1. Mackie TH15a
    By guitardad in forum Music Electronics
    Last Post: 04-12-2016, 02:43 AM
  2. Mackie Thump TH-12A Issues
    By jadams in forum Music Electronics
    Last Post: 10-09-2015, 03:08 PM
  3. Mackie thump TH15a Circuit required
    By a2d_converter in forum Schematic Requests
    Last Post: 03-22-2014, 04:21 PM
  4. Mackie TH-12A Thump
    By Brian Swatton in forum Schematic Requests
    Last Post: 10-23-2013, 08:42 AM
  5. Mackie Thump TH-18s problems
    By tonepumpamps in forum Music Electronics
    Last Post: 04-17-2011, 05:43 AM
