Results 1 to 7 of 7
Thread: Power Transformer Question
    Sep 2016
    Thailand
    26
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I am trying to replace a power transformer in a Fender Supersonic 60. I have looked at three different transformers and they all have different secondary specs. Classic Tone tranny is 484VDC which I believe is the same as stock. Mercury has 364V/514VDC. Hammond has 342V/482VDC. How much can they vary and still be ok? The Mercury seems very high compared to the other two. My transformer knowledge leaves much to be desired so maybe I am missing something here. Thanks
    0 Not allowed! Not allowed!
    Feb 2010
    9,931
    Thumbs Up/Down
    Received: 129/0
    Given: 290/0
    Is the Fender replacement part not available?
    The aftermarket types are not likely to have the extra low voltage winding, unless they are specifically designed for this model amp?
    edit: I see that the classic tone is indeed a direct replacement for Fender part # 041752
    The voices in my head are idiots!
    May 2015
    Fayetteville, AR USA
    298
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I'd be concerned about the screen grid voltages getting too high. I'd probably go with the ClassicTone one. It's really close to spec and CT are a good value, quality transformer.
    Also, that 484VDC rating is based on a 93mA current draw. I suspect you'll be drawing at least 50% more than that.
    Feb 2010
    9,931
    Thumbs Up/Down
    Received: 129/0
    Given: 290/0
    Agree with above that ClassicTone looks like a good replacement. It does have all the same windings as the stock unit.
    Sep 2016
    Thailand
    26
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Didn't mention
    I didn't mention that I need a 220v transformer which Classic Tone does not have. Edcor will possibly make one for me. Mercury has one at a crazy price. I currently am using the Hammond 290VEX with a Variac @ 240V but I am not getting enough heater voltage. The Classic specs show 3.75A as do the Hammond. The tubes are 2x6L6=1.8A, 8x12ax/at7=2.4A which is 4.2A total. I haven't measured the actual heater amp draw. When I measure heater voltage across pins 2 and 7 I get 5.3 volts. I think Fender cheaped out on the transformer so they could use it in the Hot Rod Deluxe which needs less heater current. As previously stated I am for far from an expert on this subject. Let me know if I am on the wrong track.
    May 2015
    298
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I'd probably go with the Edcor, then. They make quality transformers at a reasonable price. MM makes quality transformers, just not at a reasonable price...
  7. #7
    Sep 2016
    Thailand
    26
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I am thinking about using the existing Hammond 240v transformer and adding a separate filament transformer. This would give the heaters the correct voltage but the plate voltage would be a little on the low side like around 450VDC. Do you think this would be ok?
  1. Firefly Power transformer question
    By kkillebrew in forum Theory & Design
    Last Post: 03-25-2011, 05:30 PM
  2. Power Supply Transformer question
    By Howlin' Mad Mac in forum Theory & Design
    Last Post: 02-21-2011, 11:44 PM
  3. 5e3 Power Transformer Question
    By AppleScrappler in forum 5 E 3
    Last Post: 01-13-2011, 08:20 AM
  4. Power transformer voltage question
    By bmacrae in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-27-2009, 03:43 PM
  5. tsl power transformer question
    By wyomingrocks in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-13-2009, 01:23 AM
