Results 1 to 19 of 19
Thread: Hartke HS 1200 Kick Back bass amp NOT WORKING
    May 2016
    34
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hi ,
    I am trying to repair this amp.
    The problem is : is not switching on.
    NOW: I check the cord, the fuse on the chord,the fuse on the amp. everything OK.
    I have my bulb limiter.
    I check the continuity and everything is OK.
    I detached the wires from the transformer to the main PCB board to isolate transformer to the circuit.
    No reading out of the transformer.
    I read 250v between the blue and the red going into the transformer.
    Is the transformer busted?
    Thanks for any input
    I put the schematics in the attachmentsamson hs1200 sch.pdf
    0 Not allowed! Not allowed!
    Supporting Member The Dude's Avatar
    May 2010
    Sioux Falls, SD
    5,156
    Thumbs Up/Down
    Received: 121/0
    Given: 102/0
    Check continuity across the tranformer primary with no power applied (your blue and red wires). If you get an infinite reading, the transformer primary is likely open.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
    May 2016
    34
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    on the transformer I get 5.4 between the red and blue wires and buzzing from the multimeter.
    May 2010
    Sioux Falls, SD
    5,156
    Thumbs Up/Down
    Received: 121/0
    Given: 102/0
    ...and that is the same place you read 250VAC? If that is so, connect the primary back to the amp and apply power. Leave the secondary disconnected. What VAC do you get across each of the secondary windings labeled SEC1 (red to red) and SEC2 (blue to blue)?
    Edit: "buzzing from the multimeter"? You did remove power first?
    May 2016
    34
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hi Dude!
    For buzzing I mean the continuity test(the sound that there is continuity....sorry for confusion)with power off.
    I did switch the power on(I have my poor mans Variac) and on SEC1 I couldn't read any voltage between Yellow and red1 ,Yellow and red2.
    May 2010
    Sioux Falls, SD
    5,156
    Thumbs Up/Down
    Received: 121/0
    Given: 102/0
    Sorry for what might seem a dumb question, but I have no idea of your experience level. You are measuring for AC voltage?
    Also, do you get anything across SEC2 or no voltage across either secondary tap?
  7. #7
    May 2016
    34
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    No worries for Dumb Questions, I measure DC on the output of the transformer. AC on the input.
    Now I saw that one of the blades was a bit loose(the one for the brown cable BR on the schematics). I resolder it but... OUcchh Lamp limiter kiks in now. so there is a short somewhere I presume
  8. #8
    May 2010
    Sioux Falls, SD
    5,156
    Thumbs Up/Down
    Received: 121/0
    Given: 102/0
    The transformer output will be AC- not DC. The job of a transformer is only to provide isolation and, in most cases, step the voltage up or down. The exception is a 1:1 transformer used for isolation. It is the rectifiers and filter caps that convert that AC to DC voltage.
  9. #9
    May 2016
    34
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    ouch, so it is ac to ac transformer? I assumed it was ac to dc . My bad then... Now the problem that I have is a short circuit somewhere
    Of course after the rectifiers is DC ...
  10. #10
    May 2010
    Sioux Falls, SD
    5,156
    Thumbs Up/Down
    Received: 121/0
    Given: 102/0
    The most likely culprit is one or more shorted output transistors. Check them for shorts. Note that they are paralleled. If one is shorted, they all appear to be shorted. If you find a short there, you will need to remove them and test out of circuit to see which of them is actually shorted.
    Edit: The above is if you do indeed have a short. However, in post one you said the fuses were good. A short would likely cause a fuse to blow. How bright is your bulb limiter? I'm wondering if the "brown cable" connection problem you found was the only problem and the brightness of your bulb is normal. It would still be a good idea to check for shorts before removing the bulb limiter.
  11. #11
    May 2016
    34
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hi Dude, I haven't connected the transformer to the PCB board Yet . RC1 and RC2 are not connected yet
  12. #12
    May 2010
    Sioux Falls, SD
    5,156
    Thumbs Up/Down
    Received: 121/0
    Given: 102/0
    Oh. I thought you were connected. So the bulb is glowing bright even with the secondary disconnected? Measure the AC voltages out of the 2 secondary windings and post them.
  13. #13
    May 2010
    Sioux Falls, SD
    5,156
    Thumbs Up/Down
    Received: 121/0
    Given: 102/0
    I should add. Be careful in there. We don't want to read about you in the obituaries.
  14. #14
    May 2016
    34
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I am still alive like Bee Gees
    Quote Originally Posted by The Dude View Post
    Hi Dude, sorry for late reply but I went to bed(I am in LOndon so we have different time). Thanks for your help.
    The Light bulb is coming on very bright.
    At the beginning it wasn't because there was a broken trace between the brown and red cable blades.
    Now that I soldered the two, it is showing a short(a very bright light bulb).
    Rc1 and Rc2 are disconnected from PCB board.
    I can't measure the AC voltage out of RC1 and RC2 as I see the light bulb(very bright) coming up and I switch off immediately.
    Am I missing something?
    No worries Dude I am careful there ( I know its 250 V AC )
    I should add I am no expert but I did open up quite a few amps in the past.
    I am looking for some good advice from people that are more experienced than me and I am really grateful for any input given .
  15. #15
    May 2010
    Sioux Falls, SD
    5,156
    Thumbs Up/Down
    Received: 121/0
    Given: 102/0
    This isn't making much sense. No fuses were blown indicating that there wasn't a short anywhere. Yet, with the transformer secondary disconnected, you say the bulb is glowing brightly indicating a short. Please check that all of the fuses are the correct value. Maybe someone stuck a highly overrated fuse in the unit? Also check the transformer for windings that are shorted to each other or the transformer housing.
  16. #16
    Feb 2010
    9,931
    Thumbs Up/Down
    Received: 128/0
    Given: 290/0
    Sounds like initially there was an open in the circuitry to the primary which he has now corrected.
    Now that he has connected the primary, he has bright bulb without the secondary connected to anything.
    So either there is some other fault in the circuitry to the primary, or the power transformer is bad.
    The voices in my head are idiots!
  17. #17
    May 2016
    34
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hi ,
    Yes G1 that's the case.
    Now: How do you test the transformer out of circuit? I have no idea so please be patient with me.
    PRIMARY I have blue,red,brown,white and grey cable
    SECONDARY I have yellow and 2 reds, 1 black and 2 Blues.
    I have as tools only a normal digital multimeter.
    Thanks Guys
  18. #18
    Feb 2010
    9,931
    Thumbs Up/Down
    Received: 128/0
    Given: 290/0
    Quote Originally Posted by Fabrizio View Post
    On primary, connect red to brown. Now apply voltage (from limiter lamp) between blue and grey. If bulb lights bright, transformer is bad. Otherwise, check AC volts at secondary between 2 reds, then between 2 blues.
  19. #19
    May 2016
    34
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thanks G1
    Quote Originally Posted by g1 View Post
    Hi G1 ,
    Sorry for late reply but I was doing gigs over the weekend.
    You are right it is a Bad Transformer , I followed your instructions and the bulb limiter went on very bright.
    Thank you very much for your clear instructions.
    Cheers
  1. polytone brute bass amp back again....
    By pontiacpete in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-03-2017, 03:03 AM
  2. Blown Transistor on Hartke HA1200 (hs-1200 board) for Kickback 12. Any advice?
    By Nobail in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-09-2016, 04:12 PM
  3. Hartke HS 1200 bass amp transformer needed
    By detoxic in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-29-2015, 07:19 AM
  4. Fender TB-1200 Bass Amp Output Stage Failure
    By nevetslab in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-02-2014, 05:52 PM
  5. XR-1200 Quit working
    By Novo in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-23-2012, 02:59 AM
