Results 1 to 10 of 10
Thread: silverface deluxe reverb
    Jan 2014
    maryland
    12
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hey guys I've got a silver face deluxe reverb I'm working on.After it warms up on the vibrato channel only,the bass drops out of the signal. reverb still there just sounds tinny,all the fullness goes away.wont do it on the normal.happens after 20 minutes and the standby is reengaged.The amp has been recapped sockets cleaned. any thoughts on this
    0 Not allowed! Not allowed!
    Supporting Member
    Staffordshire UK
    3,386
    Thumbs Up/Down
    Received: 42/0
    Given: 39/0
    Does the setting of the trem intensity control affect the issue?
    Do all the controls work as normal when it's in the fault mode?
    Jan 2014
    maryland
    12
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    deluxe reverb
    Quote Originally Posted by pdf64 View Post
    Thats a good question,the reason i say this is its never been engaged no footswitch when this has occurred controls seem to work normally.Ill fire this thing up and double check and get back Thanks!
    Supporting Member
    Staffordshire UK
    3,386
    Thumbs Up/Down
    Received: 42/0
    Given: 39/0
    Some types of failure of the optocoupler (or oscillator/buffer tube) can mess up the sound of the fx channel whether the trem is switched on or not.
    Supporting Member
    Dec 2009
    UK
    3,253
    Thumbs Up/Down
    Received: 18/0
    Given: 2/0
    Make sure the treble pot isn't disconnecting on the bass side when warm. This will leave you with only the treble control of the tone stack connected and only have a limited operation, as you just have effectively a 250pf cap + 250k pot in series with the signal and no low-end. If this is happening then the bass control won't work at all.
    Jan 2014
    maryland
    12
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    deluxe reverb
    Quote Originally Posted by Mick Bailey View Post
    Will check both of these after work tonight and report back.
  7. #7
    Sep 2013
    26
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I'm not sure about the schematic but if the trem channel is tubed, I'd try a simple substitution with a known good tube. Also, a simple and thorough visual inspection goes a long way. Cheers.
  8. #8
    Mar 2010
    231
    Thumbs Up/Down
    Received: 1/0
    Given: 1/1
    Check the ground wires going to the brass panel under the controls. Push on them with screwdriver. Also a bad coupling cap would cause bass drop out..... Good luck
  9. #9
    Supporting Member
    Dec 2009
    UK
    3,253
    Thumbs Up/Down
    Received: 18/0
    Given: 2/0
    Good point. A bad coupling cap can result in the signal being coupled just through board capacitance and secondary paths. If it's happening when the amp warms up a blast of freeze spray should identify the problem.
  10. #10
    Sep 2013
    26
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Vibrato section tube? Was it checked with a known good tube?
  1. Fender Silverface Deluxe Reverb Hum
    By jeffkaplan in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-23-2016, 09:53 PM
  2. Fender Deluxe Reverb Silverface - No Sound
    By rmeadows in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-09-2007, 03:58 PM
  3. Silverface Deluxe Reverb boost, any good ?
    By Paul P in forum Theory & Design
    Last Post: 11-22-2007, 03:48 AM
  4. Filtering in Silverface Deluxe Reverb
    By Doug in forum Mods & Tweaks
    Last Post: 09-20-2006, 03:49 PM
  5. SilverFace Deluxe Reverb Conversion
    By Corona Blue in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-16-2006, 06:31 PM
