Results 1 to 26 of 26
Thread: Please help with calculations on Output transformer to get ohms l
    Aug 2017
    20
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hi ,I am running 24 volts into the primary winding and I get .6 volts out of the secondary .Can you tell me how many ohms this output tansformer is?This goes to an amp from 1965 where the brand has been removed ,and there is no schematic in it .It comes with two 8ohm magnavox speakers that look original .so it should be 4 ohms in parallel ,or 16ohms in series ,and I don't wanna hook it up wrong .The wiring was disconnected from the speakers so that won't help.the spade 4 spade connectors on one speaker are covered in solder ,so that makes me think in series and its 4 ohms .I want to know what the equation says.I went on a conversion chart site and I got 24v /.6 =960ohms .I don't even know if that's right or what that translates too.Itbsaid current was .025 Amps .Please help me figure this out I don't have much hair left to pull out.😳
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	44506   Click image for larger version.
    0 Not allowed! Not allowed!
    Senior Member Malcolm Irving's Avatar
    Dec 2014
    Derbyshire
    364
    Thumbs Up/Down
    Received: 0/0
    Given: 5/0
    24V to 0.6V means a transformer turns ratio of 24/0.6 = 40 to 1. But the impedance goes according to the turns ratio squared, so an impedance ratio of 40x40 = 1600 to 1.
    With a 4 ohms speaker load that gives a primary impedance of 1600 x 4 = 6400 ohms
    Or a 16 ohm load gives 1600 x 16 = 25600 ohms.
    Don’t know what the output tube(s) are, but the 4 ohm version looks more reasonable.
    Lifetime Member
    4,249
    Thumbs Up/Down
    Received: 4/0
    Given: 0/0
    Malcolm is correct. You measure the voltages, take the ratio, square the ratio, and that's the ohms >ratio<.
    I would add to that a couple of questions.
    > How is the primary driven? Is it single ended or push pull? That is, one tube or two?
    > How accurately can you measure 0.6V? That has a big effect on the calculations.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,876
    Thumbs Up/Down
    Received: 77/1
    Given: 0/0
    Is there some reason we ought not run voltage through the other way? Would it not be easier to get good readings if we sent say 6v into the secondary, or even the 24v, and then expect a large voltage at the primary? Then you wouldn't need to try to interpret a tiny 0.6v voltage. SO 40 to 1 would be 6v in and 240v out. Easy to read. Am I missing something? No one seems to do it that way.
    Jul 2017
    British Columbia
    357
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    ...expect a large voltage at the primary?
    <snip>
    Definitely lower error your way. But some of us get a little nervous around large AC voltages. And even more nervous about them when newcomers to electricity are involved.
    I once built a strobe circuit for a physics demo in college. It took 230 - 240 V AC from the mains, and fed it into a voltage doubler. That produced somewhere around 650 volts DC to the Xenon flash tube. I was scared the entire time I worked on the bloody thing, but I built it, and got it working. (I was young and foolhardy. I wouldn't risk that today.)
    -Gnobuddy
    29,876
    Thumbs Up/Down
    Received: 77/1
    Given: 0/0
    Then don't work on tube amps, the power transformers put out more than my 240vAC, and as to DC, Music Man amps with their 700-800v B+ ought t be positively frightening. SVT with 660vDC B+. That newcomer already has his fingers in a high voltage circuit.
    But my question was more the general case, I wondered if ther was some technical reason not to do it my way.
  7. #7
    Dec 2014
    Derbyshire
    364
    Thumbs Up/Down
    Received: 0/0
    Given: 5/0
    I understand what you mean. But a digital multi-meter doesn't read 0.6V and 240V, it reads 0.5973V and 240.2V. The accuracy of both readings (in %) is often the same.
  8. #8
    Aug 2017
    20
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thanks for the help.I have 2 el84 tubes .
  9. #9
    Aug 2017
    20
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thanks for the info.I have 2 el84 tubes.
  10. #10
    Aug 2017
    20
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thank you for the info.I will Definately run the 24volts into the secondary and see what i get out of the primary.I am Definately comfortable inside a tube amp.Discharging caps etc....peace and love
  11. #11
    Cheshire, UK
    1,774
    Thumbs Up/Down
    Received: 5/0
    Given: 4/0
    Quote Originally Posted by Stevi q View Post
    I always use the 6.3V heater winding. If it really is 24V:0.6V (40:1) putting 24V on the secondary will put 960V across the primary. That's 1357V peak!
  12. #12
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,068
    Thumbs Up/Down
    Received: 82/1
    Given: 78/4
    Please do not run *24VAC* into the secondary, for the very good reason that with expected 40:1 ratio you will be dealing with electric chair level deadly 1000VAC
    Besides the very dangerous voltage,
    a) the primary is not designed for such a high voltage and
    b) most meters can not even *read* 1000VAC anyway ... and for good reason.
    6VAC into the secondary will instead give you way more reasonable 240VAC at the primary side.
    Guessing what voltage does that transformer expects to handle:
    itīs a 2 x EL84 amp, thus, say, 15W RMS or so.
    W=Vē/Z so
    V=√(W*Z)
    * 15W and 8 ohms give us: 11VAC
    * into 4 ohms: 7.8VAC
    * into 16 ohms: 15.5VAC
    so we see that 6VAC into any normal tap gives us both high resolution (6V compared to 0.6V) and still safe values.
  13. #13
    Aug 2017
    20
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I haven't done it yet .I guess I will just stick with the calculations I got from using the primary to run the volts through.I am gonna find a 9volt and use that just to cross check things .I am a slow learner ,but I will get there .Thanks for the information ,it is greatly appreciated..peace and love .
  14. #14
    Dec 2014
    Derbyshire
    364
    Thumbs Up/Down
    Received: 0/0
    Given: 5/0
    ... .I am gonna find a 9volt and use that just to cross check things . ....
    If you are thinking of a 9V battery it won't work - transformers only work with AC.
  15. #15
    Aug 2017
    20
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Appreciate that.I thing I have a plug that is 9 volts .I think it went to a phone I used to own years ago.I hope that will work .I got a different question .I just received some sprague atom caps .It looks like there is some hard silver material around the lead but on the cap.Not sure if that's damage from a test probe or that's some type of electrolyte leaking out.I will post results a little later .Thank you very much Malcolm.
  16. #16
    Chill-Ville, VA
    2,465
    Thumbs Up/Down
    Received: 18/0
    Given: 42/1
    What Juan said times a bazillion!
    Personally, I am uncomfortable with anything more than my meter will handle, 600V...
    Before positing a theory of how one <could> use a battery to check, I should ask a question... the VERY low resistance of an OT secondary would effectively be the same as shorting out a battery, correct? Which would result in a dead battery very quickly at best and a small fire &/or explosion at worst, correct?
    Asked as someone who burned himself carrying a 9V in his pocket as a kid...
    Justin
    Edit: your 9V phone plug is likely to be DC, also - in which case, it will not work on a transformer - trannies need AC to operate.
    "... If an older Boogie and classic Marshall had a (clearly illegitimate) child and you baked it in an oven set to clown shit crazy." - Chuck H. -
  17. #17
    Jul 2017
    British Columbia
    357
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    There are tube amps, and there are tube amps. My last DIY design uses a 48 V (RMS) Hammond power transformer. Half-wave rectifying that produces about 75 V. My power supply design includes a voltage doubler that produces approximately +150V DC for small-signal pentodes, a voltage tripler that produces about +225V for the little 6AK6 output pentodes, a voltage quadrupler that produces around +300V DC for 12AX7 triodes, and a reverse-polarity voltage doubler fed from the 24 V transformer centre-tap to generate about (-75V DC) for fixed bias experiments.
    For the guitar amp output power levels I can actually use, I don't think I really ever need more than 350V B+. Less, if I take advantage of later generation sweep tubes that can drive lots of current at relatively low B+.
    Music Man amps with their 700-800v B+ ought to be positively frightening.
    To me, they are exactly that - frightening! I am not a certified electrician, and have had no formal training in high voltage safety. IMO it would be foolhardy and irresponsible for me to mess with 800V power - I'm simply not qualified. I hate to quote a violent Clint Eastwood character, but "A man's got to know his limitations!"
    I have been inside my Fender Princeton Reverb, with 440V DC on the output anodes. I wore my Salisbury Class 0 electricians gloves and eye protection for that job. That is probably as high a voltage as I plan to deal with. I'd like the chance to grow old with my wife.
    Those of you who routinely deal with those scary-high voltages have my respect, and my best wishes for your continued safety!
    -Gnobuddy
  18. #18
    Senior Member SoulFetish's Avatar
    Jan 2016
    Massachusetts
    647
    Thumbs Up/Down
    Received: 8/0
    Given: 7/0
    I know it's easy enough to use and 6V or another convenient voltage at an available tap and figure out what the turns ratio is with very little math...
    BUT, how difficult would it be to build a 1V p-p, 50/60Hz(or whatever) oscillator feeding a source follower for driving low impedance windings. It would give you quick, simple, consistent results, and should prevent any unexpected high voltages appearing on windings of unknown transformers. Okay, so you would need a over 1V at the gate for 1V to appear at the source, but you see what I'm getting at.
  19. #19
    Jul 2017
    British Columbia
    357
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by SoulFetish View Post
    Interesting idea, if it's a measurement you do often. It would probably be simplest to use a small, low-power amp IC (or module) to drive the transformer. Run it on a couple of AA cells to keep output voltages nice and low.
    I'm not a big fan of the source-follower idea, because single-ended source followers are better at sourcing current than sinking it, and push-pull source followers have massive crossover distortion until you add sophisticated biasing and lots of negative feedback - at which point you basically have a small power amp!
    But I think Malcolm Irving was entirely right (post #7). Even a cheap DMM can measure small AC voltages quite accurately, as long as you keep the frequency reasonably low (no more than 100 Hz, say.) A dedicated transformer ratio tester may be overkill for most of us.
    -Gnobuddy
  20. #20
    Cheshire, UK
    1,774
    Thumbs Up/Down
    Received: 5/0
    Given: 4/0
    A 600 ohm output sig gen may be enough to drive it. If the OT is unloaded its impedance at 1kHz (say) won't be all that low.
  21. #21
    29,876
    Thumbs Up/Down
    Received: 77/1
    Given: 0/0
    Ever hear a cook tell someone a dull knife is more dangerous than a sharp one? It is true.
    I appreciate the desire for safety, but if I started wearing gloves, I doubt I could hold my meter probes to accurately probe my circuit. Slipping and shorting out a 400v supply will blow up a rectifier as easily as it would on a 600v circuit. Safety is safety, I use teh same skills to avaoid youching 600v that I use to avoid touching 400v, or 150v. I don't like arbitrary limits, as I might convince myself this circuit ONLY has 380v in it so I am safe, while the 450v circuit over there is dangerous. They are all dangerous, the 120v from the wall outlet can kill you. You learn to not stick your fingers on it... or you die anyway.
    Frankly I am more likely to die driving to the grocery store than grabbing B+.
  22. #22
    Jan 2016
    Massachusetts
    647
    Thumbs Up/Down
    Received: 8/0
    Given: 7/0
    Quote Originally Posted by Gnobuddy View Post
    -Gnobuddy
    Yeah, your probably right. An opamp should give me a low enough output impedance anyway. Im not trying to drive a loaded secondary. I was just throwing out ideas. But a small DIY stand-alone module with clip leads would be quick and easy. Actually, if you could combine it with an inductance tester, it would be super handy to get a sense of bandwidth on an output tranny.
  23. #23
    Jun 2006
    California, USA
    3,468
    Thumbs Up/Down
    Received: 14/0
    Given: 13/0
    Quote Originally Posted by Dave H View Post
    That method has always worked fine for me. It does load down the oscillator but you just mesasure the secondary & primary voltages and do the math. No problem.
  24. #24
    Supporting Member
    Staffordshire UK
    3,360
    Thumbs Up/Down
    Received: 7/0
    Given: 12/0
    So as to account for the magnetizing current, Chris Merren advises to use a big test signal, ideally measure it in the amp with a resistive load, see Vintage Amps Bulletin Board ? View topic - Mysterious Marshall JTM45 amp
  25. #25
    Jun 2006
    California, USA
    3,468
    Thumbs Up/Down
    Received: 14/0
    Given: 13/0
    Quote Originally Posted by pdf64 View Post
    That does not make sense to me. I can believe that the power transfer efficiency would be affected during a low level signal test. However, I do not see how the turns ratio measurement, which is what we are discussing, would be significantly affected.
  26. #26
    Lifetime Member
    4,249
    Thumbs Up/Down
    Received: 4/0
    Given: 0/0
    over
    I think maybe we ought to do a sticky that amounts to a mini-course on the simplified model of transformers, and require people to complete it before offering opinions about transformers. A lot of this stuff just falls out with that as background. OK, I'm only half serious.
    The simplified model of transformers has an ideal transformer in the middle. It can transform any frequency at >>exactly<< the turns ratio from primary to secondary. On the primary side, there is a nonlinear resistor, which models the core loss, and which may be ignored for most situations until you're figuring things like insertion loss and heating. There is a primary inductor across the primary, modelling - the primary inductance. This can be linear or non-linear, depending on how persnickety you are being on flux density and such. There are resistors in the primary lead and secondary lead, modeling ... yep, you guessed, wire resistance. If you're playing with high frequencies, you need to include small inductors in series with the primary and/or secondary leads to model leakage inductance. An alternative to the leakage inductor view is to model the ideal transformer with a coupling coefficient, but that's complicated for beginners. That's pretty much it for the simple tests, which, following the 80:20 rule, tell you 80% of everything about the transformer with 20% of the effort. (Note that finding the other 20% of what there is to know takes the second 80% of the effort.)
    If you just want to know the turns ratio or phasing, you do and Open Circuit Test, the capitalization reflecting what the transformer guys think of it, an official test. You put an input on the primary and measure the volts on the secondary, setting this up so that as much of the complications of the nonlinear primary loss, primary inductance, wire resistance and leakage inductance is avoided as is reasonably possible, realizing that it's not perfect, but you might get 95% of your information with 1% of the effort you'd need for fancier tests.
    So - how do you make the leakage inductance, resistances, primary inductance and core losses be as negligible as possible? First those pesky resistances. So don't let currents flow. Leave the secondary open. No current flows in the secondary to muck up your measurements. Some current will flow in the primary, determined by the primary inductance and core losses. That current will drop some voltage through the wire resistance and leakage inductance. To minimize the error, you use a frequency that's high enough to not let much primary current flow through the primary inductance.
    You don't go mucking around with the lowest frequencies you can put through it. You'd like not to have the leakage inductance messing things up, but you can recognize that the leakage inductance is hundreds, if not thousands or tens of thousands of times smaller than the primary inductance in an OT, and ignore it. A frequency that's comfortably larger than the lowest frequency for which the primary is designed is great. A few hundred Hz will really do it up fine.
    Note that if you're after easy and not exact, you can use 60Hz. It's below the nominal frequency of guitars, but most guitar OTs will do OK there. So you're a few percent off - you'll muck up the measurements by that much, so 60Hz is probably OK.
    The voltage needs to be figured in. you want a voltage that's (1) large enough to move the core flux out of the small-loop doldrums, (2) small enough to stay well away from any fold-over from the beginnings of saturation, and (3) easy to measure well with what instruments you have. Working the core flux somewhere in the middle is good. You're part way there by using a frequency that's not rock-bottom. Using a voltage that is, as my grandmother used to say, "middlin" will keep you away from saturation too. Staying away from max flux also cuts the core losses a lot.
    Perhaps the biggest issue is "easy to measure". You can easily muck up the measurements by having to change scale on your meter if it's not well calibrated. And let's face it - none of us ever get our meters calibrated. I don't, and I know the problem. So, pick a voltage that's about mid scale for the low/secondary side, and significantly bigger than the 200mV that's the usual internal range for the circuits inside cheap meters. I like to use a few volts. Gets the measurements up out of the mud. You want the measurement to use at least two and preferably three digits on the meter, as there is >>always<< a +/- one count error on any digital multimeter, no matter how good. Then measure the secondary voltage, change scale, and measure the primary voltage, and do the math.
    Intelligent choices minimize the easiest errors, and get the remaining errors down in the noise. It takes a lot more effort to do a better job.
    Putting a resistor load on the secondary makes things worse if what you're after is the turns ratio. It adds current in the secondary and primary and therefore adds error to the measurements by causing the primary voltage to be the sum of the turns ratio voltage, but dropping that by the primary current times the primary resistance. There's always some error there, but why add to it by deliberately adding secondary loading? There are other tests where secondary loading is needed - notably the Short Circuit Test - but that's not what this question is about.
  1. Hot Deluxe III ? output xmer , reading 79 ohms &103 ohms to center tap. Is it bad???
    By 1ampman in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-01-2017, 04:03 PM
  2. OT inductance and other calculations
    By GainFreak in forum Theory & Design
    Last Post: 02-28-2015, 09:28 AM
  3. How can I find out the output resistance/ohms of my amp? Gibson GA77RET
    By kman007 in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-23-2013, 05:22 AM
  4. Matching speaker Ohms and amp Ohms
    By morbidalex666 in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-18-2009, 08:40 PM
  5. 69 Fender Bandmaster reverb ohms output
    By benindavis in forum Vintage Amps
    Last Post: 08-17-2007, 08:50 AM
