Results 1 to 9 of 9
Thread: Can anyone identify this supposed 1960s resistor between the can capacitors
    Aug 2017
    20
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Between the can capacitors there is a resistor that doesn't look like any other resistor in the whole circuit.Can you tell what type of resistor this is,I am fairly new to all this .Do you know if the old color band codes from the 1960s ,match today's color codes .Green as hell,but I love learning interesting stuff .I would appreciate any info.thank you very much
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	44508   Click image for larger version.
    0 Not allowed! Not allowed!
    Senior Member Malcolm Irving's Avatar
    Dec 2014
    Derbyshire
    364
    Thumbs Up/Down
    Received: 0/0
    Given: 4/0
    Very old resistors have a color code that works in the sequence 'body-tip-spot'.
    Explained here:
    https://www.vintage-radio.com/repair...resistors.html
    Colored bands do work the same as today's.
    Supporting Member
    Dec 2009
    UK
    3,243
    Thumbs Up/Down
    Received: 8/0
    Given: 0/0
    The slightly larger resistor is a ceramic body type - possibly an Erie. The smaller one is a carbon composition.
    Chill-Ville, VA
    2,455
    Thumbs Up/Down
    Received: 11/0
    Given: 25/1
    I'd guess 1k, if I can read the paint correctly... what's it measure?
    Maybe 1W...
    Justin
    "... If an older Boogie and classic Marshall had a (clearly illegitimate) child and you baked it in an oven set to clown shit crazy." - Chuck H. -
    Supporting Member The Dude's Avatar
    May 2010
    Sioux Falls, SD
    5,035
    Thumbs Up/Down
    Received: 13/0
    Given: 7/0
    What amp is it? Maybe there is a schematic available.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
    Feb 2010
    Just south of Bawlmer, Merlin
    2,295
    Thumbs Up/Down
    Received: 13/1
    Given: 17/0
    The smaller carbon resistor is easy: red-red-red = 2.2K +/-20%
    I assume the larger resistor follows the body-tip-spot code that malcolm referenced in post #2.
    On my screen (which has lousy color rendering), I see a red body and a black stripe = two-zero-some number of zeroes.
    Is there a hidden dot somewhere on that resistor?
    -rb
  7. #7
    Senior Member SoulFetish's Avatar
    Jan 2016
    Massachusetts
    641
    Thumbs Up/Down
    Received: 2/0
    Given: 1/0
    no doubt on the 2.2k.
    If it is a Body-tip-spot, it looks to be a 1K. Man, that's tough though. Those colors could have drifted quite a bit (the resistance may have as well!)
  8. #8
    Feb 2010
    2,295
    Thumbs Up/Down
    Received: 13/1
    Given: 17/0
    Hmm, what number is burnt umber?
    -rb
  9. #9
    Jan 2016
    Massachusetts
    641
    Thumbs Up/Down
    Received: 2/0
    Given: 1/0
    Quote Originally Posted by rjb View Post
    -rb
    Bob Ross would know if he were still with us.
  1. Pick up Covers Weren't Supposed to Make Any Difference!
    By old guy in forum Beginner/ Hobbyist
    Last Post: 05-24-2013, 05:36 PM
  2. Tremolo mod on 1960s Ampeg Rocket 2 amp
    By judge734 in forum Mods & Tweaks
    Last Post: 08-16-2012, 10:52 PM
  3. how can I identify these capacitors?
    By dann in forum Music Electronics
    Last Post: 09-30-2010, 10:36 PM
  4. Marshall VS102. Is it supposed to be this loud?
    By allante666 in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-02-2010, 08:44 PM
  5. Identify Vox capacitors?
    By Prairie Dawg in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-25-2009, 07:32 AM
