Results 1 to 13 of 13
Thread: Image attachment problems
    Supporting Member
    Dec 2009
    UK
    3,243
    Thumbs Up/Down
    Received: 8/0
    Given: 0/0
    Just trying to post a couple of 250kb .jpg images. Seems to upload, but only get grey box showing. In the post the preview shows 'Attached Images' but no image.
    File open just fine on my desktop and I can't see anything wrong.
    Any suggestions?
    0 Not allowed! Not allowed!
    Feb 2010
    9,822
    Thumbs Up/Down
    Received: 46/0
    Given: 59/0
    Maybe this is the .jpg variation of the .pdf 'clear gif' issue?
    Were these images posted previous to the big data loss?
    Maybe try adding a dot or line to the images to change their file byte size and see if they work?
    Certified Dotard
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,845
    Thumbs Up/Down
    Received: 51/1
    Given: 0/0
    Did you leave us a link so we can try and see what we get here?
    ANy chance the image files are ones that were posted here in the past?
    Better Tone thru Mathematics bob p's Avatar
    Chicago, USA
    4,908
    Thumbs Up/Down
    Received: 37/0
    Given: 0/0
    I'm not having problems uploading images, but then I haven't tried since yesterday. The board was down with "database issues" today and recently came back up -- maybe there was a maintenance issue that's been fixed now?
    Supporting Member
    Dec 2009
    UK
    3,243
    Thumbs Up/Down
    Received: 8/0
    Given: 0/0
    I'll post them here to see if things have changed since yesterday. Here goes;
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	44551   Click image for larger version.
    Supporting Member
    Dec 2009
    UK
    3,243
    Thumbs Up/Down
    Received: 8/0
    Given: 0/0
    Well, that didn't work but illustrates the problem. These are new images uploaded yesterday and I double-checked to make sure there's no duplicate file name. Will try editing the files as suggested and see if they upload. The problem seems to be when they're uploaded - I don't get the preview in the icon. Maybe re-save them as a .gif.
  7. #7
    Stray Cap DrGonz78's Avatar
    Oct 2011
    Scottsdale, AZ
    1,750
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Yup I just posted an image file on another thread and it worked just fine. Strange indeed.
  8. #8
    Supporting Member
    Dec 2009
    UK
    3,243
    Thumbs Up/Down
    Received: 8/0
    Given: 0/0
    I just opened the images in Picasa and re-saved them under a different filename and those have uploaded and posted in a different thread just fine. I'll put it down to 'one of those things....'
  9. #9
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,040
    Thumbs Up/Down
    Received: 47/0
    Given: 54/2
    I *think* that if such a filename and probably image size had been stored previously to the Great Tsunami, data itself is lost or heavily corrupted, but half brain dead server doggedly thinks "I already have that one, so donīt bother me with a duplicate" or something similar.
    Just thinking aloud, of course, no proof either way.
  10. #10
    Supporting Member
    Dec 2009
    UK
    3,243
    Thumbs Up/Down
    Received: 8/0
    Given: 0/0
    Good point - I though I'd posted those images a quite few years ago but couldn't see them in my gallery. It's certainly looks like a problem with those two specific files and nothing else.
  11. #11
    Feb 2010
    9,822
    Thumbs Up/Down
    Received: 46/0
    Given: 59/0
    The forum seems to look at the suffix (filetype) and byte size. (example, .jpg 1527 bytes) If the file was previously posted and got sucked in during that black hole event, the forum will not accept it as is.
    Changing the filename does not help. Altering the byte size or zipping the file works.
    Zipping the file is the simplest solution.
    To alter the byte size, for pdfs you can re-save from your adobe viewer, for jpgs you can just add a dot or something using paint or similar, and save the change.
    Certified Dotard
  12. #12
    "Thermionic Apocalypse" -JT nickb's Avatar
    Dec 2009
    Devon, UK
    2,750
    Thumbs Up/Down
    Received: 9/0
    Given: 6/0
    Quote Originally Posted by g1 View Post
    I suspect, or a least hope, it's a tad more sophisticated than that. I expect it does a checksum of some kind as well and uses that to confirm a match.
  13. #13
    Jun 2006
    California, USA
    3,467
    Thumbs Up/Down
    Received: 12/0
    Given: 9/0
    Oh man. Unless you need to make a packged set of files such as a multi sheet schematic lets Please NOT zip the attachments.
  1. Acoustic image shematic
    By miko in forum Schematic Requests
    Last Post: 01-14-2016, 03:01 PM
  2. More fun with scope image interpretation
    By nsubulysses in forum Theory & Design
    Last Post: 09-20-2015, 07:56 AM
  3. Scope image interpretation
    By nsubulysses in forum Music Electronics
    Last Post: 03-18-2015, 04:27 AM
  4. Attachment problems
    By g1 in forum Lobby
    Last Post: 04-23-2013, 02:53 AM
  5. An image from the Forumpocalypse
    By jmaf in forum Lobby
    Last Post: 05-02-2011, 01:54 AM
