Results 1 to 5 of 5
Thread: Maxon AD900 no effect
    Supporting Member
    Apr 2009
    NY, NY
    1,142
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    This AD900 is the mn3008 model. I've been tracing a signal through the circuit and I found it stops at IC3 and goes no further.
    Does this mean IC3 is the culprit or does it mean IC5 or IC8 are bad?
    I don't hear any signs of delay effect with the signal tracer
    Any thoughts?
    thank you in advance!
    pete
    Attached Files Attached Files
    0 Not allowed! Not allowed!
    Dec 2009
    Canada
    134
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    Check that you have 10-12v on IC3 pin 8 and a high frequency square wave on pins 2 and 6.
    If so, the bias trimmer might be off. Clip the scope probe to CP1 and adjust TR2. At some point
    you should see a signal. Otherwise the chip is probably dead. Swap it with one of the others.
    The balance trimmers TR3,TR5,TR8,TR10 should be centered but don't touch them yet.
    Supporting Member
    Apr 2009
    NY, NY
    1,142
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thanks for help dmeek. Pin 2 and 6 don't seem to have a signal. So l clipped probe to CP1 and turned SR2, nothing there.
    Switched IC3 with IC 7 still no signal.
    There's about 11v(give or take a volt) on pin 1,2,3, 4 , 6 and 8.
    Dec 2009
    Canada
    134
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    You need to have a square wave on both pins 2 and 6. Don't touch any other trimmers, the problem is with the clock oscillator.
    check for a square wave (~20-50 kHz) at IC8 pin 7. If nothing there look around the oscillator circuit and delay pot.
    C25,C26 or D4 could be shorted, or a bad delay pot, Possibly IC5 or IC8 could be bad.
    After you get the oscillator working go back and adjust TR2. Don't touch any other trimmers.
    Also, after you swap any ICs, put them back in their original positions.
    Supporting Member
    Apr 2009
    NY, NY
    1,142
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Checked C25 & 26 and D4 for shorts, all looked good, with 8v at the zener diode. No square wave on IC8 pin 7, so I changed out IC 5 & 8 and we have effect!!
    Swapped IC3 back with IC7 and adjusted SR1(trimpot 1) and SR2 by hear and sounds great.
    Thanks dmeek so much for your help!
    pete
  1. Maxon OD820 voltage conversion question
    By ninjadave7 in forum Music Electronics
    Last Post: 03-13-2012, 09:29 PM
  2. Maxon OD820 hiss
    Last Post: 02-14-2012, 05:53 PM
  3. Problem WIth Maxon AD-999
    By Bluefinger in forum Guitar Effects
    Last Post: 04-08-2010, 03:58 PM
  4. Ibanez-maxon pue5
    By GonzaloCobo in forum Guitar Effects
    Last Post: 11-23-2008, 05:08 PM
  5. Anyone Have A Maxon OD-9 Schematic?
    By turbolx5oh in forum Guitar Effects
    Last Post: 01-15-2008, 09:52 PM
