Results 1 to 32 of 32
Thread: Weird Capacitors! Need help determining replacement value
    Aug 2011
    163
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    So I've never seen capacitors like this before, in fact I'm not even 100% sure they ARE caps. They're referenced as C on the circuit board along with some other known capacitors though, so I'm to believe they are capacitors. Unfortunately none of them measure any capacitance on my multimeter and I can't understand the markings to determine replacement values. I also can't find a schematic for this amp (Carlsboro solid state amp).
    Here's a picture:
    The values written on the capacitors are like "100 MN". Any ideas?
    0 Not allowed! Not allowed!
    Supporting Member mozz's Avatar
    Oct 2015
    NEPA
    512
    Thumbs Up/Down
    Received: 6/0
    Given: 5/0
    Do they measure any resistance? Model number? Problem you are encountering? If they are caps, I can't believe that many would be open, test known good caps with your meter, start at 100pf.
    Aug 2011
    163
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by mozz View Post
    Known good caps measure accurately. These mystery "Caps" all measure OPEN for resistance. This amplifier was making a lot of noise (windy, popping, etc..) and I replaced all of the electrolytic capacitors - it's quieted down but I'm still getting some Popping. The popping isn't affected by the channel volumes or tone controls, but it does go away when the Master vol is turned down.
    Dec 2008
    Wernersville, PA
    12,207
    Thumbs Up/Down
    Received: 5/0
    Given: 4/0
    Measuring a small value capacitor with your meter set to read resistance is pointless.
    Most caps will read open circuit.
    Electrolytic caps will show a reading as the meter voltage charges them up but this is not a valid test of the cap.
    If nothing else, go out and purchase a cheap meter that has a capacitance tester.
    Supporting Member
    Staffordshire UK
    3,360
    Thumbs Up/Down
    Received: 7/0
    Given: 12/0
    I recognise those as caps, though can't recall the technology.
    The numbers are probably their value in pF
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,876
    Thumbs Up/Down
    Received: 77/1
    Given: 0/0
    They look like common ceramic caps to me. Common in a previous era, yes, but tube TV sets would be full of them. Numbers ought to be cap value in picofards.
  7. #7
    Aug 2011
    163
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by Jazz P Bass View Post
    Hey JPB, I was measuring them in the capacitance setting but was responding to mozz who asked what they measured in resistance (presumably to see if they're something other than capacitors).
  8. #8
    Oct 2015
    NEPA
    512
    Thumbs Up/Down
    Received: 6/0
    Given: 5/0
    I just mentioned resistance because he wasn't 100% sure they were actually a cap. If they are pf caps, why no meter reading? M could be tolerance 20% and then N stands for nano? Still doesn't answer why would they all be open. How old of a solid state amp? 1965? 1985?
    Here are some tube schematics, other page shows some of those caps even on the tube amp models, schematics call them 3kpf, 47kpf.
    Carlsbro Amplifier Vintage Wiring Diagrams
    Servicing a Carlsbro CS100 Reverb PA Amplifier
  9. #9
    Aug 2017
    Portland, OR
    273
    Thumbs Up/Down
    Received: 7/1
    Given: 10/1
    Wonder if MN is milli-nano, which would be pico
  10. #10
    Feb 2010
    Just south of Bawlmer, Merlin
    2,315
    Thumbs Up/Down
    Received: 37/1
    Given: 28/0
    Quote Originally Posted by glebert View Post
    Unless kpf is kilo-picofarad, which would be nanofarad.
  11. #11
    Feb 2010
    9,838
    Thumbs Up/Down
    Received: 62/0
    Given: 102/0
    Does your meter cap setting normally measure down to small values like 50pF ?
    Certified Dotard
  12. #12
    29,876
    Thumbs Up/Down
    Received: 77/1
    Given: 0/0
    milli-nano??? Now I have heard everything.
  13. #13
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,068
    Thumbs Up/Down
    Received: 82/1
    Given: 78/4
    No Sir, you still need to listen to milli-vanilli
    enjoy specially from 0:52 on
  14. #14
    Chill-Ville, VA
    2,465
    Thumbs Up/Down
    Received: 18/0
    Given: 42/1
    MV... great, now my Master Volume knobs on my amps (built or bought) will be called the "Milli-Vanilli" knob. Because Milli-Vanilli and Master Volumes are equally criminal inventions foisted upon the world.
    Juan, that was as horrible as it was 30 years ago when I had to hear it on the school bus. A pox on you for posting that! T-Boy, where's that "HULK SMASH!" button?
    Justin
    "... If an older Boogie and classic Marshall had a (clearly illegitimate) child and you baked it in an oven set to clown shit crazy." - Chuck H. -
  15. #15
    Oct 2007
    10,068
    Thumbs Up/Down
    Received: 82/1
    Given: 78/4
    Ok, hereīs the antibiotics to cure that ear infection
  16. #16
    Senior Member SoulFetish's Avatar
    Jan 2016
    Massachusetts
    647
    Thumbs Up/Down
    Received: 8/0
    Given: 7/0
    Quote Originally Posted by waspclothes View Post
    Most multimeters won't give you any accuracy at all under maybe a few hundred pf of capacitance. I think there are many techs who would argue that testing capacitance on almost all multimeters to be a convenient approximation at best, and any reliable reading should be done on a calibrated instrument (and probably at the high end of its voltage rating).
    edit: I think these are vintage "dogbone" temperature compensating type ceramic capacitors. "MN" might be the tolerance or something.
  17. #17
    Jun 2006
    California, USA
    3,468
    Thumbs Up/Down
    Received: 14/0
    Given: 13/0
    I'm wondering, during this whole thread, why all those parts were removed in the first place. I.e what troubleshooting pointed to them as "bad?"
  18. #18
    Senior Member Pedro Vecino's Avatar
    Jul 2006
    Spain
    485
    Thumbs Up/Down
    Received: 1/0
    Given: 1/0
    Ceramic tubular capacitors. Measurements are usually in picofarads, from a few to 5000. Itīs very difficult to find them damaged.
  19. #19
    Oct 2007
    10,068
    Thumbs Up/Down
    Received: 82/1
    Given: 78/4
    Yes, they very much look like old style (say the 50`s, 60īs) ceramic caps.
    If some factory was already set up to make them that way, they would keep doing so until dies or machines broke or wore off, they would be well amortized anyway.
    Any new production line would be set up to make them the modern way, of course.
    I read them as small value ceramics, visible value being from 33pF to 100pF, *very* hard to read on a multimeter since probably cable and test leads would already show more than 100pF.
    And if user is holding probes with his hands, forget about it.
    A proper LCR meter would have them attached to some terminals, no human hands nearby, and even so might show "parasitic" 10 to 50 pF, which would have to be substracted from displayed measurement
    I have this very same model, faithfully working since the late 70īs:
    I think the caps shown are ceramics, value in pF is the printed number, and MN either shows voltage and tolerance or temperature coefficient or is plain brand indicator (Minnesota Capacitors anybody? )
  20. #20
    "Thermionic Apocalypse" -JT nickb's Avatar
    Dec 2009
    Devon, UK
    2,755
    Thumbs Up/Down
    Received: 16/0
    Given: 6/0
    Quote Originally Posted by Tom Phillips View Post
    Me too! I would list bad semiconductors, electrolytics, then resistors as noise suspects in that order for a SS amp. Little caps like those would be last.
  21. #21
    Oct 2007
    10,068
    Thumbs Up/Down
    Received: 82/1
    Given: 78/4
    Agree.
    Ceramic tubular capacitors, number is capacitance in pF, no need to stablish units, MN may be voltage and tolerance or temperature coefficient code, donīt expect any mystery data.
    Or even plain Brand label.
    They should never have been pulled, shotgunning is a terrible repair technique and in any case they would never cause noise as described, which is way more possible coming from bad active components, in general ICs or transistors.
  22. #22
    Jan 2016
    Massachusetts
    647
    Thumbs Up/Down
    Received: 8/0
    Given: 7/0
    Quote Originally Posted by J M Fahey View Post
    That LCR meter is a sweet unit, Fahey! I want one of those. I admit, I have a little bit of gear envy.
    (But how obnoxious is it the i look over and see the "range multiplier" switches and think "Ew! I would have to do it?" #spoiledbyautorange)
  23. #23
    Better Tone thru Mathematics bob p's Avatar
    Chicago, USA
    4,908
    Thumbs Up/Down
    Received: 37/0
    Given: 0/0
    I have one of these. current production, easy to find.
    https://www.bkprecision.com/products...-with-esr.html
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  24. #24
    Aug 2011
    163
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Agree.
    Hi JMF, point taken. I thought the shotgun replacing of the mystery capacitors would be a quick experiment before I go to replacing transistors and then IC's. I thought I was onto something when they wouldn't measure any capacitance with my multimeter (and a known .1uF cap measured fine). The transistors in this are unlabelled and I can't find a schematic, so I'm not sure how to approach that problem.
  25. #25
    Jun 2006
    California, USA
    3,468
    Thumbs Up/Down
    Received: 14/0
    Given: 13/0
    Hi JMF, point taken. I thought the shotgun replacing of the mystery capacitors would be a quick experiment before I go to replacing transistors and then IC's...
    The usual troubleshooting technique is to isolate the problem to a certain area of the circuit. Granted, that is hard to do if you don't have a schematic and are not familiar with the circuit in your amp. In post number 1 you said the equipment was a Carlsboro solid state amp. I suggest that we start by getting the complete model number and photos of the amp so the group can try to find a schematic.
    Once we know more about the circuit then we can do troubleshooting to determining if various controls affect the noises. In addition, we can do various simple things to interrupt the signal path and/or dump the signal to ground with a temporary capacitor in certain places in the circuit and observe how that affects the noises. (Caution: Don't try this until you really understand the technique) Other things are thumping, poking & prodding, freeze spray, heat gun, pot, switch & connection cleaning and detailed visual inspection. The goal is to narrow down the section of the circuit where the noise is originating and all this comes before shotgun parts replacement.
    Cheers,
    Tom
  26. #26
    Oct 2007
    10,068
    Thumbs Up/Down
    Received: 82/1
    Given: 78/4
    Excellent advice and the way to go.
    So far we know nothing, "Carlsbro SS amplifier" covers way too much, we need some focusing.
    Post model, whatever is written on the backpanel, plus some pictures:
    front and back panels, then pull chassis out and post preamp and poweramp pictures ... weīll then ask for more
    After we get some idea of what you have, weīll suggest some tests.
    I seem to have read no controls affect noise except Master Volume?
    If so, you need to detect which is the last active section , based maybe on an Op Amp or perhaps a couple transistors, which feeds/drives that MV, I guess we wonīt be far from the suspect.
    Problem is Carlsbro was actually a very popular, widely sold and available British brand (I saw them all over the place in UK in ī86, way more than Laney, Marshall or Vox, go figure) , but since "nobody famous" used them, they are ignored today.
    HH was more famous, but also disappeared, was absorbed by Laney; another popular but obscure brand was Torque.
    Sadly Music pages, IF they remember them somewhat, that applies only to Tube circuits, but never SS.
  27. #27
    Feb 2010
    9,838
    Thumbs Up/Down
    Received: 62/0
    Given: 102/0
    This is what I was getting at. A .1uF is 100,000pF. You are trying to measure caps in the vicinity of what we think is 50pF. A lot of multi-meters with capacitance functions will not measure caps of such a low value.
    I would guess that when you measure them, you get the same reading as when the probes are open and not touching anything.
    If you were comparing to a known good 50pF cap, and the meter measured one but not the other, then you could suspect the cap.
    Out of curiosity, what is the make and model of your meter?
    Certified Dotard
  28. #28
    Jul 2017
    British Columbia
    357
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by Pedro Vecino View Post
    I remember those! Thin-walled, hollow, ceramic tubes, metallized on the inside and outside of the tube.
    This thread is giving me flashbacks to my childhood. I started tinkering with electronics when I was about 8 years old, and saw a few of these ceramic tubular capacitors (pulled from dead electronics that was already old then) during my first few years in the hobby. I haven't seen any of them in a very long time, though.
    -Gnobuddy
  29. #29
    Aug 2011
    163
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Agree.
    Just a quick update. I replaced all of the LM741 and CA741 op-amps and the noise is gone. Thanks everyone for their patience on this.
  30. #30
    Oct 2007
    10,068
    Thumbs Up/Down
    Received: 82/1
    Given: 78/4
    Glad to know
  31. #31
    Aug 2011
    163
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Glad to know
    It's news to me that opamps can become noisy like that. Intermittent crackly noise, but still functioning. Anyone know why that happens to them and what causes it?
  32. #32
    29,876
    Thumbs Up/Down
    Received: 77/1
    Given: 0/0
    Semiconductors are way more likely to go noisy than caps or resistors.
    If you are looking for a "cause", you likely will never find it. If you think it will be a "I did this, so that happened...", you will be disappointed. It rarely will be anything you "did". Playing real loud into it, or turning up your fuzz pedal will not affect the amp.
    On the other hand, even when you cannot feel it, there is static electric charge on everything. it is possible at some point you plugged a guitar into the amp and a static discharge went through things and damaged a semi junction. Didn't kill it, just damaged it. Like stepping on a ladder rung and cracking it, but not all the way through. The six months later, it finally goes. Now you have no way to know what happened.
    But within the IC, a defect or weak spot in the silicon could result in noise.
    Failures elsewhere could afffect them. If for example you are running 15v rails, and a power supply fault puts 25v on the op amp, that can damage it. And again, it might not show up immediately.
  1. Fender Red Kbob twin replacement capacitors and upgrades
    By jalexquijano in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-29-2017, 07:21 PM
  2. Weird, Weird stuff with the PT of a Twin, Secondary Voltage.
    By wizard333 in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-11-2013, 07:58 AM
  3. determining wattage
    By blueguitar in forum Theory & Design
    Last Post: 06-24-2012, 03:31 AM
  4. Help determining output impedance.
    By DLNB in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-06-2011, 06:46 PM
  5. Can anyone please reccommend replacement capacitors?
    By jakobsongs in forum Music Electronics
    Last Post: 05-18-2010, 07:37 PM
