Results 1 to 17 of 17
Thread: EVH 5150 MK3 mini head reducing the gain
    Sep 2012
    Poole UK
    576
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hi
    I had a customer see me with this Mini head and he want to reduce the noise and gain
    He is a heavy metal player.
    I did say that the head is what it is and with 4 pre amp tubes with one channel + a crunch he is better off using it or selling it, But he want to keep it.
    Ive played around with tubes changing for 5751 and 12au7 etc but this does not please him
    Any guys out there tried a few mods and worked
    BBB
    0 Not allowed! Not allowed!
    Dec 2008
    Wernersville, PA
    12,200
    Thumbs Up/Down
    Received: 3/0
    Given: 4/0
    Is the amp model an MKIII or an LBXII?
    Sep 2012
    Poole UK
    576
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    its a fender made Mk111 type PR3736
    Dec 2008
    Wernersville, PA
    12,200
    Thumbs Up/Down
    Received: 3/0
    Given: 4/0
    Never heard of it. (PR3736)
    The MKIII came in a 50 & a 100 watt version.
    Sep 2012
    Poole UK
    576
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    It does say mk3 on it but it's a 15 watt version with el84 will put up a picture tomorrow. The pr3736 is on the bottom I've never seen them before
    Feb 2010
    9,822
    Thumbs Up/Down
    Received: 46/0
    Given: 59/0
    I think that would be the 5150 III LBX (lunchbox)
    Schematic:
    Attached Files Attached Files
    Certified Dotard
  7. #7
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,845
    Thumbs Up/Down
    Received: 51/1
    Given: 0/0
    Sounds like the LBX to me.
  8. #8
    Dec 2008
    Wernersville, PA
    12,200
    Thumbs Up/Down
    Received: 3/0
    Given: 4/0
  9. #9
    Sep 2012
    Poole UK
    576
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thank guys for that .. as this amp does not say LBX on it a didn't know what it was as ive never seen them before . It is what you lot say it is.
    Now Modding is not my strong point. The owner uses it with the crunch button in. He want to reduce the gain and get rid some of the hiss.
    BBB
  10. #10
    Dec 2008
    Wernersville, PA
    12,200
    Thumbs Up/Down
    Received: 3/0
    Given: 4/0
    That would be V3, the 'Red' channel.
    I don't see any controls on that circuit.
    It's pretty much 'balls to the wall'.
    I would scope it to try to see what the guys gripe is.
  11. #11
    Sep 2012
    Poole UK
    576
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thanks jazz bass. I'll have a check with him what he wants. Sometimes these sort of customers are just not worth the hassle on jobs like this.
    Bbb
  12. #12
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,040
    Thumbs Up/Down
    Received: 47/0
    Given: 54/2
    IF its the first circuit posted, I can suggest a few attenuators , just a single extra resistor each, you tack solder them one by one until hes happy.
    Each should take about 10/12dB (back of the envelope calculations)
    * 220k from junction (Net) R69 - V1a2 (pin 2 - grid) to ground. As near as possible, preferrably to far end of C67 or R96 to avoid ground loops.
    * 150k or 220k in parallel with R88 (820k)
    * 100k from Net R72-V2b7 (grid) to ground. Preferrably grounded end of C66 or R95
    These should be more than enough, wed be knocking over 30 dB gain (and noise) , in fact probably 1 or 2 will be enough.
    Way better and more predictable than tube swapping and keeps original bias at each stage.
    You ***miiiiight*** add small toggle switches, similar to pickup phase or coil splitting ones for each attenuator (use twisted cable inside or shielded wire, those grids are sensitive) to let owner mix and match at will ... but that doubles job price, you are *redesigning* his amp, way beyond plain modding. Your choice.
    I would leave the Red channel, around V3a-b untouched, even with a tamer amp hell still need to get the fury back for solos and such. In any case that distortion will be somewhat tamer because you will not hit it that hard from the preamp.
    Test them and post results, but always with customer side by side and with his approval, so later he does not get cold feet and accuses you of messing with his amp or something.
  13. #13
    Sep 2012
    Poole UK
    576
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thank you Juan manuel fahay. I'll contact the customer and let him know. Bbb
  14. #14
    Apr 2015
    93
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    There's the gain knob, that does actually turn counterclockwise too.
  15. #15
    Sep 2012
    Poole UK
    576
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Just to let you know ive have done the mods below and it seems to work well. massive reduction in the hiss.
    I'm letting the customer try it and let him make that decision
    " 220k from junction (Net) R69 - V1a2 (pin 2 - grid) "
    " 100k from Net R72-V2b7 (grid) to ground. Preferably grounded end of C66 or R95 "
    bbb
  16. #16
    Sep 2012
    Poole UK
    576
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Damn i forgot to check that.
  17. #17
    Jun 2006
    271
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by darkfenriz View Post
    There's a 1000p bright cap on the gain pot. Turning it down more than a fraction below max will most likely result in extremely thin, harsh and unusable tones.
    I just can't figure out why amp designers insist on stupidly big bright caps. It more ore less forces the player to turn up the gain until the cap is effectively out of the circuit. You might as well skip the gain pot...
  1. EVH 5150 iii Schematics
    By scoden in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-12-2018, 11:34 PM
  2. Peavey 5150 head - Post gain controls not working normal
    By 1ampman in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-01-2012, 01:34 AM
  3. Peavey 5150 EVH head... Reinstalling the output tube circuit board???
    Last Post: 05-13-2012, 06:05 PM
  4. 5150 Head post gain volume has no effect
    By samino in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-03-2010, 12:42 AM
  5. Fenders new EVH 5150 amp
    By Slobrain in forum Guitar Amps
    Last Post: 07-27-2007, 04:41 PM
