Results 1 to 13 of 13
Thread: Seeking Advice: Ampeg V-4B PCB Trace Liifting
    May 2011
    Out West, Canada
    169
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hi folks I own a 1972 Ampeg V-4B tube Bass Amp. I recently completed a cap job. While in the amp I noticed that a PCB trace from Input 1, to PCB board is lifting. The connection is seen in the centre of the pic here. The wire wrapped in white/clear covering. It attaches to the board as seen, and then the trace travels over to V1, pin 7.
    The connection seems to still work fine, however I am thinking it may get worse in time. Should I consider repairing this PCB trace? I have never done this type of work before on a PCB.
    I was thinking I could maybe also lift the wire and directly solder it to the V1 socket connection at pin 7.
    Your comments are appreciated.
    0 Not allowed! Not allowed!
    Stray Cap DrGonz78's Avatar
    Oct 2011
    Scottsdale, AZ
    1,757
    Thumbs Up/Down
    Received: 6/0
    Given: 8/0
    Quote Originally Posted by keithb7 View Post
    I have only fixed a lifted pad on a circuit board once successfully using epoxy and it was a pain in the ass (never tried again). Your idea to solder it straight to pin 7 seems like a good one to me. Also, there is that unused connection between the two points...? Cut the trace on that unused pad's connection and solder a bridge from that new one to the pin 7 connection.
Name:	Screenshot from 2017-09-13 13:41:42.png
    Aug 2017
    Portland, OR
    300
    Thumbs Up/Down
    Received: 14/1
    Given: 20/1
    Quote Originally Posted by DrGonz78 View Post
    Isn't that a pad for R4? Also, is it just me or does the solder on the right end of C2 look a bit suspect?
    Oct 2011
    Scottsdale, AZ
    1,757
    Thumbs Up/Down
    Received: 6/0
    Given: 8/0
    Quote Originally Posted by glebert View Post
    Yeah it does connect to R4 but to me it appears that R4 is missing anyway. Disregard my idea if R4 is connected or has double sided connection point. Yeah there is too much solder on that C2 connection point.
    Supporting Member The Dude's Avatar
    May 2010
    Sioux Falls, SD
    5,165
    Thumbs Up/Down
    Received: 131/0
    Given: 111/0
    I like the idea of soldering directly to the tube pin. My $.02.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
    Feb 2010
    9,939
    Thumbs Up/Down
    Received: 141/0
    Given: 308/0
    Is that R1 spot loaded? If so, you must maintain that connection to pin7. There must be some grid leak resistor either there or at the jack?
    Do you have an accurate schematic for this particular board version? The '71 schematic calls the grid leak R2, not R1.
    The voices in my head are idiots!
  7. #7
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    4,951
    Thumbs Up/Down
    Received: 107/0
    Given: 65/0
    Another vote for direct connexion to tube socket pad.
  8. #8
    Feb 2010
    9,939
    Thumbs Up/Down
    Received: 141/0
    Given: 308/0
    Never mind (post #6), R2 must be at the jack. The same board is used in the V4, where R1 and R4 are in use.
    You can move the wire right to pin 7, as others have mentioned.
    But you should also address the reason this occurred in the first place, lack of strain relief where the wire meets the board.
  9. #9
    May 2011
    Out West, Canada
    169
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Sorry I should have mentioned the board does appear to be shared with the v-4 guitar amp. Mine is the V-4B.
    Here is an accurate schematic for my amp. I will consider attempting to wire directly to the socket pin 7, and support the wire with some type of anchor.
    I see R2 in the schematic is tied to V1 pin 7 as well. I can't see an R2 anywhere on my board.
    Thanks, Keith
  10. #10
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,175
    Thumbs Up/Down
    Received: 269/1
    Given: 0/0
    I wouldn't hesitate to solder the wire direct to the tube socket pin.
  11. #11
    Old Timer olddawg's Avatar
    Dec 2007
    Carlsbad, CA and Kona, HI
    2,639
    Thumbs Up/Down
    Received: 26/0
    Given: 0/0
    Usually I just scrape a lifting trace clean with a fiberglass pen and solder a length of stripped of appropriate sized copper solid core wire over it with a little flux and clean it up with alcohol. If I want to make it pretty I brush on a little clear lacquer. If it's a big trace I use braid.
  12. #12
    Feb 2010
    9,939
    Thumbs Up/Down
    Received: 141/0
    Given: 308/0
    I think R2 (and R8 for ch.2) are probably mounted at the input jacks?
    What did you use to replace C18,19, & 20, all discrete caps?
    Just a warning that C19 & 20 have their negative terminals at over 250VDC, so you don't want any caps that tie their negative to the shell there (shock hazard for wandering hands).
    Attached is the service manual (excluding schematic) in case you don't have it.
    Attached Files Attached Files
  13. #13
    Oct 2015
    153
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    check the pads for the screen resistors also
  1. Replies: 15
    Last Post: 08-03-2015, 06:55 PM
  2. PCB Trace width on Power Circuits in Ampeg SVT VR & CL amps
    By nevetslab in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-18-2014, 02:12 PM
  3. PCB Trace Repairs
    By Phostenix in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-28-2009, 03:28 AM
  4. Blown trace on PCB
    By WholeToneMusic in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-19-2009, 02:05 AM
  5. V-4B Ultra Lo switch
    By Dave M in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-07-2006, 01:12 AM
