| | #1 |
| Junior Member Join Date: Aug 2006
| Hi ! I need the schematic and layout diagram for a Roland Jazz Chorus model JC120 Serial number 451,181 manufactured by Roland (early 1978 model) with the TO3 output transistors. (3 boards: CH1, CH2 with dist, section and Chorus board) Hi have a distortion problem on CH2. Channel 1 is OK. It's a strange problem. I checked all transistors (2SA493, 2SC1628, Q22, 2SC1624, 2SSA814, diodes and 1S1555 diode ----> are goods). As soon as the speaker is connected (ch 2) ... the distortion appears ... when speaker is disconnected ... the distortion dissappear ... Can you help me http://music-electronics-forum.com/i...s/confused.gif ![]() THANKS !!! Mike Amptek cablespec@3web.net |
| | #2 |
| Member Join Date: Jul 2006
Mike here is three diferent schematics for JC120. once is your. cheers vintagekiki |
| | #3 |
If the output waveform looks OK without a load but collapses with a load, look to the output stage not being able to supply enough current. make sure none of the ballast resistors - "emitter resistors" - are open, remove the outputs and test them out of circuit. Note which side of waveform is collapsing.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Roland jc-120 | Mikelib | Maintenance, Troubleshooting & Repair | 10 | 02-18-2009 06:11 PM |
| Roland JC120 knobs | David B | Vintage Amps | 6 | 01-01-2008 04:13 PM |
| roland kc-500 amp repair | 54bassman54 | Maintenance, Troubleshooting & Repair | 2 | 05-22-2007 10:41 PM |
| Roland Boss MG-80 | Euthymia | Maintenance, Troubleshooting & Repair | 0 | 02-28-2007 11:21 PM |
| Roland JC120 hum | KarbonHed | Maintenance, Troubleshooting & Repair | 3 | 10-31-2006 05:28 PM |
