Results 1 to 3 of 3
Thread: Is it just me, or have major manufacturers gotten this wrong for decades?
    Mar 2010
    477
    Folks -
    Haven't been doing repairs for awhile but I was reminded recently that I used to think that a simple change to the wiring layout of tone control circuits had a real advantage.
    Especially in F-hole-type instruments, insuring that one leg of the tone cap was grounded seemed to reduce buzz levels dramatically. In fact, this tweak, IIRC, makes a more-than-significant improvement in any "normal" hi-z harness that's not fully shielded, as is almost always the case with 175's, 335's, etc.
    Seems to me that the cap has been strung from pot to pot for a very long time, and therefore placed in the alternate series position, in which it can serve as an excellent noise injector.
    Anyone else ever noticed this?
    'Course, we were all taught that the positions of two series wired components can be swapped with no effect on their function.
    I must say that since I bought a copy of "Grounding and Shielding" as prescribed by Salversan, this concept that significant properties of a circuit are not represented on its schematic has been most helpful.
    Bob Palmieri
    Senior Member jack briggs's Avatar
    Oct 2007
    Raleigh
    252
    Quote Originally Posted by fieldwrangler View Post
    Folks -
    Bob Palmieri
    Bob - I haven't noticed any difference between the series method and grounding one leg of the cap in noise levels. Every 335 type from Gibson I have worked on had shielded wire throughout the harness. Maybe some lower models or Norlin era models had unshielded wire in them, but I've never encountered it. My $0.02
    cheers,
    Mar 2010
    477
    Quote Originally Posted by jack briggs View Post
    cheers,
    Thanks for this. In fact, it's the shielded wire that leaves this element sticking out as a potential culprit due to its exposed position and direct connection to the pickups' output.
    I'd certainly like to just do the obvious thing and set up one pickup's controls one way and one the other on a typical 2 pickup-4 control guitar but my own axes are so well shielded at the controls' periphery that I doubt it would make any difference.
    Two cents most appreciated.
  1. Question for those who have stared at a scope screen for decades
    By nsubulysses in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-03-2014, 07:42 PM
  2. Major goof, major problem OT
    By captntasty in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-23-2011, 04:41 PM
  3. diode manufacturers?
    By mike_mccue in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-22-2009, 12:19 PM
  4. Best/worst large manufacturers?
    By Euthymia in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-14-2007, 05:36 AM
  5. Baseplate Manufacturers?
    By Edward R in forum Pickup Makers
    Last Post: 12-27-2006, 06:27 PM
