Results 1 to 10 of 10
Like Tree3Likes
  • 2 Post By daz
  • 1 Post By Enzo
Thread: pot taper question
    daz
    daz is offline
    Old Timer daz's Avatar
    Jan 2007
    2,518
    pot taper question
    It doesn't make sense to me that this would be possible, but i'm gonna ask anyways. It it possible that pot taper could cause a strats tone to become dull and lifeless when you roll it down to clean up, EVEN WITH a treble bleed cap? Doesn't make sense to me that a odd pot taper could cause that, but i have a classic vibe strat with tonerider pickups (which a lot of people seem to like even tho they are cheap) and after trying several treble bleed caps and unhooking the tone controls, turning the volume down to get the chimey cleans i normally get with all my other guitars yields a dark muddy tone like theres no bleed cap at all. The pot measures a bit lower than 250k but nothing abnormal. And with nothing in the signal chain within the guitar now other then the volume pot, switch and pickups i'm going to guess it must be the pickups. I's swap out the pot but i don't have any 250's on hand.
    I oaded a guard with known good pickups into it to test it and the tone was lovely. So theres the question....could pot taper be the cause?
    May 2007
    pacific north west
    12,244
    The straight answer is no. The pot taper will only affect knob setting, not tone in any way with all other things being equal. That is, same bright circuit, pickups, tone pot/cap value, etc. Which means all other things aren't equal. Now you get to find out what. I'll guess it's the pickups may be somehow different than typical and their particular resonant properties aren't playing nice with the 250k pot value. I might try changing to 500k pots and half the value of the tone cap and your usual bright cap.
    "So I acquired it for the purpose of fixing it up - in case I run out of things to do with the rest of my life..." tubeswell
    "Shut up, you big dumb poopy-head!" Justin Thomas
    daz
    daz is offline
    Jan 2007
    2,518
    I didn't think so, but turns out i just spaced and connected the bleed cap wrong. I've probably installed them 300 times in my life and i either spaced or at my age i may have alzheimers. Doh. This drove me nuts till i pictured what i had done when iside and it seemed like i recalled connecting one leg to the ground lug instead of the input lug, and sure enough that was it. No wonder the thing sounded so fat with single coils when on 10 !
    pdf64 and Chuck H like this.
    May 2007
    pacific north west
    12,244
    It probably hasn't been a year since the last time I soldered a cable jack without putting the sleeve on first You'd think that mistake would stick!?! "It" happens.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    28,916
    One good side of retiring, I likely will never make those mistakes again. Again being the operative word.
    We all do it.
    J M Fahey likes this.
    Supporting Member
    Dec 2009
    UK
    2,974
    Don't be too sure; I hear that in the Afterlife your daily existence for an eternity consists of repeating all the mistakes you made in life.
    You can avoid this by sending $10 to the Reverend Mick.
  7. #7
    28,916
    Oh thank you. I will send that right along just as soon as I get to the afterlife.
  8. #8
    Supporting Member
    Dec 2009
    UK
    2,974
    Shit. I just read this with a mouthful of half-chewed peanuts. Most I snorted out of my nose and between the keys on my laptop. The rest nearly choked me.
  9. #9
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    9,440
    You sure?
    No need to be at a Tech Lab to do silly Techie things
    What about putting batteries the wrong way on something?
  10. #10
    28,916
    Oh I will make plenty of NEW mistakes, but I doubt I will ever solder a plug on the end of a cable again. I doubt I will ever neglect to trim off a cap or resistor lead, install the board and have the lead wire short something to ground. Probably never again measure B+ voltage with my meter set up for milliamps. BZZZT.
  1. Replies: 7
    Last Post: 06-25-2016, 12:01 AM
  2. M Taper or Special Taper pot question
    By Bako in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-08-2014, 01:53 AM
  3. Pot taper question
    By daz in forum Theory & Design
    Last Post: 12-16-2013, 04:48 AM
  4. Replies: 1
    Last Post: 02-01-2013, 07:17 PM
  5. Turn audio taper pot into linear pot?
    By jakeac5253 in forum Guitar Tech
    Last Post: 05-31-2010, 07:20 PM
