Results 1 to 13 of 13
Like Tree5Likes
  • 1 Post By The Dude
  • 2 Post By LesterPTelestrat
  • 1 Post By g1
  • 1 Post By J M Fahey
Thread: External Speaker for Marshall DSL15c
    Oct 2017
    Minnesota
    12
    I'm thinking about adding an 8 ohm 10" speaker (a cab I just happened to have laying around) to one of the spare 8ohm outputs in the amp and leaving the 16ohm internal speaker connected. This gives me a combined ohm value of 5.33 ohms. Marshal says not to exceed or use less than 8 ohms. What could possibly happen? premature tube life? Fried transformer?
    Any thoughts? is it worth the risk to my amp to try this?
    Thanks for any assistance ya'll can share.
    Aug 2017
    Portland, OR
    144
    If you use the 16ohm output and one of the 8 ohm output jacks (hate the way they labelled these, makes it looks like you can hook up two 8 ohm cabinets) the total impedance won't be 5.33. You aren't truly putting them in parallel, since they are on two separate secondary taps of the output transformer. It would be 5.33 if you put the internal speaker and the external cabinet to the two 8 ohm jacks. If you keep the internal on the 16 ohm jack and add the cab to the 8 ohm jack I think the tubes are essentially seeing a 4 ohm load. I could be wrong though.
    I personally wouldn't do it, not just if it is a random speaker you just happen to have. You get less total power output (since you will have mismatch impedance) and potentially damaging your amp.
    Oct 2017
    Minnesota
    12
    Thanks for the feedback, I have a Marshall Ministack cab with an 8 ohm Eminence Rajin Cajin in it. Anyway I slice it, I get less impedance than is recommended so I won't mess with it. It just would have looked sweet to put the cab on top of the amp and run both. Instead I replaced the stock speaker with an 8 ohm Jensen CK12 that I took out of my Fender DRRI, it's much tighter and not fizzy when in the high gain channel. Much better than the stock for dirty tones.
    Old Timer olddawg's Avatar
    Dec 2007
    Carlsbad, CA and Kona, HI
    2,398
    Depends on how loud you are wanting to be. You can put an 8 ohm/ 5 watt ceramic resistor in series with your 8 ohm cab on the positive terminal and connect that 16 ohm load in parallel to the 16 ohm internal speaker. You will get more cone movement and dispersion. I doubt you would lose much perceptible volume. Wouldn't hurt to try.
    Oct 2017
    Minnesota
    12
    Thanks olddawg, I may give that a try.
    g1
    g1 is offline
    Feb 2010
    9,176
    Quote Originally Posted by olddawg View Post
    If you do this, you have to plug them into the 8 ohm jacks. When the 16ohm jack is used, the other jacks are not operational. (according to the handbook)
    The two 8 ohm jacks are for a single 8 ohm cab or two 16ohm cabs.
    Certified Dotard
  7. #7
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    9,440
    Please somebody post a schematic showing output transformer wiring, specifically because Marshall labelling is poor (maybe the user manual explains it better) and leads to confusion.
    Only after that an answer can be given with any certainty.
  8. #8
    Supporting Member The Dude's Avatar
    May 2010
    Sioux Falls, SD
    4,591
    J M Fahey likes this.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  9. #9
    Oct 2017
    Minnesota
    12
    Quote Originally Posted by g1 View Post
    I can confirm that the 8 ohm outputs still work, even with the internal speaker plugged into the 16 ohm jack.
    J M Fahey and g1 like this.
  10. #10
    g1
    g1 is offline
    Feb 2010
    9,176
    So then you have to consider what glebert mentioned in post #2. You do not want to run off 2 taps at the same time.
    Use two 16ohm speakers plugged into the 8 ohm jacks.
    Certified Dotard
  11. #11
    Oct 2007
    9,440
    Quote Originally Posted by LesterPTelestrat View Post
    Cool, but in practice that does mean much, since only very very few use switching jacks to automatically select the proper tap (Ampeg SVT, Music Man, a couple Fender)
    Most others either used a single or parallel pair jacks and a manual impedance selector switch or currently different jacks for different taps, NOT meant to be used at the same time but to let you choose proper impedance when plugging in.
    No switching involved so none cuts out when others are used, which is what you found.
    You *might* plug a 16 ohm speaker in the 8 ohm tap *and* an 8 ohm one in the 4 ohm one, but since you do NOT have any 4 ohm taps, forget it.
    What Marshall expects is you to get another 16 ohm speaker and use it with the current one, both plugged into the poorly labelled 8 ohm output.
    FWIW what I write on my amps is:
    * 1 x 16 ohms (single 16 ohm jack)
    * 1 x 8 or 2 x 16 ohm speakers (parallel 8 ohm jacks)
    * 1 x 4 or 2 x 8 ohm speakers (parallel 4 ohm jacks)
    for a grand total of 5 jacks, which is far more reliable and intuitive than 2 parallel jacks and a rotary swich (not to mention cheaper )
    Many do the same, as in Mesa Boogie.
    pdf64 likes this.
  12. #12
    Better Tone thru Mathematics bob p's Avatar
    Chicago, USA
    4,109
    so what happens when a dufus plugs an 8-ohm cabinet into one of the jacks that says "1 x 8 or 2 x 16 ohm" and plugs a 4-ohm cabinet into one of the jacks that says "1 x 4 or 2 x 8 ohm"?
    we all know that somebody will do it.
  13. #13
    Oct 2007
    9,440
    They lose warranty coverage
    That´s specifically advised against.
  1. Marshall DSL15C/H DSL40C schematics
    By Steve A. in forum Schematic Requests
    Last Post: 01-16-2017, 11:56 PM
  2. external speaker jack
    By beetle288 in forum Mods & Tweaks
    Last Post: 07-30-2011, 11:51 PM
  3. External Speaker
    By kuvash in forum Guitar Amps
    Last Post: 03-26-2011, 03:33 AM
  4. Adding an external speaker jack
    By vmazz in forum Mods & Tweaks
    Last Post: 09-10-2008, 03:48 PM
  5. External speaker volume control?
    By JJGross in forum Mods & Tweaks
    Last Post: 10-17-2007, 06:38 PM
