Go Back   Music Electronics Forum > Amplification > Guitar Amps > Vintage Amps
Old 10-19-2007, 01:52 PM   #1
61 Ampeg Reverberocket. weak reverb
Nice boards here! This is my first post.
Anyway, I just bought an old Ampeg Reverberocket, which sounds amazing, but had little or no reverb. I repleced the preamp tubes with NOS 6SL7s, and 6SN7s. I also cleaned the connections on the reverb pan, retentioned the RCA jacks, and re-flowed the solder joints at the jacks.
Its a little better now, but weak, and has a fast delay quality to the reverb.
Anyone know what I might try next? Resistor, Cap ect?
retrobob is offline   Reply With Quote
Old 10-19-2007, 09:27 PM   #2
Check the cap that drives the tank, usually .47 or so.
J Martin is offline   Reply With Quote
Old 10-20-2007, 01:12 PM   #3
Quote:
Thanks, Can you tell me how to locate that cap? also do you know which tubes are used for the reverb?
Old 10-20-2007, 03:49 PM   #4
The cap should be near the large 330 ohm resistor off the 6SN7 that drives the tank.
Old 10-23-2007, 01:30 AM   #5
Thanks!, Ill see if I can locate it.
Old 10-24-2007, 12:59 AM   #6
I found the .47 cap. All I have in my stash is 200v .47 caps.
I'll have to get a 600v. Will a 400volt work?
Old 10-27-2007, 02:18 AM   #7
We have Reverb!
After obtaining a schematic, I found several replaced parts with the wrong parts, and an electrolytic cap installed backwards.
There was a 22k resistor with a .013 cap across it at V3 at pin 6. Should have been a 3.3k with an .02 cap. The backwards 33uf cap was a V4 at pin 6. Replaced it with a correct 25 uf.
I also replaced two wrong .022 caps with the correct .02 which made the tremolo stronger.
The reverb works properly now, but seems to have a faster delay than I like. Maybe I will order a long delay pan for it.
This amp sounds better than any Fender I have ever owned!
Slowing trem speed in Ampeg Reverberocket 2 Keith Mods & Tweeks 5 04-27-2007 02:53 PM
need help finding parts list for a reverberocket gandalf_reldnik Repair and Restoration 5 02-17-2007 04:44 PM
Deluxe Reverb Weak Output nikdvs457 Maintenance, Troubleshooting & Repair 5 02-15-2007 03:15 PM
Reverberocket reissue channels wont switch tpw Maintenance, Troubleshooting & Repair 10 01-09-2007 09:54 PM
Ampeg Rocket Reverb 2X12 noah_swanson Maintenance, Troubleshooting & Repair 16 12-14-2006 05:33 AM
