Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By Jazz P Bass
Thread: Hartke LH1000
    Jun 2007
    Pensacola, FL
    3,492
    Hartke LH1000
    Came in with Channel B PA blown. 7 of 8 BJTs (C5200/A1943) shorted.
    I removed them all. Added 4 1k 2w resistors from B to E. 2 on each side. Not sure if I need to do all 4 on each side. I think JM Fahey or Jazz P bass suggested this on a previous repair.
    The voltages at the driver bases aren't symmetrical. Seems skewed positive. Or actually the on driver base isn't pulled negative enough. All other voltages look good to me so I'm stuck.
    All .22 ballasts are good.
    Any suggestions?
    Jun 2007
    Pensacola, FL
    3,492
    Here's a pic. Had a technical hiccup.
    Jun 2007
    Pensacola, FL
    3,492
    Ok ok...haha. Sometimes just posting forces me to analyse further.
    The limited Q312 seemed a likely suspect. Sure enough it was shorted B/C. Put the closest pnp I have in stock in there. MPSA56. Fixed.
    Dec 2008
    Wernersville, PA
    12,105
    Check the fan operation while you have it on the bench.
    I had one come in that the fan came on way too late.
    lowell and g1 like this.
    Jun 2007
    Pensacola, FL
    3,492
    All 3 fans come on right quick.
    Reassembled the amp, voltages look great, works great. Wouldn't be able to say that if not for the Ampage community, who has taught me I don't have to be just a "tube amp" guy. Thanks to everyone!
  1. Hartke LH1000
    By lowell in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-31-2017, 09:14 PM
  2. Hartke LH1000 balance ??
    By nosaj in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-22-2015, 03:42 AM
  3. What thermistor for a Hartke LH1000?
    By booj in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-22-2011, 01:10 AM
  4. hartke LH1000
    By pontiacpete in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-18-2009, 06:22 PM
  5. Hartke LH1000
    By pontiacpete in forum Schematic Requests
    Last Post: 10-28-2009, 04:19 AM
