Results 1 to 4 of 4
Like Tree4Likes
  • 1 Post By nosaj
  • 1 Post By J M Fahey
  • 2 Post By doctor
Thread: TDA2050
    Jun 2007
    Pensacola, FL
    3,414
    TDA2050
    Got a JC40 in with a blown one. Anyone have a few I could buy?
    Sep 2011
    Pace, FL
    1,246
    Quote Originally Posted by lowell View Post
    If you need it tomorrow try Mcdowell's Electronics on 9th Avenue. They're off the road a bit by a fire station.
    nosaj
    lowell likes this.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    9,445
    Out of production and EBay ones are relabelled TDA2030 which is still being made.
    Unless you get one from somebody´s cache or some small town Mom and Pop shop which has a few in dusty shelves or a Tech who bought a few too many, your best bet is an LM1875 which are still being made.
    Not 25/30 W rated like 2050 but honest 20W , I guess JC40 is actually 20+20.
    lowell likes this.
    Jul 2007
    547
    Output power is defined by supply voltage(s) used in the amp and load resistance.
    For this reason, TDA2050 can be replaced with LM1875 and vice versa.
    The output power will be EXACTLY the same.
    Only two electric parameters should be considered when you need to replace output operational amplifier (IC):
    - The maximum allowable voltage of the IC, which is used as a replacement, should be greater than the supply voltage(s) of the amp.
    - The IC, which is used as a replacement, should have a minimum load resistance no more than the original one.
    lowell and J M Fahey like this.
  1. Vox Cambridge 30 Reverb Twin keeps blowing TDA2050
    By acorkos in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-22-2015, 07:51 AM
  2. Current booster circuit with TDA2050
    By Aleko in forum Build Your Amp
    Last Post: 02-17-2010, 12:02 AM
