Results 1 to 17 of 17
Like Tree4Likes
  • 1 Post By big_teee
  • 1 Post By rjb
  • 1 Post By jrdamien
  • 1 Post By J M Fahey
Thread: Info On This Vox Pickup
    Sep 2011
    Minneapolis
    276
    This is out of a Vox Voilin bass. I've never seen one or worked on one.
    Any idea what it is or what sort of wire was used? The coil is taped and I've yet to tamper with it.
    The other pickup measures 9.7k.
    EDIT: This is a Hofner pickup.
    Sep 2011
    Minneapolis
    276
    Well nevermind. It's a Hofner 512b from the late 60's and wound with 50mm wire.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,149
    50mm is about 2 inches
    maybe you mean 0.005mm wire (5 thousandths of a mm) which amounts to some AWG 44 .
    May 2017
    30
    There's quite a bit of info/inside views of Hofner pickups here - Hofner Guitar Pickups
    Their designs are interesting to study...You can tell they tried to make the most out of each magnet with all sorts of metallic gizmos, and some of those pickups sound really nice!
    Sep 2011
    Minneapolis
    276
    Quote Originally Posted by J M Fahey View Post
    This.
    Supporting Member
    PDX
    3,211
    Hmm... 44AWG is .002" or .051mm -no?
  7. #7
    rjb
    rjb is offline
    Feb 2010
    Just south of Bawlmer, Merlin
    2,491
    Quote Originally Posted by David King View Post
    Yup. Those pesky decimal places...
    https://www.rembar.com/PDF/WireGauge.pdf
    Last edited by rjb; 10-17-2017 at 05:17 PM. Reason: Changed decimal "points" to "places"
  8. #8
    Oct 2007
    10,149
    Probably.
    Fact is AWG scale is not linear so some equivalences are either not exact or need a long string of decimals ... which is irrelevant because there´s quite a tolerance spread on very thin drawn wire, specially if copper.
    Just check Elektrisola (or any other) wire tables, tolerance can easily be 5 to 10%
    As in:
    Gauge: 42 AWG & 43 AWG, 44 AWG
    Weight: 1.0 Pound Each
    Length: 42 AWG - 51,313 Feet (approx.) • 43 AWG - 66,092 Feet (approx.) • 44 AWG - 79,798 Feet (approx.)
    Diameter: 42 AWG - 0.0026"-0.0028" • 43 AWG - 0.0023"-0.0025" • 44 AWG - 0.0020"-0.0022"
    Insulation: Solderable Polyurethane
    Build: Min-Nom
    NEMA Description: MW-79-C
    Temperature Rating: 155°C (311°F)
    Color: 42 AWG - Natural • 43 AWG - Natural • 44 AWG - Red
    Reel Size: 2.5"x3" Spool
    Manufacturer: Elektrisola
  9. #9
    rjb
    rjb is offline
    Feb 2010
    2,491
    Juan, we're not talking about tolerance out to a long string of decimals. We're talking about order of magnitude.
    You told jrdamien "50 mm is about 2 inches"- which is correct.
    You went on to say "maybe you mean 0.005mm wire (5 thousandths of a mm) which amounts to some AWG 44"- which is incorrect.
    AWG 44 is approximately 0.05mm (5 hundreths of a mm). So your "correction" was off by a factor of 10.
    If I had better language & social skills, I would have said this more clearly & succinctly, and in a playfully teasing manner.
    -rb
    EDIT
    How's this? "Hey Juan, is it true you worked on the Hubble telescope?" Nah, too snarky.
    Last edited by rjb; 10-17-2017 at 08:07 PM. Reason: Added bolding, italics, and snark.
  10. #10
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    10,565
    44 Gauge magnet wire, .0020-.0022 inches.
    Technicians Run the World, but Bankers, Lawyers, and Accountants, Take All The Credit!
    Keep Rockin! B_T
    Terry
  11. #11
    rjb
    rjb is offline
    Feb 2010
    2,491
    Quote Originally Posted by big_teee View Post
    0.002 inches ~= 0.050 millimeters = 0.005 centimeters
  12. #12
    Jun 2010
    Mid-South USA
    10,565
    Quote Originally Posted by rjb View Post
    Like I said! See Attach.
    Keep beating it, I think I saw it wiggle!
    kayakerca likes this.
    Keep Rockin! B_T
    Terry
  13. #13
    rjb
    rjb is offline
    Feb 2010
    2,491
    You're right, I didn't read the attachment.
    So we agree: 44AWG = .0020"-.0022" = .051-.056 mm (to 2 significant decimal places).
    Right again- I saw it wiggle too.
    big_teee likes this.
  14. #14
    Oct 2007
    10,149
    Think you are making a big point out of a very small one.
    And yes, I typed one extra zero, so sue me, the main point was that pickup wire was NOT 50 mm, a FOUR orders of magnitude error now that you insist on that , anything else comes in its wake.
    I even got close with the AWG value, which I included just as a courtesy to you Imperial heathens
    Oh well, no good deed goes unpunished, just ask some moderator to remove all of my posts in this thread, which I should have left unmolested.
  15. #15
    rjb
    rjb is offline
    Feb 2010
    2,491
    Of course. That's what we do.
    It's not that. It's that you wrote out "5 thousandths of a mm", then when David corrected you, due to a coffee deficiency or similar malady, you misinterpreted what he said and went off on a tangent about manufacturing tolerances.
    Yes, I'm still chuckling about that. Two inch thick pickup wire, tee hee hee.
    Lucky guess.
    Got that right.
    No way. This is going on the wall of shame.
    -rb
  16. #16
    Sep 2011
    Minneapolis
    276
    So you're all saying *don't use 2 inch diameter wire?
    Well it's too late now!
  17. #17
    Oct 2007
    10,149
    Quote Originally Posted by jrdamien View Post
    Hey!!!!! I wound the PT transformer for my Champ with it !!!!!!
    rjb likes this.
  1. More Thomas Vox Repair Info
    By R.G. in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-24-2017, 11:28 PM
  2. Need Vox Cambridge 15 schematic and/or power amp IC info
    By bluesky6 in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-29-2014, 06:20 PM
  3. vox buckingham super reverb info needed.......
    By rockgod212 in forum Repair and Restoration
    Last Post: 07-31-2011, 11:29 PM
  4. Looking for vox info
    By Ebtronics in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-14-2008, 11:38 AM
  5. Where can find Vox dating info?
    By H Chandler in forum Vintage Amps
    Last Post: 06-07-2007, 02:08 AM
