Results 1 to 4 of 4
Thread: Marshall valvestate Channel Switching Problem
    Oct 2017
    3
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hi,
    I have a Marshall VS100 Combo amp. I have had several issues in the past with channel switching, usually buying a new footswitch sorts it out.
    This time however the footswitch does not seem to be at fault. I have swapped the switches, checked the cable and even hardwired it to the socket, (the socket has been changed too).
    This is a two button footswitch but will only switch between clean and OD1. I can manually select OD2 from the front panel of the amp, however if I do this I can't un-select using the footswitch.
    I've done a bit of digging and seen the the Mosfet transistor 1 (SA872E) on the backboard controls the switching; does this only control clean to OD1 or all three channels? I'm thinking the issue is with the internal board but not sure what needs changing out?
    Located North East England.
    Thanks in advance,
    Dave
    0 Not allowed! Not allowed!
    Oct 2017
    3
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by DaveLMI View Post
    Hi,
    Thanks in advance,
    Dave
    Just as an update - I swapped out the T1 transistor and now I can switch from od1 to od2 but can't access the clean channel unless I use the front panel, turn off od2 then I can switch between clean and od1 - I feel so close to cracking this, any suggestions? I tried changing t2 as it's right next to it but that did nothing?
    Thanks.
    Feb 2010
    9,849
    Thumbs Up/Down
    Received: 70/0
    Given: 127/0
    Both front panel buttons must be 'out' when using the footswitch.
    With both buttons out, what are the new symptoms?
    Certified Dotard
    Oct 2017
    3
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by g1 View Post
    Yeah I've had this amp years, I know how the front panel buttons need to be set. I've put the amp back together and now I just get a realky loud hum, it's going in the bin!
  1. Marshall Valvestate 8080 - VS80 - overdrive channel not working
    By callai in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-02-2016, 01:25 PM
  2. channel switching help (problem with amp)
    By HTH in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-05-2013, 12:54 PM
  3. Marshall Valvestate 265 with one channel hum
    By Judson in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-22-2010, 12:11 AM
  4. Marshall 8100 Valvestate Volume issue on Distortion channel
    By jmarshall in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-29-2009, 06:03 AM
  5. Marshall JCM900/4100 PS and channel switching problem
    By jaz10 in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-26-2009, 09:35 PM
