Results 1 to 6 of 6
Thread: will this work
    Jun 2017
    England
    102
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    will this work
    [ATTACH=CONFIG]45508[/ATTACH
    It took me a while to draw just want to ask will this design work i know its not your standard circuit drawing but its the best i could do!!!
    all the jacks both input and output are non isolated
    would really appreciate it if someone could look over it and tell me if i've made any silly mistakes
    thanks
    scott
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    0 Not allowed! Not allowed!
    Jun 2017
    England
    102
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
Name:	amp drawing.png
    So sorry i uploaded the wrong file this is the correct picture!!!! As noted before all jacks both input and output are non isolated
    thanks
    scott
    Supporting Member mozz's Avatar
    Oct 2015
    NEPA
    512
    Thumbs Up/Down
    Received: 6/0
    Given: 5/0
    A schematic would help. Very hard to tell if it would work from a layout.
    May 2013
    170
    Thumbs Up/Down
    Received: 2/0
    Given: 2/0
    I've not analysed the whole amp, because even as a layout it's not even clear.
    In any case, the boost switch will pop loudly.
    Keep the 470 nF always connected (it's two orders of magnitude lower than the 22 uF, so well within the tollerance of the latter cap), and ground the 22 uF through a 1M resistor, then put the switch in parallel with the resistor to activate the boost.
    As for the rest of the circuit, a schematic or a correct layout would be better.
    Jun 2017
    England
    102
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Yeah I thought it would be difficult to analize from the drawing I don't yet have the skills to prepare a proper circuit drawing (sorry about that) the main thing I'm asking for is the grounding scheme
    the first attachment in this thread is the original layout using the brass plate method and the second attachment (my awful drawing ) is what i have changed it to after reading various recommendations from various forums and such i just want to make sure i haven't made a basic mistake
    Thanks
    Scott
    Jun 2017
    England
    102
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    With regard to the boost switch pop I've read that a 1 meg resistor from each side of the switch to ground cures it as well?
  1. Would This Work?
    By walcen in forum Pickup Makers
    Last Post: 11-30-2015, 11:35 AM
  2. How does this work?
    By ricach in forum Theory & Design
    Last Post: 03-26-2010, 02:19 AM
  3. would this work?
    By daz in forum Theory & Design
    Last Post: 05-15-2009, 12:58 PM
  4. Let me know, do you think this will work?
    By CitizenCain in forum Theory & Design
    Last Post: 05-31-2008, 02:31 AM
  5. will this work?
    By Jason C in forum Theory & Design
    Last Post: 04-12-2008, 10:31 PM
