Results 1 to 9 of 9
Like Tree3Likes
  • 2 Post By Jazz P Bass
  • 1 Post By mozwell
Thread: Boss ME 20 loses memory after shutting off
    Supporting Member Steve A.'s Avatar
    4,920
    A friend has an ME 20 that he gigs with quite often and its memory is no longer persistent. Once he turns it off all of the settings (like the noise gate) are lost. We both think it is an internal battery which need to be replaced. Anybody here familiar with this? Like the number and source for the replacement battery...
    Thanks!
    Steve A.
    P.S. A Google search only finds hits for the 6 AA batteries... gee thanks, Mister Google!
    Supporting Member mozz's Avatar
    Oct 2015
    NEPA
    507
    I would think if you took it apart, you would see if there is a battery for the memory or not. I see dram and eeprom on ME-30.
    Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics
    4,920
    Quote Originally Posted by mozz View Post
    My friend lives about 40 miles away so I was hoping that I would have a fresh battery on hand when he embarks on an 80 mile round trip.
    FWIW I have had some digital gear that needed an internal battery changed after ~10+ years, something usually omitted from user manuals.
    Steve A.
    g1
    g1 is offline
    Feb 2010
    9,884
    Get him to pop the cover. If it has one, should be a coin cell with a visible number on it. Important to know if it is in a clip style holder, or solder tab style.
    Certified Dotard
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,402
    Memory batteries in some less sophisticated or older models can be plain old AA cells. The drain from them for a CMOS RAM is tiny, they batteries essentially last their shelf life. But most are either rechargeable Nicads or then Lithium cells.
    The lithiums are usually coin cells, like the common CR2032. Since those lithium cells also last for YEARS, they are usually the solder-in type. Digikey or Mouser will have those. It is a coin cell with little solder legs welded on. You can't solder to a plain coin cell without destroying it. The battery is the same, solder lugs or not. I keep a supply of coin cell sockets on hand, and when I replace a soldered battery, I just mount a coin cell socket, and now anyone can pop a new CR2032 into it in seconds. BUy CR2032 at Radio Shack, the local grocery store battery display, wherever.
    Older things like synths from the 1980s used Nicads more. Those were kept charged whenever the unit was powered. and could hold a charge for months on end when off. I don't ever recall seeing a Nicad that wasn't a solder in, but no reason one couldn't mount a AA holder and use plain rechargeables.
    There is more than one footprint for coin cells with solder tabs. One has a pin in the middle and one off the edge. ANother has an edge pin but a flat tab on the center that bends down and has two pins.
    I don't think the six AAs on this are for memory, but I could be wrong.
    4,920
    Of course you're right about the AA cells since they are not needed if you are using an AC adaptor.
    Thanks for such a comprehensive post... I will save it in my evergrowing archive of useful information.
    Thanks for reminding me not to try soldering leads to CR2032 I had forgotten all about that! I usually order the lithium coin cells from Amazon or eBay which is where I buy 6 packs (or larger) of the common lithium coin cells at very reasonable prices.
    So could you use a conductive glue to mount leads if you didn't have a socket? I think I ordered some of that awhile back from that American Surplus & whatever mail order seller...
    I found these at Amazon, 10 for $5.81 with free shipping (not Prime.) Many of the ones listed there are PCB mount or with flimsy leads while these have solder tabs on the top. I guess you could just epoxy the holder to the old battery.
    https://www.amazon.com/uxcell-CR2032.../dp/B00GYW39KG
    HELPFUL HINT: When using a glue that doesn't set immediately and has to be held in place I've been using the 5 Second Fix which is cured by the UV LED on one end of the dispenser. It does not bond to all materials but you usually find that out right away (my first project was repairing an $8 rubbery plastic 13 quart trashcan... it does not bond to that kind of plastic so I went back to the Gorilla Clear Repair Tape I had been using before eventually recycling it.)
    Before I learned about the 5 Second Fix I used a similar trick but with a hot melt glue gun. 2 years ago I wanted to add an oak threshold to the side door on my garage to keep out rats which were getting in through the 3/4" gap between the door sweep and the smooth concrete slab.
    Not having the tools or desire to do it the proper way with a Hilti gun I heated up the smooth concrete slab a little bit with a hot air gun and then secured the threshold in place alternating dabs of hot melt glue and silicone. It is still attached securely and when it eventually comes loose I will use the same method to glue it down again.
    Steve A.
  7. #7
    30,402
    I buy them from Mouser or Digikey.
    I would never rely on "conductive glue" for electrical circuit. Soldered wires for me. The only place I would consider conductive glue would be a situation where I want static electricity shunted to chassis.
  8. #8
    Dec 2008
    Wernersville, PA
    12,151
    By definition, EEPROM chips do not need to be powered all of the time.
    I do not see a 'battery' for the EEPROM.
    Here is the ME-20 & the EEPROM IC datasheet.
    ME-20.zip
    HN58X2408FPIE.pdf
    mozwell and g1 like this.
  9. #9
    Senior Member mozwell's Avatar
    Sep 2009
    Australia
    644
    I am not familiar with this unit, but....
    There seems to be an internal 6x AA battery pack, presumably on connector CN3
    There are two EEproms, with I2C serial bus connection. These don't need a battery to keep their memory.
    Page 2 of the service notes says "user memory is in EEPROM IC8, moving user memory to another unit can be done by moving IC8 to the new unit, but is not recommended".
    There appear to be no button cells for memory backup in this unit.
    It is possible IC8 is bad, or maybe the serial bus is not working correctly. Easy enough to change IC8 & see how you go.
    IC8 is HN58X2408FPIE, 8 pin 1Kx8 I2C serial EEPROM
    A quick check on Digikey gives many suitable alternatives which should be drop in, the pinout is standard across different manufacturers, try CAT24C08WI-GT3CT-ND
    Good luck
    g1 likes this.
  1. Boss ME-20
    By dmeek in forum Schematic Requests
    Last Post: 06-01-2016, 10:14 PM
  2. Boss DD-20 Mods and Observations
    By 12Bass in forum Guitar Effects
    Last Post: 03-11-2016, 05:44 PM
  3. Boss DD-20 Giga Delay schematic
    By RedGuitar in forum Schematic Requests
    Last Post: 07-03-2010, 02:22 PM
  4. Boss FS-6 pedal switch and ME-20
    By Ramsay in forum Guitar Amps
    Last Post: 05-29-2010, 03:02 AM
  5. Vox AD60VT loses memory when using foot controller
    By ChancesR in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-24-2008, 08:53 AM
