Results 1 to 18 of 18
Thread: TS-9 Problems
    Oct 2016
    44
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    TS-9 Problems
    I bought a used 83-TS9 and am having an issue with getting the 4.5 V. Basically the LED is stuck in the on position and no sound. It looks as if there are two 10k resistors that split the 9V into the 4.5 then it moves on. There is no 4.5V at this point.
    Im more familiar with tube amps,but i have a decent knowledge of SS pedals,but this one has puzzled me.
    0 Not allowed! Not allowed!
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,290
    Thumbs Up/Down
    Received: 347/5
    Given: 356/5
    Please post a TS9 schematic, preferrably the original Japanese/Factory one (I have seen it somewhere) so it best matches your pedal guts, maybe even part ID names, so we can suggest some specific voltage measurements and tests.
    Oct 2016
    44
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I have not been able to find a TS( but i found a TS808 which is virtually identical. Let me see if i can post a picClick image for larger version.
    Supporting Member mozz's Avatar
    Oct 2015
    NEPA
    564
    Thumbs Up/Down
    Received: 40/0
    Given: 27/0
    If the voltage is not there, either something is open or something is shorted. One of the 10k is open, the cap 47uf is shorted, or wherever the 4.5v goes to is shorted.
    Oct 2016
    44
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    The two 10k test good,new 47 cap installed. According to the schematic,the 4.5v starts at those two 10k resistors as far as i can tell.
    Feb 2010
    10,068
    Thumbs Up/Down
    Received: 236/0
    Given: 451/0
    Is the 9V getting to one of the 10K resistors? Are you using a battery?
    The voices in my head are idiots!
  7. #7
    Dec 2008
    Wernersville, PA
    12,279
    Thumbs Up/Down
    Received: 63/0
    Given: 21/0
    That would be my question: do you have the 9Vdc.
    The input jack is supposed to be a 'stereo' jack (TRS).
    When nothing is plugged in, the battery ground is not connected to circuit ground.(LED Off)
    Inserting a plug will complete the grounding scheme & light the LED.
  8. #8
    Oct 2016
    44
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    9V is getting to the two 10ks,yes
  9. #9
    Oct 2016
    44
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I use a battery exclusively. Already replaced the DC jack just to be sure and checked the connections to the jacks and verified the jacks to be operational. Also checked the LED itself to be working correctly in and out of circuit. Of all the schematics I lookd at,most showed the 4.v originating from the two 10k resistors and the 47uf and 100uf caps,all of which have been changed with new parts(nichicon and RN55 Dale)
  10. #10
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,433
    Thumbs Up/Down
    Received: 446/1
    Given: 0/0
    You say your 9v gets to the two 10k resistors. OK, but what happens to it then? Normally the 9v gets to one end of one of them. They are in series from 9v to ground. That means there SHOULD be 4.5v at the joint between the two. Now we either have 4.5v there, but it doesn't reach the circuits or we do not. If we do not, we might have zero, meaning the upper one is open or not connected. If we have 9v at the joint between, then the lower resistor is open or not grounded.
  11. #11
    Dec 2008
    Wernersville, PA
    12,279
    Thumbs Up/Down
    Received: 63/0
    Given: 21/0
    You could try measuring the 10K R junction to ground.
    If it is loaded down elsewhere that could cause an issue.
  12. #12
    Oct 2016
    44
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    The pedal is at work and I'll have to check it Monday. Seems that grounding could be an issue. Im lucky to have a second TS9 open on the bench next to it so i can compare voltages. I guess ill have to pick this up Monday.
  13. #13
    Oct 2016
    44
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Its at work and im going to check Monday afternoon when i get back. Too bad the factory schematic service manual is not available. It would help identifying
    parts.
  14. #14
    Old Timer nosaj's Avatar
    Sep 2011
    Pace, FL
    1,772
    Thumbs Up/Down
    Received: 177/20
    Given: 24/5
    Quote Originally Posted by J M Fahey View Post
    Will this work?
    Thanks,
    nosaj
    ibanez_ts9_tubescreamer.pdf
  15. #15
    Oct 2016
    44
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    By the way thank you all for the help so far. I appreciate it.
  16. #16
    Oct 2016
    44
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Actually i found a good copy just a little while agoClick image for larger version.
ID:	45554Click image for larger version.
ID:	45555Click image for larger version.
  17. #17
    Oct 2016
    44
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    So today at work i was able to look at all the connections. I wasn't happy with many so,I just pulled all the wires from the board and cut them,stripped them exposed new wire,tinned them and cleaned all the pots well. I wanted to eliminate any bad connections and they needed it any way. Tomorrow I'll resolder all all that stuff back together and go from there.
    Also,the above schematic is the TS808,which is just SLIGHTLY different from the TS9. The schematic is the same but for a few resistor values. The board is 95% the same but slightly different in layout. I have not found a factory Ibanez/Maxon service manual or schematic yet.
  18. #18
    Sep 2011
    Pace, FL
    1,772
    Thumbs Up/Down
    Received: 177/20
    Given: 24/5
    Quote Originally Posted by lo-watt View Post
    A little premature just ripping everything out without troubleshooting the problem first. Hope you get all the wires back where they go. You keep saying how everything is Ts808 but a little different. What is wrong with the TS-9 ones I provided?
    Kinda get the premonition your gonna be on your own on this one. We were still waiting on a reply to Jazz's question of you.
    nosaj
  1. TS-9 led question
    By Randall in forum Guitar Effects
    Last Post: 09-27-2013, 12:36 AM
  2. ts into trs
    By rrbtrip18 in forum Music Electronics
    Last Post: 09-04-2011, 12:25 AM
  3. TS-9 TrueBypass how to?
    By kylendm in forum Guitar Effects
    Last Post: 10-16-2009, 12:03 AM
  4. TS - 9 Trouble
    By cam_wonders in forum Guitar Effects
    Last Post: 08-18-2009, 12:23 PM
  5. Rescue a TS-5
    By elpops in forum Guitar Effects
    Last Post: 10-31-2006, 08:18 AM
