Results 1 to 5 of 5
Thread: Tremolo effect pedal build
    Sep 2012
    Poole UK
    570
    Hi
    I want to build a tremolo pedal for my own use
    I have built it and it works, But not as well as i hoped
    The main problem is the depth. When i turn it fully off it increases the volume and only starts to work at about 12 o'clock
    The speed is better but i would like it to be more controllable, again it dont really work much until 12 o'clock
    I have made it exactly to the circuit
    I was going to try audio taper pots, but before i rip it out any idea's
    BBB
    Supporting Member
    Dec 2009
    UK
    3,025
    If it only starts to work at 12 o'clock with linear pots then with log it will be worse. With linear, 1/2 rotation is 50% of the resistance, with (most commercial) log pots this equates to 10% of the resistance.
    Try wiring up a log pot backwards to simulate a C taper pot. If that works OK either leave it like with reverse-operation controls, or order some C taper pots.
    The volume shift is a characteristic of the design. Amongst other things the NFB changes due to the varying cathode resistance - more NFB as the depth increases, so lower effective gain.
    May 2007
    pacific north west
    12,519
    I can't look at the circuit and determine how it sounds. Is this a known good circuit. "Known good" being relative. As in did some guy say he made this and it's good or is it a popular design that is known? Many tremolo circuits use reverse audio pots. It's possible the behavior is "normal" with linear pots. The increase in volume with the trem off is a problem to be sure though. If you have a scope you can monitor signal swing to see if the trem is biased a little cold relative to when it's off. Properly, the trem will be a bit hot on peaks and, obviously very cold on the low volume or off modulation.
    "So I acquired it for the purpose of fixing it up - in case I run out of things to do with the rest of my life..." tubeswell
    "Shut up, you big dumb poopy-head!" Justin Thomas
    Supporting Member
    Dec 2009
    UK
    3,025
    See post #222 here to reconfigure the depth control and add a cathode bypass cap (to remove the variable NFB, though the post refers to this as an anti-pop cap);
    Vibracaster - or "How to turn your Valvecaster into a Tremolo"
    Sep 2012
    Poole UK
    570
    Thank you. I will look into the changes
    BBB
  1. Tremolo effect idea - already been done?
    By Mark Lavelle in forum Music Electronics
    Last Post: 04-20-2017, 01:31 PM
  2. we use subminiature in effect pedal
    By kldguitar in forum Guitar Effects
    Last Post: 10-09-2011, 03:12 AM
  3. 1950's tube effect pedal
    By shzmm in forum Guitar Effects
    Last Post: 05-29-2010, 09:44 PM
  4. Ac30 clone - tremolo effect when goes off
    By bluemonk in forum Debugging Your Build
    Last Post: 10-04-2009, 09:05 PM
  5. new squeezer effect pedal
    Last Post: 04-19-2009, 04:09 AM
