Results 1 to 13 of 13
Like Tree11Likes
  • 1 Post By leadfootdriver
  • 2 Post By Chuck H
  • 1 Post By Chuck H
  • 1 Post By Enzo
  • 1 Post By eschertron
  • 2 Post By R.G.
  • 2 Post By tubeswell
Thread: My tube amps sound better the longer they're on..
    Aug 2009
    225
    When I power my amps up, they sound pinched an nasally. The longer I play them, the more natural and detailed the sound gets. The highs are pleasing, the lows are warm... U get it..
    They're must be something about the whole amp getting warm; caps and resistors, wiring that effects this and not just the tubes. I was hoping someone could explain this.
    Justin Thomas likes this.
    Chill-Ville, VA
    2,313
    Darn right there is. Sometimes I leave mine in the car all day with the Windows up to accelerate the process. (I mostly play heads - no "what about your speakers?" please!
    Justin
    "If you're using one of those Digiyuk module type things..." - Chuck H. -
    May 2007
    pacific north west
    12,515
    Many things in your amps change between cold and warmed up. This could well be what you're hearing. I won't mention speakers, but I will mention ears. Listener fatigue, even at low levels can have a profound affect on perception. I'll guess it's a combination of both. One way to tell would be to do like Justin and leave the amp in a hot car (or similar, sunny window. hot day, etc.) Then see if the process goes faster than a couple of hours. If it doesn't then listener fatigue is probably part of the equation. Most guitar amps warm up just fine idling or cranked because there's not a profound difference in current for many designs. So you could also pay attention next time you're playing louder than average. If the process happens a little faster on those days then, again, listener fatigue could be part of it.
    I mention this because as a designer I have done A LOT of listening at volume. There only so much you can take before you can't trust what you hear to be accurately considered. Many times I've thought I was on or off the mark during listening tests when I knock off for the day. Then the next day things are different without any other changes but time between the tests. I've noticed this is most likely to happen with long listening/testing sessions.
    J M Fahey and The Dude like this.
    "So I acquired it for the purpose of fixing it up - in case I run out of things to do with the rest of my life..." tubeswell
    "Shut up, you big dumb poopy-head!" Justin Thomas
    Jan 2017
    72
    Quote Originally Posted by leadfootdriver View Post
    Umm... bias current rising as the tubes heat up?
    Aug 2009
    225
    FTR, I have big amps that I play at home at low volumes, so I wonder if that has something to do with what I'm experiencing.
    I know all about the Loudness Curves and how our ears hear things differently at louder volumes. When playing loud, the amp sounds and feels totally different than in the house..
    So that said, last weekend I did a test where I recorded a riff after power up. I played for an hour and then recorded the same riff on another track to compare them. You can hear the difference no question. The warmed up take is even slightly louder.
    J M Fahey likes this.
    NYC
    1,648
    Pinched and nasally? That sounds like a problem.A tube amp does get better as things start cooking,power tubes mostly.How long does it take before the "pinched and nasally" thing stops? It should be almost instantly.Once the tubes voltages are applied it should sound normal,not pinched and nasally.It will get better as things start to cook.How old are the tubes?What kind of amp?
  7. #7
    May 2007
    pacific north west
    12,515
    ...last weekend I did a test where I recorded a riff after power up. I played for an hour and then recorded the same riff on another track to compare them. You can hear the difference no question. The warmed up take is even slightly louder.
    I'll be the first to point out that a good player has better tone using the same amp as a mediocre player. I don't suppose an hour into practice you were a little hotter than when you first started
  8. #8
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,180
    Here is a theory (more or less what Chuck said):
    You start out, and after a while your ears get used to the level, and you turn up some. Your ears get more middle-y the lower the volume. Hence, at first your sound is more to the middle, and as you get louder, your end responses widen out.
  9. #9
    Aug 2012
    Great Black Swamp
    1,653
    There are many psychological factors that are in play here.
    One sure-fire way to eliminate all of them is to record some material directly onto disk (tape?) and then with all levels consistent, record a pass through the amp at first turn on and then after letting it sit and idle for a few hours. If you think it needs to be "played through" to really warm up, go for it but resist the temptation to tweak a knob during the session Be sure to record a pass of exactly the same material used for the initial 'control' pass.
    Another test that can be performed if done this way onto a DAW, is to time-align the two passes, invert phase on one, and mix them together. any changes in the amp can then be really highlighted.
    edit: I personally have never been able to do this because I can't resist the urge to change the amp's controls even when I've told myself NOT to.
    Chuck H likes this.
    If it still won't get loud enough, it's probably broken.
    We need more chaos in music, in art... I'm here to make it.
  10. #10
    Lifetime Member
    4,193
    Folks, this is simple. It's well known that the girls all get prettier at closing time. Well, the amps sound better too.
    rjb and The Dude like this.
  11. #11
    Mar 2008
    417
    Do you like vintage ?
    " I know I'm stupid but get courage when look around "
  12. #12
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    9,551
    Tone improves with time
  13. #13
    Supporting Member tubeswell's Avatar
    Feb 2007
    Wellington NZ
    4,082
    Besides your ear fatigue, heat increases resistance and causes bias shift, so the way the circuit functions changes slightly with increasing heat.
    If you get a 1959 plexi superlead really pumping, you'll notice that the amp sounds supremely awesome as the quad of EL34s light up cherry red (just before you smell that smokey smell) LoL
    Chuck H and The Dude like this.
  1. Replies: 41
    Last Post: 03-03-2015, 03:02 PM
  2. Replies: 2
    Last Post: 10-09-2014, 06:54 PM
  3. About Storing Tube Amps/Tube gear
    By Dan Lawrence in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-08-2014, 08:04 AM
  4. Replies: 42
    Last Post: 09-03-2011, 10:01 PM
  5. how to mic amps for sound samples...
    By Possum in forum Pickup Makers
    Last Post: 07-30-2008, 06:37 AM
