Old 10-22-2007, 05:34 PM   #1
Volume problem in Blues Jr.
I performed two of Mill M's mods...tone stack and Twin and now I have almost no volume. The Tone stack is simply replacing two caps and the Twin mod is placing a jumper across the left and middle of the Middle switch. Any help would be much appreciated.
Thank you
danerada is offline   Reply With Quote
Old 10-22-2007, 08:59 PM   #2
Jag
Jag's Avatar
Are you sure you did the Twin Mod (where did you hear of this mod and who is Mill M) correctly? If I read your post right and am looking ath the schematic right, you are shorting most of you signal to ground regardless of the Mid and Bass settings.
I stand to be corrected but, remove that jumper and see what happens.
Jag is offline   Reply With Quote
Old 10-22-2007, 09:10 PM   #3
Jag
Jag's Avatar
I think I found the mod. Is it this one http://home.comcast.net/~machrone/bjr/twinstack.htm?
I was seeing the typical Fender layout in my mind, and forgot that the pots are oriented with their tabs on the bottom on the BJr. Try removing the jumper or at least checking that it is not shorting to the case as he indicated in his notes.
Old 10-23-2007, 07:52 AM   #4
Whatever you work on, if it is functioning before you work on it, and afterwards it is not, then something you did was the cause. Either your mod was not done correctly, or you globbed some solder where it didn't belong, or in the process you knocked a wire off something else, and so on.
Old 10-24-2007, 07:18 PM   #5
I took a break form it this weekend. I am going to get back on it later this week....I will let you all know what I find.
Fender Blues Deville preamp problem - very low volume moss0031 Maintenance, Troubleshooting & Repair 2 10-13-2007 09:22 PM
94 Blues deluxe clean channel problem tbrogit Maintenance, Troubleshooting & Repair 5 10-12-2007 01:20 AM
Fender Blues Deville cutting in & out at volume...help! slapbackdaddy Maintenance, Troubleshooting & Repair 5 08-31-2007 05:15 PM
Blues Deluxe Channel Problem eeijcon Maintenance, Troubleshooting & Repair 6 07-16-2007 11:16 PM
18W volume problem DOLBY Debugging Your Build 4 11-12-2006 10:08 PM
