Results 1 to 15 of 15
Thread: Bias after pulling out two power tubes?
    Nov 2017
    7
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I have a 94 Fender Twin with external Bias test. I have pulled the two inner 6L6 tubes to lower the wattage down to 60 watts per manual instructions. The manual says adjust bias to .08 volts but when I turn the adjustment screw all the way I only get .055
    So I tap on the power tubes, one is a bit harmonic the other is not. So I am thinking I need to replace my power tubes. My main question is do I still set the bias to .08 when running only two tubes? or do I set the Bias for half of .08 that being .04?
    0 Not allowed! Not allowed!
    Nov 2013
    123
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    is this the evil twin?
    anyway,2 tubes means half current,so 40 mA each,and you measure 40 mVdc.
    you have to use a load of double impedance of what you have on the amp,i guess 4 ohms,so the speaker must be 8 ohms,if you have 2 in parallel i'd disconnect one.
    Nov 2017
    7
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Evil Twin
    Quote Originally Posted by alexradium View Post
    Yes this is an Evil Twin also referred to as a 94. It seem there is a lot of confusion online about the name Evil Twin.
    Also a follow up question when tapping on the two power tubes is it normal for one to be a bit harmonic and the other NOT harmonic?
    Thanks for your help.
    Feb 2010
    9,827
    Thumbs Up/Down
    Received: 49/0
    Given: 67/0
    If you look closer at the manual, you will see it says .04V for optimum tube life, .08V for optimum performance.
    So, somewhere in the range of .04 to .08V.
    Now, when you pull 2 tubes, you cut that in half, like alexradium said.
    So somewhere between .02 and .04V, then adjust impedance setting or disconnect a speaker like he said.
    Certified Dotard
    Nov 2013
    123
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by Pennypicker View Post
    what do you mean with harmonic,rattling,buzzing?
    if you play it at proper volume and don't hear noises from the speaker,leave it like that,otherwise try another set.
    Chill-Ville, VA
    2,455
    Thumbs Up/Down
    Received: 14/0
    Given: 30/1
    I think he meant that a tube was microphonic - and those can hum, rattle, screech, or any other sort of sound you can imagine...
    As far as "Evil Twin," I believe this was the moniker for the Blackface-Style "The Twin," which was a part of the "Pro Tube Series" in the 90s, along with the Concert, Prosonic(!), and there was one other one... the earlier incarnation was the "Red-Knob Twin."
    Justin
    "... If an older Boogie and classic Marshall had a (clearly illegitimate) child and you baked it in an oven set to clown shit crazy." - Chuck H. -
  7. #7
    Feb 2010
    9,827
    Thumbs Up/Down
    Received: 49/0
    Given: 67/0
    Evil twin is '94 Twin Amp which is what is says on the nameplate.
    Red knob is the earlier version which is labelled The Twin. There may be versions of this whose knobs are black, but they are pointer style knobs like the red knobs.
    Twin Amp (aka 94 aka Evil twin) uses standard skirted knobs.
    Certified Dotard
  8. #8
    Nov 2017
    7
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Ok thanks. Oh I should have asked do I do anything to the balance adjustment? now that there is only one pair of tubes?
  9. #9
    Nov 2017
    7
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Yes this all is correct. The 94 has more features then most amps. Two effect loops one of them has a blend knob and each loop has level adjustment, reverb switch for each channel,XLR out, Main Speaker out/Ser/par, 4 8 16 ohms selector, 3 channels, presence etc!
  10. #10
    Chill-Ville, VA
    2,455
    Thumbs Up/Down
    Received: 14/0
    Given: 30/1
    Thanks g1, forgot about that one! :P
    Justin
  11. #11
    Nov 2017
    7
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Should the Balance adjustment still be set to Zero?
  12. #12
    Nov 2017
    7
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    When I tap with my finger on the tube one power tube makes noise. The amp sounds ok but the amp has to much bass even when turned all the way down I already order a set of tubes so I'll see if that fixes the problem.
  13. #13
    Feb 2010
    9,827
    Thumbs Up/Down
    Received: 49/0
    Given: 67/0
    Yes, adjust balance to zero.
    Certified Dotard
  14. #14
    Nov 2017
    7
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    g1 Thanks for the help!
  15. #15
    Jul 2011
    Adelaide, South Oz
    684
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Balance adjustment doesn't need any test equipment but your ears.
    Set any Master Vol or each preamp Vol to 0 so you are not getting the preamp sourced hum into the power amp..
    Then put your ear against the speaker and adjust balance for minimum hum. Mimimum hum will be at the point where the idle currents on each side of the push pull are equal.
    This works regardless of if you run 2 or 4 tubes, I would do it after pulling 2 tubes.
    Cheers,
    Ian
  1. Replies: 59
    Last Post: 03-23-2013, 10:42 PM
  2. Pulling tubes for lower output power
    By MonkHouse93 in forum Vintage Amps
    Last Post: 05-29-2011, 04:40 PM
  3. Pulling power tubes;
    By Bernardduur in forum Theory & Design
    Last Post: 03-07-2010, 01:01 PM
  4. Pulling power tubes from a Twin Reverb RI
    By denton in forum Mods & Tweaks
    Last Post: 11-25-2009, 06:13 PM
  5. Pulling tubes in a Classic 30?
    By glocker199 in forum Mods & Tweaks
    Last Post: 11-22-2009, 08:35 PM
Tags for this Thread
