Results 1 to 5 of 5
Thread: Getter flash spots changing over time
    Mar 2017
    10
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Does it indicate a problem or age, etc. if a tube (6550) starts to get a gray coloring around the side getter flash spots. It was totally silver when I first installed the tubes and now the edges are turning grayish.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	New Tung Sol Getter Flash Changing.JPG
    0 Not allowed! Not allowed!
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,435
    Thumbs Up/Down
    Received: 446/1
    Given: 0/0
    Generally means the vacuum inside the tube is going soft.
    Aug 2012
    Great Black Swamp
    1,804
    Thumbs Up/Down
    Received: 44/0
    Given: 130/1
    What's the time frame? Hours, months, decades?
    30,435
    Thumbs Up/Down
    Received: 446/1
    Given: 0/0
    All I can say is this:
    If you see a guy on the street, and his hair is turning gray. It tells you he is aging - whether it happened suddenly or over 20 years is hard to say.
    A white edge to the getter means air, however fast things inside are changing. SLow leak, fast leak, who knows?
    Chill-Ville, VA
    2,561
    Thumbs Up/Down
    Received: 110/1
    Given: 227/4
    Gas has gotten into the tube SOMEhow. Whether via vacuum leak or released because the tube was overheated, can't tell you. No way to predict life, either. Just keep a casual eye on it, in my opinion.
    Yes - what IS the timeframe?
    Justin
    "... If an older Boogie and classic Marshall had a (clearly illegitimate) child and you baked it in an oven set to clown shit crazy." - Chuck H. -
  1. Changing/Biasing Tubes for the first time in JCM 900 SL-X
    By samth3mancgp in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-09-2012, 03:13 PM
  2. Replies: 1
    Last Post: 12-10-2011, 04:45 AM
  3. Getter halo turned dull and brownish: tube still good?
    By slidincharlie (Carlo P) in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-23-2008, 09:33 PM
  4. Mesa Nomad Pots have dead spots, what's up with that?
    By SteveB in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-26-2008, 01:19 AM
  5. getter problems
    By Wakculloch in forum Tubes (Valves)
    Last Post: 02-01-2008, 12:54 AM
