Results 1 to 10 of 10
Thread: Wire Tension & Inductance
    Sep 2011
    Minneapolis
    284
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Understanding that higher tpl results in higher inductance, does wire tension likewise increase inductance with an increase in tension? Or is the other way around?
    0 Not allowed! Not allowed!
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,290
    Thumbs Up/Down
    Received: 347/5
    Given: 356/5
    Not TPL by itself but actual number of turns.
    Of course, if you fill up a coil form with higher TPL, rising wire tension so you can fit more in same space, then you can fit more turns there, and that is the proper parameter to consider.
    Apr 2015
    101
    Thumbs Up/Down
    Received: 4/0
    Given: 2/0
    Only marginally, as far as it reduces loop area and turns count.
    Sep 2011
    Minneapolis
    284
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thanks. I am puzzling over an original Filtertron that needs repair. The coil is wound so loose it's...surprising. And the inductance is lower than I would have expected. I would a replacement coil but the inductance was much higher so I'm trying to work out what's happening.
    Oct 2007
    10,290
    Thumbs Up/Down
    Received: 347/5
    Given: 356/5
    Well, you definitely wound more turns than what was previously there, thatīs for sure.
    Thereīs your difference.
    By the way, your rewind will also be hotter
    Feb 2010
    Just south of Bawlmer, Merlin
    2,365
    Thumbs Up/Down
    Received: 77/1
    Given: 56/1
    Look, in the sky! It's a bird! It's a plane! No, it's Kibbitzer Man!
    Quote Originally Posted by jrdamien View Post
    ...I am puzzling over an original Filtertron that needs repair...
    You know that the inductance of a coil is inversely proportional to its length, right? So (all else being equal) a tall bobbin will have lower inductance than a short bobbin with the same number of coil turns. But of course the biggest decider, inductance wise, is the relative permeability of the core material.
    IIRC, an original Filtertron coil would have about 3000 turns. How many does your replacement have?
    Shalom,
    rb
    EDIT: I see that Juan posted while I was tending the kugel.
    My mind is made up. Don't confuse me with the facts.
    - Dudley Do-Right
  7. #7
    Supporting Member mozz's Avatar
    Oct 2015
    NEPA
    564
    Thumbs Up/Down
    Received: 40/0
    Given: 27/0
    "So, all else being equal, a tall bobbin will have lower inductance than a short bobbin with the same number of coil turns.'
    I think you have that backwards. Tall bobbin, more surface area of the core for the wire to contact, higher inductance. A shorter bobbin will be fatter, thus the wire is further away from the core thus less inductance.
  8. #8
    Senior Member jack briggs's Avatar
    Oct 2007
    Raleigh
    258
    Thumbs Up/Down
    Received: 1/0
    Given: 4/0
    Quote Originally Posted by mozz View Post
    tell that to the P90 bobbin.......
  9. #9
    Oct 2015
    NEPA
    564
    Thumbs Up/Down
    Received: 40/0
    Given: 27/0
    So, all else being equal.............................
  10. #10
    Feb 2010
    2,365
    Thumbs Up/Down
    Received: 77/1
    Given: 56/1
    Quote Originally Posted by jack briggs View Post
    Huzzah.
    Yea, I was being intentionally ridiculous.
    But, ignoring that a pickup bobbin isn't really a solenoid, the inductance of a solenoid is really inversely proportional to its length.
    You'll have to ask a physicist to explain why, because I can't. (Not without slogging through some physics text, anyways.)
    Of course, this is all a red herring. I strongly suspect, along with Juan, that OP overwound his replacement coil.
    -rb
    EDIT: Forgot to put this in:
    - Dudley Do-Right
  1. Tension in wire
    By guitar_guy86219 in forum Beginner/ Hobbyist
    Last Post: 07-15-2013, 05:21 AM
  2. Understanding Wire Tension
    By Chris_H in forum Beginner/ Hobbyist
    Last Post: 05-17-2012, 12:55 PM
  3. Wire tension experiment
    By MrCandy in forum Pickup Makers
    Last Post: 09-16-2011, 09:11 AM
  4. Wire Tension and Tone
    By voodoochild in forum Pickup Makers
    Last Post: 05-30-2007, 09:00 PM
  5. Applying Tension According to Wire Manufacturer
    By kevinT in forum Pickup Makers
    Last Post: 05-03-2007, 02:06 PM
