Results 1 to 12 of 12
Like Tree8Likes
  • 1 Post By stokes
  • 1 Post By The Dude
  • 1 Post By JMMP
  • 1 Post By g1
  • 2 Post By JMMP
  • 1 Post By g1
  • 1 Post By JMMP
Thread: Tweed champ 5f2 pwr tranny swap
    Feb 2014
    New Jersey
    36
    Original tranny smokes and blows fuse with all secondary leads disconnected. Bought new unit, all is good save for the heater filament on the new tranny (magnetic components 40-18019). It's center tapped. Should I tape n tuck the center tap away and ground one side of the heater winding? Silly question, I should know this, figured I'd ask anyway.
    Thanks in advance.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,165
    No, ground the center tap, not one side.
    NYC
    1,648
    I would scrap the old single wire heater scheme and rewire with the quieter twisted pair.If you are talking about a vintage 5f2 that you prefer to keep original,then yes,just disregard the CT and wire it like the original.Just saw Enzo's response,if he grounds the CT and uses just one side,he'll only get like 3+v's.
    Justin Thomas likes this.
    Feb 2014
    New Jersey
    36
    Quote Originally Posted by stokes View Post
    So if I ground the center tap, I would need to lift the grounds on pin 2 on the 6v6 and pin 9 on the 12ax7, then do the twisted pair, correct?
    Feb 2014
    New Jersey
    36
    Quote Originally Posted by JMMP View Post
    Also, doing the heaters this way, how do you guys handle the pilot lamp (grounded to the chassis through the mount)? Seems easier to add the 2 100 ohm resistors, leave the CT tucked away and not attached, and ground one end of the 6.3v filament tap. Thoughts?
    Supporting Member The Dude's Avatar
    May 2010
    Sioux Falls, SD
    4,702
    FYI: The pilot lamp connections are isolated by fiber washers.
    g1 likes this.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  7. #7
    Feb 2014
    New Jersey
    36
    Quote Originally Posted by The Dude View Post
    Not on this model, indicator is just another parallel filament connection, lamp body goes directly to chassis ground through mount.
    The Dude likes this.
  8. #8
    g1
    g1 is offline
    Feb 2010
    9,336
    Well, if you are not going to change the indicator, then you have to leave one side of the heaters grounded, no CT, no 100 ohm resistors.
    Certified Dotard
  9. #9
    Feb 2014
    New Jersey
    36
    Correction, lamp is exactly as pictured there. One tab was rotated, bent and soldered to mount and I didn't look closely enough. Thanks for all the help!
    g1 and The Dude like this.
  10. #10
    g1
    g1 is offline
    Feb 2010
    9,336
    Just to clarify about your question in post #5, you can't use the resistors and ground one side of the supply.
    You must choose only 1 of the three options:
    a) CT
    b) 100R resistors (virtual CT)
    c) One side of heaters grounded
    Certified Dotard
  11. #11
    Feb 2014
    New Jersey
    36
    Quote Originally Posted by g1 View Post
    a) CT
    Got it G1, thank you. Gonna ground one side of the supply.
  12. #12
    Feb 2014
    New Jersey
    36
    Worked out great, Champ is now working as it should!
    g1 likes this.
  1. Voltage Chart for the Tweed 5f2-a
    By marcbo77 in forum Debugging Your Build
    Last Post: 11-04-2009, 10:15 AM
  2. Stock 5F2-A Power tranny values?
    By ncusack in forum Tweed Builders
    Last Post: 08-01-2009, 09:53 PM
  3. Power Tranny Swap
    By ajeffcote in forum Mods & Tweaks
    Last Post: 02-16-2008, 07:38 AM
  4. More Pwr and Headroom for SF Champ
    By JPH in forum Mods & Tweaks
    Last Post: 08-11-2007, 11:24 PM
  5. More Pwr and Headroom for SF Champ
    Last Post: 08-11-2007, 03:55 PM
