Results 1 to 26 of 26
Thread: Yamaha Disklavier power supply help - schematic attached
    Dec 2017
    15
    Hello! Long time lurker who has fixed a lot of electronics with help I've found here. My ability level is decent. I can almost always solve problems when there is a smoking gun (burned parts, blown fuse, etc). I can often solve issues with no visual clues by reading a schematic. This power supply is a little beyond my grasp.
    Where I'm at: all fuses check out good. None of the protect relays are closing. I've been concentrating on trying to trace out RY1 in the upper left of the schematic. Q1 has 17.5vdc on it No power on the Q2/Q3 darlington pair. I'm having trouble understanding how they are supposed to be powered. It looks like it connects to the 100V rail near Fuse F2 on the right side of the schematic. Does it get dropped down by the 100k resistor (R1)?
    I'm only seeing low voltage on the C13 side of the bridge rectifier. I think that should be closer to 100V. It starts out at 15V and slowly charges the caps. That seems to make sense because RY1 is not closing to put power into that part of the circuit.
    As you can see, I've worked my way into a circle unable to figure out why RY1 won't close.
    Schematic for the PSU is on the lower left of the page.
    Attached Files Attached Files
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,151
    Q1 has 17v on it WHERE? Q1 has three terminals. RY1 will never function unless that voltage appears on the collector. We have to turn on Q1 for that to happen. Follow the base lead over to SW+, right next to it is SW-, which leads me to think the power switching shorts them together?
    g1
    g1 is offline
    Feb 2010
    9,334
    Also, if you are not familiar with the special safety considerations for SMPS type supplies, please do some reading about them.
    Certified Dotard
    Dec 2017
    15
    Hi Enzo. Thanks for the reply! Q1 has 17'ish volts on the Emitter (connected to D2), and on the base. 0.0v on the collector as you surmise. This power supply is from of my Mother in Law's piano and it is all I have in my possession. The piano, and computer box is a couple hundred miles away, but I'll be visiting the piano and in laws for the holidays.
    It was the piano technician who told her/me it was a power supply issue.
    I gather that you suppose the SW+ and - are indicative of a SWitch. The SW terminals are on a ribbon connector, which leads to another chassis that I don't have.
    Just to be clear, the next step may be jumpering the SW+ and - terminals and see what the supply does?
    Dec 2017
    15
    I definitely would like to learn more about these switching supplies. Do you mean that there are special safety considerations for working on them, or safeties inherent to the electronic design? Or both?! I'm fairly comfortable working around high voltage supplies, having fixed quite a few tube amplifiers.
    Where is a good place to start?
    Dec 2017
    15
    Just to update, I followed the schematic to another page (not on the small PDF I posted) and the PS terminals do indeed lead to the power switch board. Momentarily touching the contacts does cause at least one of the relays to trip. Time for more checks.
    I'll also say that what caused this system to malfunction was a the piano being in a bad highway accident while being transported. It's very possible that this power supply will end up being fine and the problem being with another part of the system. Maybe just a connector unplugged in the box I don't have here!
    Last edited by VintageValves; 12-07-2017 at 07:54 PM. Reason: Fix quote formatting
  7. #7
    Dec 2008
    Wernersville, PA
    11,963
    Quote Originally Posted by VintageValves View Post
    Here is a good primer: SMPSRM-D.PDF
  8. #8
    Dec 2017
    15
    Thank you Jazz P Bass. I'll need some time to read that carefully and digest it.
    With RY1 closing, I am getting power to more of the circuit now, but not much more.
    I find 170V on the filter caps C13 and C17. I get power to the primary side of T2 as follows:
    1. 160 vDC
    2. 160 vDC
    3. 155 vDC
    4. 153 vDC
    5. 151 vDC
    6. 152 vDC
    7. 123 vAC
    8. 123 vAC
    I find no voltage (AC or DC) on the secondary side. Of course the transformer won't pass DC... Seeing all that DC at the input of a transformer is suspect to me. Is IC1 suspect? I pulled the heat spreader off and it looks like a modular device called 'Power Stream.' Working on extracting it to see if I can find a part number/datasheet.
    Quote Originally Posted by Jazz P Bass View Post
  9. #9
    Dec 2017
    15
    IC1 is a Powerstream XK413A0 - Can't seem to find a datasheet... Looks like they are available for $50'ish if necessary. Should I be checking something else first?
  10. #10
    29,151
    Your friend diagnosed a power supply problem, but he didn;t understand the system it is part of. I surmise a switch elsewhere just because Yamaha usually labels things intelligently, and the circuit made sense. If a relay clicked, make sure it is the relay we have been looking at. That relay closing applies power to the primary circuit, then there is right after it a soft start relay, which the triac shunts after power comes up.
  11. #11
    Dec 2017
    15
    Yes, the report of a faulty power supply should definitely be taken with great suspicion. The person is an instrument tuner / technician, who likely has zero electronic knowledge. I'm not sure if he has even worked on Disklaviers before. I suspect that the piano did not turn on and he immediately suspected the power supply and gave up.
    RY1 is certainly the relay which is closing when I short the SW terminals as evidenced by power being measured in first filter caps. I'm assuming that RY2 is the soft-start relay you have mentioned. Is it correct to say that in order for RY2 to function, there would need to be power on the secondary side of T2? I don't seem to be getting any there as mentioned above. Thanks for your continued guidance.
    Your friend diagnosed a power supply problem, but he didn't understand the system it is part of. I surmise a switch elsewhere just because Yamaha usually labels things intelligently, and the circuit made sense. If a relay clicked, make sure it is the relay we have been looking at. That relay closing applies power to the primary circuit, then there is right after it a soft start relay, which the triac shunts after power comes up.
  12. #12
    Dec 2017
    15
    I should also note that the schematic posted is not for the same exact model. The service manual for the piano this came from (a Mark IIXG) does not have a schematic for some reason. I believe that it uses the same or nearly the same power supply as the one I shared (MX1Z) because the layout diagram in both manuals looks to be the same. Further, the next generation Mark III piano service manual has the same layout and schematic as the MX1Z).
    What is a little puzzling is that all three of the layouts show IC1 being a 16 pin device (which it is on my board), but the schematics for MX1Z and Mark III show 21 pins? I'm also a bit puzzled about C16 - I can't find on the schematic. It's connected to the bridge rectifier (D4) and pin 15 of IC1. Big filter cap the same size of C13. Looks to be a negative rail.
    Any thoughts and guidance are appreciated.
  13. #13
    29,151
    Remember we mentioned the danger? it stems from the fact the mains are directly rectified into DC. Generally that means a result of about +170vDC and -170vDC with respect to earth. Moreso, the control circuits on the primary side are using the -170 rail as its reference or common. In other words the primary side "ground" is really -170vDC with respect to earth.
    So one could unsuspectingly clip a scope probe to what looks like "ground" and either short out the supply through the earth connections of scope and unit, or if the scope is isolated, put -170vDC on the frame of the scope. Not saying you did that, but your voltages in post #8 make me think you used chassis ground - earth - as your reference for the readings. real readings would be made against that -170v rail.
    The secondary side IS referenced to earth/chassis/ground.
    One thing I do is lay my scope probe right against the T2. Not making electrical contact, just picking up any radiated field. I do this to detect if any action is occurring there.
  14. #14
    Dec 2017
    15
    Thanks Enzo for that information. I definitely could have made a mistake without it. I did gather that the mains were being directly rectified with no transformer isolation! Thus far all my measurements have been with a DMM, using the PCB earth points as reference. I do have a scope (Analog, Hitachi V-750F), but I mostly have used it for tracing out audio paths in amplifiers. I did try to view a few of the reference traces on the schematic on the secondary side. Of course, the secondary side is not turning on, so I don't think I did any harm! I'll retake my readings in post #8 referencing the -170 rail and post results later. I'll also see if I get anything by laying my scope probe over the coils of T2.
    What is the function of IC1 just before the primary side of T2? Stock photo from Google images:
  15. #15
    29,151
    IC1 is pretty much the whole primary side. It is one I have not worked with, but looking at it and hte schematic, it is a hybrid like one of the old STK series audio power amps. It would have the control circuits as well as the transformer drive transistors all in one part.
    Your meter will be OK for DC readings, but unlike a linear supply that works at 60Hz or 120Hz, switching supplies work at very high frequencies, like many kilohertz, and on AC it is likely your meter wouldn't respond to it anyway. This is scope terrirtory.
  16. #16
    Dec 2017
    15
    That's kind of what I figured. If I'm getting power up to IC1, and the primary side of T2, but not after - would you suspect IC1 as being the defective part? They're available for around $50....
  17. #17
    29,151
    The mains are rectified into +/-170v, centered around the earth. So if the thing isn't running, I still am not surprised if you see 170 or there abouts to earth on the terminals there.
    I do suspect that IC, at least from here, but it is your money I am speculating with.
    On many systems there are protections. A shorted rectifier on the secondary - and do check them all - can shut down a switcher. I don't see a feedback path from secondary to primary - normally done with an optocoupler to maintain separation. But the big IC could be sensing draw through the windings of T2.
    One test to make is to watch closely to see if there is a momentary voltage spike right at powr up from any secondary output. Like the thing starts up, sees an overload, and instantly shuts down. Maybe a brief flicker of power light.
    Also possible something out there is loading the system down. remove fuse F2, do the +8 and +20 return? Pull F3, does +20 return? Disconnect the two connectors on the right edge of the PS drawing, do the voltages now appear on those bare connectors? Just looking to see if ther is any way the IC is not at fault.
  18. #18
    Dec 2017
    15
    Thanks Enzo. This is exactly the guidance I need to do some more troubleshooting! I'll try these steps and report back later.
    I do want to note that the connectors on the right side of the schematic are disconnected, because I don't have the full system here on my bench. All I have is the PSU, the connectors jump out to the rest of the piano...
  19. #19
    Dec 2017
    15
    I'm back. Had to take a break from this over the weekend.
    Pulling the fuses one at a time did not get me any power out of the 8v, 20v or HV outputs. I tried power cycling the supply each time. I only have the power supply here, so the terminals are bare except the jumper I put across SW+ and SW-
    No blips to the outputs upon power on - there is no power light on this box. There is definitely no action from the RY2 soft start relay either.
    I did not see AC on my scope with the probe laid across the transformer. I have it set on 5mV and get no action there. Super interesting to know that my my multimeter won't be helpful on the switching side of things. I'll get a some action on the big power choke on the input.
    I did diode check on the Triacs after the T2. I was able to remove and test D6, D7, and D8. All are good. D10 I had to check in-circuit as it and the components around it were fairly glued in. It tested as Expected with forward voltage one way, and ascending voltage as a cap charged the other direction.
    Anything else to check before replacing IC1?
  20. #20
    Jan 2018
    3
    Hi VintageValves,
    I have been watching this thread with interest. I have a Yamaha Disklavier MX100II that also appears to have a power supply issue.
    Just wondering if you replaced IC1 and if that fixed your issue. Thanks.
  21. #21
    Dec 2017
    15
    Quote Originally Posted by DownSizing View Post
    Hi VintageValves,
    Hi there! I have yet to replace IC1 on this PSU. There was some delay with receiving the device (from ebay seller BocaSemi). They did not have it in stock and had to source it. It arrived just before I departed for Christmas vacation with my family. I got sidetracked on some other easier projects (Including a full rebuild on a Mesa/Boogie D-180).
    I have the part, just haven't found the time to do the swap. I hope to get to it this week.
  22. #22
    Jan 2018
    3
    Thanks for the reply. Good luck with the installation and please post back - hopefully it will solve the problem.
    Interesting comment by Enzo: "That relay closing applies power to the primary circuit, then there is right after it a soft start relay, which the triac shunts after power comes up."
    I am suspecting that my unit may have been damaged during a storm. When the unit was working, there was an click (the primary circuit probably) followed by a click, but not as pronounced (soft start relay?). Now all I hear is the initial click and the unit does not power on. I am planning to order the part. I want to sell the piano and it would be really nice to have the Disklavier working. Definitely worth the $60 gamble.
  23. #23
    Dec 2017
    15
    Progress....
    OK! So I got motivated and swapped IC1. Upon startup something rather excitingly threw a spark tiny spark. Not sure what from. I powered down, caught my breath, checked fuses and tried again. The supply is definitely doing more now than before the IC1 swap. There is a lot of whining (like you'd hear in an old CRT TV). Maybe a disconcerting abnormal amount. Perhaps it doesn't like getting run without a load? As mentioned previously 1.) I only have the bare supply in my possession - no piano or brain box 2.) I have very little SMPS experience.
    My wife summoned me inside, so I didn't have a chance to do any further voltage checks.
    I should also note that the part that BocaSemi sent is not a perfect match for the one I replaced. The main part number XK413A0 matches, but there are two other numbers that are different. The leads on the new part are shorter which prevented it from being mounted with it's mounting clip. Maybe there is something different internally too (hopefully not). I haven't been able to find any datasheets for this part. See attached photo. xk413a0.jpg
  24. #24
    29,151
    Date codes or lot codes.
  25. #25
    Dec 2017
    15
    I plugged it up again today. Lots of whining... By the time I could get my meter on it, I saw the Kill-A-Watt go from 2A to 3A (KAW update is real slow) and then I heard a quiet tick, and now I think I'm back to square one... I'm out of time for the next week to work on it, but may revisit.
    I found a SMPS repair place on the internet who says they have repaired this supply before. I suppose I may have to send it in... I'm close to wits end on this and have lots of things around that I know I can actually fix. I'll have to include a sob story about how my friendly local tech couldn't figure it out. Too embarrassing to admit failure. 61dhvw3gwjl._sl1500_.jpg
  26. #26
    Jan 2018
    3
    I found a SMPS repair place on the internet who says they have repaired this supply before. I suppose I may have to send it in... I'm close to wits end on this and have lots of things around that I know I can actually fix. I'll have to include a sob story about how my friendly local tech couldn't figure it out. Too embarrassing to admit failure. Click image for larger version.
    I spoke with Yamaha service in CA and asked about sourcing the IC from them. They don't source parts at the component level and the P/S itself has been obsoleted. However, they pointed me to their authorized service center that repairs this supply. I called the service center (Tap Electronics) and was told they do the repair for a $200 flat fee. They also stated they are 100% certain the issue is the p/s.
  1. Yamaha EMX512SC power supply
    By Jeff907 in forum Music Electronics
    Last Post: 11-28-2017, 11:39 PM
  2. Yamaha Analog delay pedal power supply.
    By dyn in forum Guitar Effects
    Last Post: 12-13-2012, 10:06 PM
  3. Tone circuit - schematic attached
    By EFK in forum Theory & Design
    Last Post: 05-09-2009, 07:38 AM
  4. Power Supply - Schematic attached
    Last Post: 04-30-2009, 06:27 AM
  5. Need schematic for a Yamaha P2050 power amp
    By Twist in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-15-2008, 01:39 AM
