Results 1 to 11 of 11
Like Tree4Likes
  • 1 Post By Enzo
  • 1 Post By Mick Bailey
  • 1 Post By Mark Hammer
  • 1 Post By waspclothes
Thread: Any Good Limiter Schematics? (no clipping)
    Aug 2011
    161
    So I shot my mouth off a bit.. Let me explain.
    My bass player friend just got a new amp, but said he misses the Limiter that's built into his old Ampeg head (SVT-350H I believe). I said that it would be "very easy" to build a similar limiter into a pedal for him that he can use in his new amp.
    So far I've been unable to find any schematic for the 350H (let alone one with the compressor section circle and labelled "copy this part!") and other limiter circuits I've been finding online seem to just clip the signal to hard-limit it, or some have adjustments that the SVT limiter does not have. From what I could tell, the SVT limiter just allows a signal through without issues until it reaches a certain threshold and then attenuates it to match that. It seems to do it very transparently as well. Anyone have any schematics for this?
    Chill-Ville, VA
    2,254
    I didn't scour the schematics, but do any of the ones Enzo put here help?
    Ampeg SVT -350H schematic
    Justin
    "Are you practicing in the lobby of the municipal library? It's still a guitar amp and it SHOULD make some noise (!!!)" - Chuck H. -
    Apr 2015
    87
    Opto? That might be a bit slow for a bass limiter in my view...
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    9,443
    Well,thatīs what actually is inside the SVT350 and what waspclothesī friend is missing.
    But not sure about a pedal version; if anything a Rack one ... or at least some box standing on top of his current head (which we IGNORE, Mr Waspclothes ... ) inerted in his loop .
    You need +/-15V for this limiter to work.
    IF you want to build this one, Iīll suggest what schematic section to crop and build.
    9V single supply is a very limiting factor so foot pedal compressor/limiters are more toys or gimmicks than serious stuff.
    EDIT: and for transparency and good effect limiters need to be at an amp point where signal level is relatively high (definitely not instrument level) and after most gain and EQ so it only cares about peak level and nothing else.
    Dec 2007
    Poland
    1,511
    I'm not sure what exactly is the problem. If you search in google for "bass compressor schematic", you get hundreds of good bass compressor schematics supplied from +9V, usually they are build using opto. One of the best is Demeter Compulator but there are also many others. Demeter Compulator is very simple but it is used in many recording studios to get vintage-type compression.
    If you set minimal compression, it will work as limiter. Or, you are looking for something else?
    Mark
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    28,926
    Isn't the holy grail of compressors, the LA-2A based on optos?
    J M Fahey likes this.
  7. #7
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    4,456
    True, and the light element in the original LA-2A is a swatch of electroluminescent panel (tape). In reissue versions I don't know what they use, I haven't been inside one.
    One problem with bass and compressors/limiters is if the attack time constant is too short, the sensing circuit can mistake the waveform for the envelope and do some very strange things to the sound, so approaching the comp/limiter as a "leveling amp" is appropriate. Same story for bass from synthesizers, not just bass guitars.
  8. #8
    Apr 2015
    87
    LDRs (optos) tend to have very fast attack and slow release, say a couple of ms attack to hundreds of ms or more than a second release. That's fine for many compressors.
    For limiters in strict sense you'd expect a relatively fast attack (yet 20ms is still fine and does not distort bass freqs as much) with a fast release, say <100ms.
    Just my 2c, not saying it is a very big deal.
  9. #9
    Supporting Member
    Dec 2009
    UK
    2,975
    The 350H limiter has a number of issues that need to be considered in relation to a pedal build. Firstly, the 'sense' line is taken from the power amp output (labelled 'output' on the schematic). So it needs a high-level signal to drive it and isn't the usual signal-in/signal-out pedal arrangement. Secondly, there's no level adjustment so it's pretty much fixed around the 350H circuit levels.
    For my money, if I was taking this approach I'd use a Rod Elliot type of design, which is powered off the amp's output and requires no additional supply. I've built this using an NSL32SR2 optocoupler with no issues whatsoever - 2Kv isolation and fast response time.
    diydidi likes this.
  10. #10
    3,513
    The SSM2166 chip is still available from Small Bear electronics and probably a few other places. It is the engine of a high-quality control strip, that can be used as a compressor or limiter. It also includes a downward expansion function for use as a sort of noise gate. IN short an extremely quite, and quiet-capable, chip, that requires very little in the way of external components to be a full-fledged dynamics processor.
    darkfenriz likes this.
  11. #11
    Aug 2011
    161
    Quote Originally Posted by Mark Hammer View Post
    Thanks Mark! I see the LM13700 datasheet also shows a schematic for an "Automatic Gain Control" But I don't think it can be tweaked to ensure it works great with bass. I might breadboard it though since I have a few of those chips around.
  1. Fender Twin Reissue - No Power, Good Fuses, Inrush Limiter Seems OK
    By CKuzGuitars in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-18-2013, 10:17 AM
  2. Clipping ciruit idea: Good? Bad?
    By Koreth in forum Guitar Effects
    Last Post: 11-24-2009, 06:06 AM
  3. Good FREE CADware (schematics, layout) - KiCAD
    By Don Moose in forum Fun with computers
    Last Post: 07-25-2007, 10:01 PM
  4. good Mark IIC+ schematics?
    By spinalhack in forum Build Your Amp
    Last Post: 01-20-2007, 09:22 PM
  5. Replies: 3
    Last Post: 10-12-2006, 11:40 PM
