| | #1 |
| Junior Member Join Date: Sep 2007
| Pro Reverb mystery
Hi all, I have an early 70's Fender Pro Reverb with no master volume or mid controls. It sounds not so good. The bass is not tight and really not all that present. When I adjust the EQ to get the bass in the ball park, the treble strings are ice pick bright. It's not the guitar or the speakers. I just did a recap and it didn't really have any impact on this problem. Any ideas? Also, Where can I go to get schematics for this or the blackface version? Someone told me that it is the same as the Super Reverb but when I compared them my parts didn't match up. Thanks |
| | #2 |
Try here http://www.schematicheaven.com/fender.htm or here http://www.ampwares.com/ffg/ for schematics. |
| | #3 |
| Thanks
Thanks.
| | #4 |
| Things that go
bump. Still would appreciate some trouble shooting tips, tubes are good, speakers good, just did recap... so why is it so dull sounding? |
| | #5 |
I'd gop through the amp stage by stage to see where it loses tone. An open coupling cap or connection thereto would remove a lot of bottom, since all you'd be hearing was the crosstalk.
| | #6 |
| Senior Member Join Date: Jun 2006 Location: Southern french alps, right by the Italian border
May be simply the .1 cap in the tone stack. Does it on both chanels? Or just one?
| | #7 | |
| Member Join Date: Oct 2007
| Quote:
Inside the amp, on one side wall should be a paper sticker with the tube ID on it, that should also have the circuit used printed at top. If not, check the rectifier tube. The AB668 circuit used a GZ34 and the AA 1069 used a 5U4. They use entirely different transformers, and are not interchangeable, so the rectifier tube should be a good indicator of which circuit you're dealing with. A silver face Fender without any bass is definitely not right, most have way too much boomy, out of control bass. I had to modify the tone section of mine to get the bass under control, changed out one cap and it's great. So I would say enzo is on the money, I was thinking tone section caps too but I'm no amp tech...and if the "Bright" switch is on, yeah that thing is going to be really bright...I can't run the treble above about 5 or 6 onstage and it's running enough treble to just about cut glass... | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| marshall 800 mystery/problem | toggle | Maintenance, Troubleshooting & Repair | 12 | 01-16-2010 05:51 PM |
| Reverb noise in Fender super reverb 65 (vintage) | albania | Maintenance, Troubleshooting & Repair | 8 | 09-24-2007 06:35 PM |
| It's A Mystery: LFO Clicking | heyniceguy | Guitar Effects | 4 | 11-02-2006 05:00 PM |
| It's A Mystery: Nasty Sounding Tube OD | heyniceguy | Guitar Effects | 1 | 11-02-2006 01:34 PM |
| It's A Mystery: Bad Compander? | heyniceguy | Guitar Effects | 1 | 11-02-2006 01:30 PM |
