Results 1 to 3 of 3
Thread: ground wire not connected
    Supporting Member Randall's Avatar
    Jan 2013
    Cape Coral, FL
    1,348
    A 70's Japanese Ric bass knock off with odd pick ups came to me recently. Both pickups made sound, but were weak and noisy. Much to my surprise, I found neither had it's shield connected. One was severed at the pickup, and the other at the tone pot. They sounded a lot better once I connected them both, but how is it even possible that they even worked at all that way?
    Supporting Member
    Sep 2007
    2,873
    Quote Originally Posted by Randall View Post
    Since the input impedance of the amp is is high, stray capacitance lets some signal through, but the bass must have been dreadful.
    788
    It's true -- I test pu's with alligator clips and run into the same noisy-with-surprisingly-significant-signal-level thing and discover the clip holding the ground lead on has unclipped.
  1. Humbucker - no output when ground wire connected
    By TheGrateOz in forum Pickup Makers
    Last Post: 12-04-2012, 06:01 PM
  2. 6-wire (+ground) 3-Speed Fan Motor... help!?
    By verhoevenc in forum Tools and Coil Winding Gear
    Last Post: 02-28-2011, 04:12 PM
  3. Ground Wire: buss wire vs. copper?
    By mook in forum Theory & Design
    Last Post: 05-16-2010, 11:29 PM
  4. Wiring problem ('floating' ground wire)
    By slidincharlie (Carlo P) in forum Guitar Tech
    Last Post: 02-21-2009, 06:33 PM
  5. Replies: 5
    Last Post: 11-01-2008, 05:37 AM
