Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By The Dude
Thread: Wiring help
    Jan 2018
    2
    Wiring help
    Iím building an interesting Strat style guitar and the guy Iím making it for is asking for something I havenít done before. Weíre putting an Invader in the Bridge position, a JB Junior in the middle, and a Hot Rails in the neck. He would like to have a Coil split pot on all three knobs in the same order as the pickups. Iíve wired a single split before but not all three. So 5 way switch, standard Strat knob arrangement and basically three humbuckers. Has anyone done this?
    Supporting Member The Dude's Avatar
    May 2010
    Sioux Falls, SD
    5,278
    Welcome to the place!
    I would just use 3 push/pull pots- one for each pickup. Wire each coil split on each switch the same as you've done in the past when you did just one pickup.
    Chuck H likes this.
    ďYeah, well, you know, thatís just, like, your opinion, man.Ē
    Jan 2018
    2
    Thanks Dude! Thatís what I was thinking. I suppose I need to sit down and draw it out.
    Supporting Member Steve A.'s Avatar
    4,880
    Before hardwiring the p-p switches I always recommend checking out how it sounds. On a strat you can run the cables under the pickguard, or remove a pot and run them there.
    One option to consider for other custom wiring jobs is a 4PDT mini-toggle switch which could do the series/parallel switching for 2 humbuckers. And with an ON/ON/ON switch you can do series/split/parallel switching.
    FWIW I think I've had better luck doing S/P switching on strat-sized humbuckers than full-sized ones...
    Good luck!
    Steve A.
  1. Replies: 5
    Last Post: 01-17-2017, 09:26 PM
  2. Series heater wiring, series/parallel heater wiring
    By diagrammatiks in forum Theory & Design
    Last Post: 05-11-2011, 01:14 PM
  3. I need help with old wiring.
    By htebreeder in forum Guitar Effects
    Last Post: 01-06-2011, 04:36 AM
  4. Need help with wiring...
    By mdelahoussaye in forum Music Electronics
    Last Post: 02-12-2010, 01:19 AM
  5. i really could use so help with h-h wiring
    By fenderman7787 in forum Guitar Tech
    Last Post: 09-16-2008, 04:54 AM
