Results 1 to 3 of 3
Thread: Kapton shielded cable
    Jun 2017
    England
    102
    Anyone on here ever used kapton shielded cable ? Just got hold of some 24awg silver plated kapton shielded cable and wondered if it would be any good for signal runs looks really high spec!!! Nice shield not as flexible as normal 174 but looks really nice??
    Old Timer tedmich's Avatar
    Apr 2008
    Sonoma CA
    3,111
    Kapton insulated cable perhaps?
    I like Kapton, with the silver plate its likely to be Mil. spec and as such probably fairly old, I believe kapton (polyimide) insulation has been forbidden in Mil. wires for quite some time. When Swiss Air flight 111 went down near Nova Scotia (1998) the kapton wire flash over was suspected, but hey teflon insulated wire probably brought down TWA 800 (1996) but its one of my favorites
    Modern avionic wire now often combines soft teflon polymer with a harder shell polymer like PEEK or tefzel but kapton is fine for amps etc. IMHO.
    Jun 2017
    England
    102
    Yeah done a bit of research on the stuff and looks like it has a 100 hour fail time due to hardening of the coating causing "failure" many planes had to rewired apparently so maybe not the best stuff to use maybe covering the kapton with heat shrink could avoid any problems? But on the plus being a dustcart (garbage lorry) driver I occasionally stumble across things people have thrown away that I keep and today I found this cable in the rubbish ( trash ) all bagged up and as good as new result !!!20180124_180035.jpg
  1. Shielded cable
    By Jarvini in forum Guitar Amps
    Last Post: 10-04-2017, 09:58 PM
  2. Shielded cable
    Last Post: 10-02-2017, 08:49 PM
  3. stripping shielded cable
    By scole in forum Theory & Design
    Last Post: 07-21-2009, 04:18 PM
  4. Shielded Cable
    By Amp Kat in forum Theory & Design
    Last Post: 12-03-2008, 07:16 PM
  5. Shielded cable
    By mbach72 in forum Build Your Amp
    Last Post: 02-23-2007, 06:28 PM
