Results 1 to 34 of 34
Like Tree7Likes
  • 2 Post By The Dude
  • 2 Post By Enzo
  • 3 Post By Valvehead
Thread: DSL 401
    Feb 2007
    1,200
    DSL 401
    The dreaded jcm 2000 ..... This is the 401 with el84s. Have a big short or current draw . Not the tubes...but only does it with the el84s in (new ones and the old set) , If i pull the heater fuse F4 , for the el84s and PI , it goes away . R34 / 35 test good.
    I measured the resistance of the secondary of the PT with nothing hooked up to it -
    HT pins = 36 ohms
    Bias pins = 10 ohms
    Fil. pins = short / 0.0 ohms
    that filament winding shouldnt measure 0 right ??
    http://www.thetubestore.com/lib/thet...-Schematic.pdf
    Supporting Member The Dude's Avatar
    May 2010
    Sioux Falls, SD
    4,702
    It probably won't measure much. Consider how much less wire that winding has than the HT winding. Then consider you have a bunch of filaments in parallel with it.
    Edit: It doesn't track with, "only does it with the el84s in", but those amps are notorious for problems with BR1. It is for the DC filament supply of the V1-3. They are usually intermittent or open, but a shorted one wouldn't surprise me. They run very hot. The rectifier is supplied by the filament winding, so it does track with, "If i pull the heater fuse F4 , for the el84s and PI , it goes away.". It's worth checking anyway as it's a common problem. If you end up needing to replace it, stand the new one off the board a bit to keep heat away from the solder joints and board.
    J M Fahey and Tone Meister like this.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
    Supporting Member
    Dec 2009
    UK
    3,025
    With the power tubes removed check your DC voltages on the EL84 sockets. Do you have bias voltage?
    Feb 2007
    1,200
    yes .
    -90 mv
    g1
    g1 is offline
    Feb 2010
    9,338
    You should have something more like -15VDC at pin2 of the power tubes.
    Attached is the rest of the schematic.
    Attached Files Attached Files
    Certified Dotard
    Feb 2007
    1,200
    sorry -- brainfart here... its -17vdc at 1 pair of sockets .. and 0 mv at the other pair . pin 2 . The four 10k res that feed those are all good .
    It looks like i have a different board- mine is labeled DL40-60-00
  7. #7
    Feb 2007
    1,200
    i forgot i had the same model amp acting up a few years ago---found my post on it here . Ill go through all that first
  8. #8
    May 2010
    Sioux Falls, SD
    4,702
    Here's a thread w/similar problem.
    JCM2000 DSL401 lost bias voltage on V4, V5
  9. #9
    Feb 2007
    1,200
    ok guys....after a lot of testing / looking and such... i found a broken trace to V5/6---the bias feeding R84/85. I repaired that and i have -17vdc at all the sockets now. I need to piece it together and fire it up on the current limiter...will do tomorrow...its 2:46 am now......................
  10. #10
    Feb 2007
    1,200
    Update---
    amp is up and running now , bias is great , have hv to all tubes and filiment volts ac and dc .
    no smoke or fire yet.
    Since this amp is possessed...i now have a new problem = no signal when on the orange or red channels (dirty) . The green channel works fine . The relay is clicking / switching but i dont have the dirty side of the preamp . No signal...
  11. #11
    Feb 2007
    1,200
    Can someone tell me what kind of voltages i need to see at T9 / 12/13/14 ? Could one of those kill the ch.2 signal from getting to the relay ? Are they used to mute ?
  12. #12
    Supporting Member Randall's Avatar
    Jan 2013
    Cape Coral, FL
    1,380
    If you found broken traces, does that mean you had to lift or flip the board? If so, check very closely for any and all wire connections that could have broken in the process from flexing.
  13. #13
    Feb 2007
    1,200
    ill have a look , but its all pcb mount sockets..most wires are from the PT .
  14. #14
    Feb 2007
    1,200
    Im not finding the problem--tried replacing T9 , a j174 , it looks like the OD mute ? Or am I way off ?
    In OD mode i tried touching the grids even the phase inverter with an insulated screwdriver to see if i had any noise or buzz......nothing..
    I would think i would hear some noise down towards the end of the preamp
    checked the solder joints---even chopsticked the hell out of the board
  15. #15
    g1
    g1 is offline
    Feb 2010
    9,338
    On page 2 of the schematic in area C-3. There are lines called ODMUTE, V2A-IN, OD1G1.
    Check that they are changing in voltage depending whether clean or dirt.
    Have you tried with the footswitch or are you using the panel switches?
    Certified Dotard
  16. #16
    Feb 2007
    1,200
    Quote Originally Posted by g1 View Post
    i will check that--
    no fsw--the panel switches seem to switch the relay fine--i can hear it click --just no OD signal
  17. #17
    Feb 2007
    1,200
    ok....
    if volts change - here we go,
    ODMUTE ---YES
    V2A-IN = YES
    OD1G1..... which leg is the gate ? looking at the transistor, flat facing me ...the left leg - yes , the middle leg = no , the right leg =yes
  18. #18
    Dec 2008
    Wernersville, PA
    11,967
    J174 P Channel Jfet: D G S
    A Jfet is normally 'closed' D to S.
    It needs the gate voltage to 'open' it.
  19. #19
    Feb 2007
    1,200
    ok...what am i missing-------the gate connection goes nowhere on the scem..?? ?? im going to go trace it ..
  20. #20
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,178
    No, the schematic says the gate connects to OD1G1. Look on the other page just right of T10,11. There is OD1G1 right beneath CLNG1.
  21. #21
    Feb 2007
    1,200
    i just found it while you posted---sorry...
    so we need voltage from T2 yes ? and im looking for 24v or bit lower ?
    sorry , trying to get these transistors--so these are sending signal to ground when they are switched in?... now i see T10 called ODmute
  22. #22
    Feb 2007
    1,200
    Im lost. Heres what Im getting , testing the j174's with the amp fired up and switching channels -
    T9 (j174) gate has 20v clean or OD
    clean -- D+S = 47K
    OD D+S = 47K
    T2 (mpsa13) HAS 28V , CATH OF D18 HAS 20V CLEAN / 0V IN OD
    T10 (j174) GATE HAS CLEAN = 0V / OD 19V
    CLEAN D+S = 43 OHMS
    OD D+S = 300K
    T11 (j174) GATE HAS CLEAN 0V / OD = 18V
    CLEAN D+S = SHORT
    OD D+S = SHORT
    shouldnt T11 open with that 18v ??
  23. #23
    Stray Cap DrGonz78's Avatar
    Oct 2011
    Scottsdale, AZ
    1,709
    Just a quick question... Have you cleaned the JS-1 foot switch jack? I figured you probably did but just had to ask.
  24. #24
    Feb 2007
    1,200
    Quote Originally Posted by DrGonz78 View Post
    yes--ill hit it again to be sure
    so if T10 is getting its gate voltage...it should "open" , ? because i have 1 leg going to ground still --is that it maybe ?
  25. #25
    29,178
    T10 seems to be working. With zero v on the gate the JFET reads 43 ohms - a low resistance. Put 19v on the gate for OD, and resistance goes up to 300k.
    T11 is controlled by the same gate signal, and so I expect it to behave the same as T10. Looks bad.
    T9 always had gate voltage? Then go back to OD!G! source and find out why. Remember to plug something into the input jack, because it has a mute contact involved with this. Empty input jack and R100 is grounded at the top, and that is the 47k you are reading, I'd wager. meanwhile I'd expect T9 to still vary once that is corrected. it looks like it isn't. SO I suspect those two transistors at this point.
    The MPSA13 is bipolar and doesn;t test this way.
    g1 and DrGonz78 like this.
  26. #26
    Feb 2007
    1,200
    T9 still has 20v at gate with or without something in the input jack.
    i dont know what switches the gate volts on/off at T9 . T2 bad?
    T2 = E = switches 25v to 9mv
    B = switches 25v to 0.6v
    C = switches 26v to 27v
    i have swapped out T9 and T11
  27. #27
    Dec 2008
    Wernersville, PA
    11,967
    "T9 still has 20v at gate with or without something in the input jack.
    I don't know what switches the gate volts on/off at T9"
    Either the Ft Sw Ring normally closed contact (going open) or the Fr Pnl Sw (going open) will remove the +20V from the gate of T9.
  28. #28
    Feb 2007
    1,200
    I inserted a cable in the fsw jack- it does switch and the T9 gate volts go to 0.2v when in od mode......still no sound though--also tried pressing down on the contacts
  29. #29
    g1
    g1 is offline
    Feb 2010
    9,338
    You had a fet that looked bad, T11. You swapped it with T9.
    Do the resistance checks on both again. When the voltage is at the gate the D & S should not be shorted.
    If one of them is shorted all the time, remove it and see what the amp does with it removed.
    Certified Dotard
  30. #30
    Feb 2007
    1,200
    ive swapped out T 9 / 10 / 11 at this point with a J175 (that should work as a 174 yes? ) = no change
    with 20v at gate of T9 or T11 -- D+S is open on T9 / T11
    before i swapped T10 out i tested like above and D+S was 1.8k so i tried swapping it = nothing....
    if i pull T11 out do i need to leave t9/10 in ...or can i pull more than 1 ?
  31. #31
    Feb 2007
    1,200
    I powered it up tonight , removing 1 transistor , out of the amp 1 at a time for signal , then replacing it....next one , replacing it , etcc T9 - 10 - 11
    Nothing--no OD channel .
    Im so close......and so frustrated .
    tested each of the 3 J174 , out of the amp and on the bench for resistance and Diode test---all 3 are identical .
  32. #32
    Oct 2011
    Scottsdale, AZ
    1,709
    Did you suss out that T11 issue and do the voltages make any sense now? So we have no signal on OD channels. Perhaps you have all the channel switching circuit running fine now. Have you tried to replace V2 to make sure it is not bad? Just a quick thing to check or at least to make sure you have checked it.
    Edit: Or do I have that backwards and V1B is the tube used to generate the Overdrive in the amp? Perhaps it is V1 since I see ODMUTE at that tube.
  33. #33
    g1
    g1 is offline
    Feb 2010
    9,338
    Agree with Dr. Gonz that the fet switching cirucuits seem to be working properly. Time for signal tracing.
    You hear the relay click, but are it's switch contacts closing and passing signal?
    Certified Dotard
  34. #34
    Feb 2007
    1,200
    FOUND THE PROBLEM !!!
    What a F$!$@@#! n relief............ !!
    i went back thru the preamp area with my meter and magnifier , triple checking connections---finally found a bad one....looks like someone replaced a 100k in there previously , and it was just barely on a bent up trace....so i soldered and Bingo---------------amp works perfect now !!
    I appreciate everyones time and knowledge and I definitely learned a little about the J174 !!
    THANKS GUYS .
    g1, The Dude and DrGonz78 like this.
  1. DSL 401
    By Valvehead in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-02-2016, 08:40 PM
  2. DSL 401 mods
    By Chimp93 in forum Mods & Tweaks
    Last Post: 09-30-2013, 02:03 AM
  3. marshall dsl 401
    By Valvehead in forum Schematic Requests
    Last Post: 06-06-2013, 06:51 AM
  4. Dsl 401
    By sscamaro14 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-02-2010, 02:31 AM
  5. marshall dsl 401
    By samyx in forum Music Electronics
    Last Post: 02-03-2009, 02:34 AM
