Results 1 to 17 of 17
Thread: Another oscilloscope question
    Jan 2018
    Mass. U.S.A.
    143
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Just found an Iwatsu SS-5706 30 Mhz scope with HP probe for sale.
    He states in the listing that Everything works as it should. It's pretty light for it's size and has low hours.
    Wondering if it would be good enough for amp testing.
    He is asking $50.00 for it.
    Still have to see if he still has it, it's a bit of a ride to go get it.
    Here as two pictures of it.
ID:	47093 Click image for larger version.
    0 Not allowed! Not allowed!
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,860
    Thumbs Up/Down
    Received: 66/1
    Given: 0/0
    Sounds reasonable. Just about any scope that makes a picture is good enough for guitar amps. Bandwidth is just not an issue.
    Jan 2018
    Mass. U.S.A.
    143
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thanks Enzo. The scope usage is new to me so not sure what's needed.
    If I could get my hands on a cheap or free single primary, single HV secondary trans that would work on the Eico Id'e try it just for the heck of it.
    Aug 2012
    Great Black Swamp
    1,765
    Thumbs Up/Down
    Received: 11/0
    Given: 17/0
    If you go looking at it, test it with a 9v battery just to see that it works in DC mode and that it's calibrated (may take some dial twiddling to ensure you're reading the scale ranges correctly), then probe a house outlet to see a 60Hz sin wave. If it works for both AC and DC, then it works. IMHO, $50 is next to free if you're getting a set of probes along with it.
    edit: even if you don't get probes, it is still a good deal.
    Distortion is a form of signal degradation. It is pretty easy to define what a good "clean" signal is, but trying to achieve just the right kind of "broken" can be pretty maddening. - glebert
    Jan 2018
    Mass. U.S.A.
    143
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thanks.
    It's all new to me, not sure how to use one properly just yet so I'll see if they are willing to show it works not just powers up or grantee it works.
    He claims it works but you never know.
    Also looking at a Tektronix 2465A DV 350 MHz 4 channel with 2 probes for $140.00.
    Claims it works.
    This one.
    Supporting Member mozz's Avatar
    Oct 2015
    NEPA
    512
    Thumbs Up/Down
    Received: 6/0
    Given: 4/0
    That Tek is a nice scope. Parts, if needed are a lot easier to find. It may have a steeper learning curve but it has the auto setup button which is nice. You won't outgrow it as soon as that Japanese scope.
  7. #7
    Supporting Member The Dude's Avatar
    May 2010
    Sioux Falls, SD
    5,035
    Thumbs Up/Down
    Received: 13/0
    Given: 8/0
    ^^^^^^Agreed. The numerical readout is handy, too.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  8. #8
    Jan 2018
    Mass. U.S.A.
    143
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    OH well, the Tektronix is gone still waiting to hear about the Awatsu.
  9. #9
    Senior Member SoulFetish's Avatar
    Jan 2016
    Massachusetts
    641
    Thumbs Up/Down
    Received: 2/0
    Given: 2/0
    Quote Originally Posted by J Luth View Post
    Thanks.
    Claims it works.
    This one.
    I really like the waveform resolution you get using analog scopes and I LOVE the Tek 2465* scopes and am hoping to grab one when I can. They don't last long at that price if they're working.
    ... I see you're on the east coast. Don't Bogart all the craigslist 2465s on me.
  10. #10
    Jan 2018
    Mass. U.S.A.
    143
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    SoulFetish
    Not only are we on the same coast, although it actually showed east cost, DOH, we're in the same state. And if I remember correctly I'm not all that far from where you work, about a 1/2 hour to 45 min drive for me.
  11. #11
    Jan 2018
    Mass. U.S.A.
    143
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Are the Tektronix 434 scopes really as bad as I have read.
    Found this one for $110.00 if it's still available.
    Attached Images Attached Images
  12. #12
    Jan 2018
    Mass. U.S.A.
    143
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I'm still on the hunt for a scope.
    Found this oldie Tektronix T935A real low price.
    The T935A is from a Ham guy that repairs ham radios and tube radios. Says if I come up he will demo that everything works it's a bit of a ride for me. Figure it might be a good entry level scope and the price is real low. The 434 is a lot closer and more money but I don't know if they will let me come and see it working.
  13. #13
    29,860
    Thumbs Up/Down
    Received: 66/1
    Given: 0/0
    Ask them. I would be suspicious of any sale they won't let me see it working.
    Otherwise, any working scope will be sufficient.
  14. #14
    Jan 2018
    Mass. U.S.A.
    143
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thanks Enzo
    I read an article about the 434 that stated it was not a good model, hard to repair, no parts available and not constructed very well. I am leaning towards the older T935A. It's cheaper so it wont hurt as much if it dies or I screw it up. He will show that everything works as it should plus he may have a lot of other parts I am looking for along with possible a transformer for the Eico 460 or maybe just a HV one I can put in along with the stock one.
  15. #15
    Feb 2010
    9,827
    Thumbs Up/Down
    Received: 49/0
    Given: 67/0
    Not only a good deal but sounds like a good guy to know.
    Certified Dotard
  16. #16
    Old Timer olddawg's Avatar
    Dec 2007
    Carlsbad, CA and Kona, HI
    2,607
    Thumbs Up/Down
    Received: 8/0
    Given: 0/0
    The most important thing once it's running is to make sure that it will trigger.
  17. #17
    Jan 2018
    Mass. U.S.A.
    143
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Well I bought the Tektronix T935A. Got it for $60.00 with a 10X probe. They ran it and showed that it worked but only time will tell. If it has issues at least it was only $60.00 and not a hundred or two. All the switches and pot's were a bit stiff, took the case off and cleaned everything. They all work great now. I will probably change the 3 electrolytic caps that are easy to get to, they all measure out of spec a bit.
    Pretty cool place like walking back in time, Radio Rescue Ashburnham Ma. A lot of ham gear, tube radios and a lot of other old and older electronics. Shelves and cabinets full of parts, ham gear, cathedral radios, large probably 1930's, 40's floor model radios, grandfather clocks everywhere. I could spend hours walking around looking and probably not see everything. Stacks and stacks of original tubes but he wouldn't sell any of them. Says he keeps them for the repairs and rebuilds. Dagnabit!
    So far I haven't let the smoke out of the scope.
  1. Eico model 460 oscilloscope question
    By J Luth in forum Music Electronics
    Last Post: 02-14-2018, 05:30 AM
  2. Oscilloscope Question
    By SpareRibs in forum Music Electronics
    Last Post: 12-19-2011, 06:34 AM
  3. Oscilloscope
    By Groover in forum Theory & Design
    Last Post: 04-19-2010, 05:47 AM
  4. Basic Oscilloscope question
    By Froumy in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-24-2007, 03:17 PM
  5. Newbie question - obtaining an oscilloscope
    By ZBod in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-04-2007, 04:45 PM
