Results 1 to 5 of 5
Thread: Fuse resistance
    Supporting Member
    Dec 2009
    UK
    3,250
    Thumbs Up/Down
    Received: 12/0
    Given: 2/0
    Fuse resistance
    I noticed that after replacing the cathode fuses in an Engl amp the power tube LED was flashing in sequence to playing. The only way is if there's either a circuit fault or the fuses have a high enough resistance for the voltage drop to trigger the LED circuit. I re-checked the amp and checked the fuses - they all read 56 Ohms, which really annoyed me as I'd just bought them and had to make up a minimum order charge as I was out of stock (T63mA).
    I did a further check and the resistance holds out even at their rated voltage and close to their capacity. Temporarily swapped them out for some T100mA and no problem.
    0 Not allowed! Not allowed!
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,873
    Thumbs Up/Down
    Received: 77/1
    Given: 0/0
    Really low current fuses like that do normally show resistance. My HP meter used 32ma fuses.
    So other than the LEDs blink, what problem did the smaller fuses cause?
    Supporting Member
    Dec 2009
    UK
    3,250
    Thumbs Up/Down
    Received: 12/0
    Given: 2/0
    No other problem that I can see, though the 'scoped output increased just a little with lower resistance fuses. The originals read a little over 10 ohms so I've ordered another lot from a different supplier who lists the resistance. I would think that 56 ohms in each cathode circuit would introduce a little more NFB, as it's unbypassed. The main issue is I don't want to return the amp to the customer with a flashing LED that didn't flash before.
    Feb 2010
    9,836
    Thumbs Up/Down
    Received: 58/0
    Given: 100/0
    I remember some of the slow blows used to have little resistors inside, maybe some still do.
    Could you just tell the guy it's the 'back-off!' light?
    Certified Dotard
    Supporting Member
    Dec 2009
    UK
    3,250
    Thumbs Up/Down
    Received: 12/0
    Given: 2/0
    I actually prefer the flashing LED. It just needs to be blue to make it a 'now' thing.
  1. Why would anyone put a fuse in seies with another fuse, you might ask? Iíll tell you
    By SoulFetish in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-18-2017, 07:16 AM
  2. thermal resistance
    By Randall in forum Theory & Design
    Last Post: 06-23-2016, 02:02 AM
  3. Vintage Yamaha EM 150 II fuse holder & fuse.
    By Shmitty312 in forum Music Electronics
    Last Post: 08-05-2013, 03:14 AM
  4. Winds To Resistance Formula?
    By automan in forum Pickup Makers
    Last Post: 07-06-2009, 01:20 PM
  5. DC Resistance
    By eggman6 in forum Pickup Makers
    Last Post: 02-22-2009, 02:27 AM
