Results 1 to 13 of 13
Thread: Internal Quick-Disconnects for Strats?
    Better Tone thru Mathematics bob p's Avatar
    Chicago, USA
    4,908
    Thumbs Up/Down
    Received: 38/0
    Given: 0/0
    I'm wondering if anyone has developed a system using internal quick-disconnect systems when wiring up their guitars. I think this sort of thing would be particularly useful for pickup swapping, or in the case of a Strat, loaded pickguard swapping.
    I'm aware that there are some manufacturers out there who are already using solderless harnesses for their pickups (Epi and Gibson, I think, as well as others). I don't have any guitars like that, and my application doesn't involve testing pickups that have those sorts of connections (at least for now). I'm more interested in hearing about different DIY solutions that people might have implemented that didn't involve buying a commercial solderless wiring harness.
    In the instant case, I'm working on a parts-caster Strat. I'd like to be able to do pickup swaps, and because of all of the screws that are involved in a strat pickguard and pickup removal, the easiest way to do this seems to be to swap out loaded pickguards. The only hurdle to overcome in making it really easy to swap a Strat loaded pickguard is the soldered connection to the output jack. To make the swapping experience totally solderless, I've thought about using some sort of quick-connector located in the main control cavity to connect the output jack to the loaded pickguard assembly.
    I'm wondering if anyone has done this and what sort of connectors they found to be useful. I'm searching my junk drawers for for things to repurpose and it's looking like I might have to buy something, so I thought I'd ask.
    1 Not allowed! Not allowed!
    Supporting Member
    Dec 2009
    UK
    3,253
    Thumbs Up/Down
    Received: 18/0
    Given: 2/0
    I use .1" SIL and DIL connectors in various styles according to what I'm doing. I'll etch a small number of boards and mount an SMD header if it's attaching to a flat surface and use a 'flying' connector with crimp terminals to connect. I only use this system to connect various parts of more complex guitars with synth/piezo/magnetic combinations where I need to be able to easily swap out sections for troubleshooting or changes. .1" connectors are available in SMD, through-hole, crimp and solder bucket formats in all kinds variations. Plus they're inexpensive.
    0 Not allowed! Not allowed!
    Chicago, USA
    4,908
    Thumbs Up/Down
    Received: 38/0
    Given: 0/0
    I had thought of using "Dupont" connectors like these:
    The biggest downside seems to be that they are non-locking.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,170
    Thumbs Up/Down
    Received: 259/1
    Given: 0/0
    There are small connectors similar to that in modern reverb pans, on the transducers. I rarely see them come off, the wires break first.
    But if you wire inside a guitar like that, fold the wire back on itself, and put a tie wrap around it, so there is no slack for the connector to part without cutting the tie wrap. Snip the tie for quick access to do whatever plug in changes, but otherwise secure.
    Supporting Member
    Dec 2009
    UK
    3,253
    Thumbs Up/Down
    Received: 18/0
    Given: 2/0
    Think about all the EMG-equipped guitars with non-locking connectors and they don't come apart. I don't see this as a downside in a guitar.
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    10,142
    Thumbs Up/Down
    Received: 88/21
    Given: 92/9
    On some of my pickup test guitars I solder on short pigtails, and test the pickups with small wire nuts.
    On everything else I like a neat layout, with shorter leads, all soldered, and no rats nests.
    Wiring rats nests, usually are very noisy. Here, big on lots of shielding & grounding.
    T
    “When you find yourself in a hole, quit digging.” WILL ROGERS
    Keep Rockin! B_T
    Terry
  7. #7
    Supporting Member Steve A.'s Avatar
    4,447
    Thumbs Up/Down
    Received: 69/0
    Given: 56/0
    Several vendors have their own quick-connect harness systems, none of which are interchangeable AFAIK. Some 2000-ish Epiphones had quick connects inches from the pickup to facilitate pickup swaps and many if not most of the recent Gibsons have been using printed circuit boards for their controls.
    Locking connectors might be good for ES-335 style guitars with wiring accessible through the f-holes, otherwise not...
    Steve A.
  8. #8
    New Member
    Jun 2018
    1
    Thumbs Up/Down
    Received: 1/0
    Given: 1/0
    I used 1/8-3/16" spade terminals and they work great but solder them on the leads, crimps alone are not enough.
  9. #9
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,223
    Thumbs Up/Down
    Received: 184/0
    Given: 255/0
    Now if we can come up with a way to swap strat pickups without unstringing and removing the pick guard THAT would be great.
    "I'm just going to perform a bit more scientific investigation, turn it up to 11 and rip of the knob." überfuzz
    "A pedal, any kind, will not make a Guitar player more dangerous than he already is." J M Fahey
    "If you build it, it will hum..." Justin Thomas
  10. #10
    Aug 2015
    Edmonton, AB
    85
    Thumbs Up/Down
    Received: 47/0
    Given: 26/0
    Quote Originally Posted by Chuck H View Post
    Cut a hole in the back... ... but you knew somebody waz gonna say that...
  11. #11
    Feb 2010
    Just south of Bawlmer, Merlin
    2,360
    Thumbs Up/Down
    Received: 73/1
    Given: 53/1
    Quote Originally Posted by galaxiex View Post
    I've never owned a real Strat, but I think the springs and trem block would be in the way... but you knew somebody was gonna say that....
    -rb
  12. #12
    4,447
    Thumbs Up/Down
    Received: 69/0
    Given: 56/0
    Well, if the strat has a swimming pool route I can usually loosen the strings enough to slide the pickguard out but I guess that doesn't count...
    Steve A.
  13. #13
    3,658
    Thumbs Up/Down
    Received: 31/1
    Given: 3/0
    I'll put a bug in your ear for the connector cables traditionally used to connect a CD/DVD drive to a sound card or mobo. Unlike the Dupont connector shown in the thread, these cables are shielded and have two additional wires, making them amenable to phase-reversal, coil-cancelling, or anything else requiring more than a simple hot and ground.
    The caveat is that they are getting harder to find as more and more desktop machines eschew drives of any kind, and that they are long-ish. But they are slender and every bit as flexible as one might need.
  1. Quick quick question re Series resistor power handling
    By emenasche in forum Guitar Amps
    Last Post: 04-01-2017, 08:55 PM
  2. Replies: 1
    Last Post: 01-18-2014, 05:29 PM
  3. RWRP tones in strats - basic question
    By Marco Pancaldi in forum Pickup Makers
    Last Post: 03-21-2012, 04:07 PM
  4. Replies: 13
    Last Post: 10-19-2011, 10:41 AM
  5. why fender changed polarity on strats?
    By Rosewood in forum Pickup Makers
    Last Post: 10-28-2007, 05:09 AM
