Results 1 to 6 of 6
Thread: Carvin mts3200 problem
    New Member
    Dec 2016
    5
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hi, i,m from Perú and i have some issue with my head carvin mts3200; i was using it normaly( no problems or issues) so then yesterday we had a rehersal with my rock band and when i try to turn on the head the front ligths turn on but no sound was in the speakers then i loocked in the back and i saw the tubes and no one was runnig, i mean it was like all the tubes were turn off, but the front lights were running normally, since here there is not technical services or repair i'd like to check if its possible to me make something, i'll be very grateful and happy of someone could help me , thx for all the comunity
    0 Not allowed! Not allowed!
    Dec 2008
    Wernersville, PA
    12,243
    Thumbs Up/Down
    Received: 35/0
    Given: 15/0
    The power ON light is an integral part of the power switch itself.
    Switch ON/ Light On.
    It relies on the mains line voltage.
    To see why the tubes do not light up you will have to dig deeper.
    http://www.thetubestore.com/lib/thet...-Schematic.pdf
    NYC
    1,654
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I would check the heater/filament voltages first.
    Nov 2013
    132
    Thumbs Up/Down
    Received: 8/1
    Given: 0/0
    Schematic is around the net, you have the first 2 preamp tubes in DC, and there are fuseable resistors on the lines.
    Senior Member Pedro Vecino's Avatar
    Jul 2006
    Spain
    500
    Thumbs Up/Down
    Received: 5/0
    Given: 12/0
    Your amp must be a export model. It must contain inside, on the board, a fuse holder marked as F1 with a 10A fuse. Remove it and check its integrity. If it is open that would be the reason why the tubes do not light up.
    Please, confirm this when you try it.
    New Member
    Dec 2016
    5
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    thank you very much, everyone helps me, the problem was a fuse (f1) i´m so happy that was only that , i´ll save money for a tube set. this forum is the best
  1. Carvin VT50 problem, need help please.
    By sjturbo in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-30-2017, 02:21 AM
  2. Carvin X100b problem
    By squimbolio in forum Music Electronics
    Last Post: 08-31-2012, 07:34 AM
  3. Carvin MTS3200 reverb tank
    By lbaudio in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-16-2009, 06:58 PM
  4. CARVIN MTS3200 HELP!!! loud hum noise
    By brian_shott in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-25-2007, 09:21 AM
  5. Carvin TSL100 problem
    By drewl in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-09-2007, 03:20 PM
Tags for this Thread
