Results 1 to 11 of 11
Like Tree3Likes
  • 1 Post By Antigua
  • 1 Post By copperheadroads
  • 1 Post By MKB
Thread: Has somebody tried? Wiring a 51 P PU partly with AWG 43 and partly AWG 42?
    May 2015
    24
    Has anybody tried to wind one coil with two different wire gauges?
    I had a little AWG 43 left and wound first 2000 turns with that. And then some 8000 turns with AWG 42. (DCR is 7,7 kΩ and ind. is 3 H)
    Sound is more trebly, but not bad at all. Haven't tried it with a band yet.
    Senior Member LtKojak's Avatar
    Feb 2008
    Milano, Italy
    942
    Quote Originally Posted by okabass View Post
    I know at least three boutique winders that have production models of p'ups wound with different wire gauges in the same bobbin/s.
    Pepe aka Lt. Kojak
    Milano, Italy
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    10,539
    I don't get, or dig the two gauge series concept?
    Why not go to 42-1/2, or 43 on the whole bobbin?
    Would be much easier to make.
    https://www.remingtonindustries.com/...5-spool-sizes/
    T
    Technicians Run the World, but Bankers, Lawyers, and Accountants, Take All The Credit!
    Keep Rockin! B_T
    Terry
    3,974
    It would, but I suspect the use of two gauges is for the purpose of spacing the inner turns one way and the outer turns another. Just a guess.
    Supporting Member
    PDX
    3,199
    The OP will have to let us know how it works out. I'd think one would need to wind a series of PUs with identical specs to see if there was an audible difference not caused by other vagaries of the wind like tension, TPL, internal shorts etc.
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,045
    Why switch up with smaller wire size with a pickup that has space to account for/& designed for awg42 ...........if you now why ...why do it .
    "UP here in the Canada we shoot things we don't understand"
  7. #7
    May 2015
    24
    Quote Originally Posted by copperheadroads View Post
    I'm the one who's asking. Why are you answering with questions if (?) you know about the matter?
  8. #8
    Jun 2015
    138
    From a theory standpoint, the only difference should be in terms of summed series resistance, which in turn just damps the resonance slightly, and as alluded to above, would be about the same as using 42.5 AWG. Differences of capacitance or inductive coupling would rely more on the insulation thickness or the winding pattern.
    okabass likes this.
  9. #9
    Jun 2009
    2,045
    Usually, smaller gauge wire would be used when you can not get the desired number of turns on a particular bobbin/pickup.
    I do this with one of my pickups ,start off with 42 gauge & finish it with 43 gauge but it's only to get a desired number of turns .Not really a tonal decision thing .
    With that said , you can certainly make a great pickup buy using 42/43 . the bass slightly gets a little deeper but would be hardly noticeable if you are only doing 2000 turns . Good on you for using ALL the wire .
    okabass likes this.
  10. #10
    May 2015
    24
    Thank you.
  11. #11
    MKB
    MKB is offline
    Jun 2006
    29
    Don't know if this would be of much help, and I'm not a pro pickup builder, but back in the 90s I had an American Standard Strat that had what I thought was a really weak bridge pickup. A friend had just given me a roll of 44ga, so I added enough turns of that to fill up the bobbin. Not sure what the DCR ended up to be or how many winds I added, will have to dig into the archives to find out. But I do recall it sounded fantastic, exactly what I wanted. So if anyone runs across a black nineties Strat with a plastic bobbin stock bridge pup with strange looking green 44ga magnet wire, that's the one.
    One would think that the smaller gauge magnet wire trick could be useful if someone wants to beef up a stock pickup a bit, the thinner wire would allow more turns in what little space might be available. Could be a quick thing to try before a total rewind of an otherwise good pickup.
    okabass likes this.
  1. AWG 42 and 43 wire sources
    By Ruel in forum Pickup Makers
    Last Post: 07-20-2012, 09:41 PM
  2. What Next 43 - 44 awg
    By JCrab in forum Beginner/ Hobbyist
    Last Post: 01-27-2012, 06:23 AM
  3. 43 AWG PE
    By lespaul123 in forum Pickup Makers
    Last Post: 04-05-2011, 10:54 PM
  4. 42.5 awg
    By kevinT in forum Pickup Makers
    Last Post: 03-17-2009, 10:53 AM
  5. 43 AWG problem
    By lordnikon in forum Pickup Makers
    Last Post: 10-17-2007, 10:12 AM
